AAX SDK  2.1.1
List of all members | Public Member Functions | Protected Member Functions | Protected Attributes
AAX_CEffectParameters Class Reference
#include <AAX_CEffectParameters.h>
Inheritance diagram for AAX_CEffectParameters:
Inheritance graph
[legend]
Collaboration diagram for AAX_CEffectParameters:
Collaboration graph
[legend]
Description
Default implementation of the AAX_IEffectParameters interface.
This class provides a default implementation of the AAX_IEffectParameters interface. In nearly all cases, your plug-in's data model should inherit from this class and override only those functions that you wish to explicitly customize.
Legacy Porting Notes:
The default implementations in this class are mostly derived from their equivalent implementations in CProcess and CEffectProcess. For additional CProcess-derived implementations, see AAX_CEffectGUI.
Related classes
Classes related to AAX_IEffectParameters by inheritance or composition
Classes owned as member objects of AAX_CEffectParameters
 AAX_CEffectParameters (void)
virtual ~AAX_CEffectParameters (void)
AAX_CEffectParameters & operator= (const AAX_CEffectParameters &other)
Initialization and uninitialization
virtual AAX_Result Initialize (IACFUnknown *iController)
 Main data model initialization. Called when plug-in instance is first instantiated. More...
virtual AAX_Result Uninitialize (void)
 Main data model uninitialization. More...
AAX host and plug-in event notification
virtual AAX_Result NotificationReceived (AAX_CTypeID iNotificationType, const void *iNotificationData, uint32_t iNotificationDataSize)
 Notification Hook. More...
Parameter information
These methods are used by the AAX host to retrieve information about the plug-in's data model. For information about adding parameters to the plug-in and otherwise modifying the plug-in's data model, see AAX_CParameterManager. For information about parameters, see AAX_IParameter.
virtual AAX_Result GetNumberOfParameters (int32_t *oNumControls) const
 CALL: Retrieves the total number of plug-in parameters. More...
virtual AAX_Result GetMasterBypassParameter (AAX_IString *oIDString) const
 CALL: Retrieves the ID of the plug-in's Master Bypass parameter. More...
virtual AAX_Result GetParameterIsAutomatable (AAX_CParamID iParameterID, AAX_CBoolean *oAutomatable) const
 CALL: Retrieves information about a parameter's automatable status. More...
virtual AAX_Result GetParameterNumberOfSteps (AAX_CParamID iParameterID, int32_t *oNumSteps) const
 CALL: Retrieves the number of discrete steps for a parameter. More...
virtual AAX_Result GetParameterName (AAX_CParamID iParameterID, AAX_IString *oName) const
 CALL: Retrieves the full name for a parameter. More...
virtual AAX_Result GetParameterNameOfLength (AAX_CParamID iParameterID, AAX_IString *oName, int32_t iNameLength) const
 CALL: Retrieves an abbreviated name for a parameter. More...
virtual AAX_Result GetParameterDefaultNormalizedValue (AAX_CParamID iParameterID, double *oValue) const
 CALL: Retrieves default value of a parameter. More...
virtual AAX_Result SetParameterDefaultNormalizedValue (AAX_CParamID iParameterID, double iValue)
 CALL: Sets the default value of a parameter. More...
virtual AAX_Result GetParameterType (AAX_CParamID iParameterID, AAX_EParameterType *oParameterType) const
 CALL: Retrieves the type of a parameter. More...
virtual AAX_Result GetParameterOrientation (AAX_CParamID iParameterID, AAX_EParameterOrientation *oParameterOrientation) const
 CALL: Retrieves the orientation that should be applied to a parameter's controls. More...
virtual AAX_Result GetParameter (AAX_CParamID iParameterID, AAX_IParameter **oParameter)
 CALL: Retrieves an arbitrary setting within a parameter. More...
virtual AAX_Result GetParameterIndex (AAX_CParamID iParameterID, int32_t *oControlIndex) const
 CALL: Retrieves the index of a parameter. More...
virtual AAX_Result GetParameterIDFromIndex (int32_t iControlIndex, AAX_IString *oParameterIDString) const
 CALL: Retrieves the ID of a parameter. More...
virtual AAX_Result GetParameterValueInfo (AAX_CParamID iParameterID, int32_t iSelector, int32_t *oValue) const
 CALL: Retrieves a property of a parameter. More...
Parameter setters and getters
These methods are used by the AAX host and by the plug-in's UI to retrieve and modify the values of the plug-in's parameters.
Note
The parameter setters in this section may generate asynchronous requests.
virtual AAX_Result GetParameterValueFromString (AAX_CParamID iParameterID, double *oValue, const AAX_IString &iValueString) const
 CALL: Converts a value string to a value. More...
virtual AAX_Result GetParameterStringFromValue (AAX_CParamID iParameterID, double iValue, AAX_IString *oValueString, int32_t iMaxLength) const
 CALL: Converts a normalized parameter value into a string representing its corresponding real value. More...
virtual AAX_Result GetParameterValueString (AAX_CParamID iParameterID, AAX_IString *oValueString, int32_t iMaxLength) const
 CALL: Retrieves the value string associated with a parameter's current value. More...
virtual AAX_Result GetParameterNormalizedValue (AAX_CParamID iParameterID, double *oValuePtr) const
 CALL: Retrieves a parameter's current value. More...
virtual AAX_Result SetParameterNormalizedValue (AAX_CParamID iParameterID, double iValue)
 CALL: Sets the specified parameter to a new value. More...
virtual AAX_Result SetParameterNormalizedRelative (AAX_CParamID iParameterID, double iValue)
 CALL: Sets the specified parameter to a new value relative to its current value. More...
Automated parameter helpers
These methods are used to lock and unlock automation system 'resources' when updating automatable parameters.
Note
You should never need to override these methods to extend their behavior beyond what is provided in AAX_CEffectParameters and AAX_IParameter
Todo:
Do these methods belong in the data model? Should integration with automation system be bolt-on or otherwise modular?
virtual AAX_Result TouchParameter (AAX_CParamID iParameterID)
 "Touches" (locks) a parameter in the automation system to a particular control in preparation for updates More...
virtual AAX_Result ReleaseParameter (AAX_CParamID iParameterID)
 Releases a parameter from a "touched" state. More...
virtual AAX_Result UpdateParameterTouch (AAX_CParamID iParameterID, AAX_CBoolean iTouchState)
 Sets a "touched" state on a parameter. More...
Asynchronous parameter update methods
These methods are called by the AAX host when parameter values have been updated. They are called by the host and can be triggered by other plug-in modules via calls to AAX_IParameter's SetValue methods, e.g. SetValueWithFloat()
These methods are responsible for updating parameter values.
Do not call these methods directly! To ensure proper synchronization and to avoid problematic dependency chains, other methods (e.g. SetParameterNormalizedValue()) and components (e.g. AAX_IEffectGUI) should always call a SetValue method on AAX_IParameter to update parameter values. The SetValue method will properly manage automation locks and other system resources.
virtual AAX_Result UpdateParameterNormalizedValue (AAX_CParamID iParameterID, double iValue, AAX_EUpdateSource iSource)
 Updates a single parameter's state to its current value. More...
virtual AAX_Result UpdateParameterNormalizedRelative (AAX_CParamID iParameterID, double iValue)
 Updates a single parameter's state to its current value, as a difference with the parameter's previous value. More...
virtual AAX_Result GenerateCoefficients (void)
 Generates and dispatches new coefficient packets. More...
State reset handlers
virtual AAX_Result ResetFieldData (AAX_CFieldIndex iFieldIndex, void *oData, uint32_t iDataSize) const
 Called by the host to reset a private data field in the plug-in's algorithm. More...
Chunk methods
These methods are used to save and restore collections of plug-in state information, known as chunks. Chunks are used by the host when saving or restoring presets and session settings and when providing "compare" functionality for plug-ins.
The default implementation of these methods in AAX_CEffectParameters provides save and restore functionality for all of the plug-in's registered parameters. Override these methods to provide additional plug-in state details that are not encapsulated by the plug-in's set of parameters.
For reference, see also:
virtual AAX_Result GetNumberOfChunks (int32_t *oNumChunks) const
 Retrieves the number of chunks used by this plug-in. More...
virtual AAX_Result GetChunkIDFromIndex (int32_t iIndex, AAX_CTypeID *oChunkID) const
 Retrieves the ID associated with a chunk index. More...
virtual AAX_Result GetChunkSize (AAX_CTypeID iChunkID, uint32_t *oSize) const
 Get the size of the data structure that can hold all of a chunk's information. More...
virtual AAX_Result GetChunk (AAX_CTypeID iChunkID, AAX_SPlugInChunk *oChunk) const
 Fills a block of data with chunk information representing the plug-in's current state. More...
virtual AAX_Result SetChunk (AAX_CTypeID iChunkID, const AAX_SPlugInChunk *iChunk)
 Restores a set of plug-in parameters based on chunk information. More...
virtual AAX_Result CompareActiveChunk (const AAX_SPlugInChunk *iChunkP, AAX_CBoolean *oIsEqual) const
 Determine if a chunk represents settings that are equivalent to the plug-in's current state. More...
virtual AAX_Result GetNumberOfChanges (int32_t *oNumChanges) const
 Retrieves the number of parameter changes made since the plug-in's creation. More...
Threads
Threading functions
virtual AAX_Result TimerWakeup ()
 Periodic wakeup callback for idle-time operations. More...
Eucon
Eucon functions
virtual AAX_Result GetCurveData (AAX_CTypeID iCurveType, const float *iValues, uint32_t iNumValues, float *oValues) const
 Generate a set of output values based on a set of given input values. More...
Custom Data Methods
These functions exist as a proxiable way to move data between different modules (e.g. AAX_IEffectParameters and AAX_IEffectGUI.) Using these, the GUI can query any data through GetCustomData() with a plug-in defined typeID, void* and size. This has an advantage over just sharing memory in that this function can work as a remote proxy as we enable those sorts of features later in the platform. Likewise, the GUI can also set arbitrary data on the data model by using the SetCustomData() function with the same idea.
Note
These are plug-in internal only. They are not called from the host right now, or likely ever.
virtual AAX_Result GetCustomData (AAX_CTypeID iDataBlockID, uint32_t iDataSize, void *oData, uint32_t *oDataWritten) const
 An optional interface hook for getting custom data from another module. More...
virtual AAX_Result SetCustomData (AAX_CTypeID iDataBlockID, uint32_t iDataSize, const void *iData)
 An optional interface hook for setting custom data for use by another module. More...
MIDI methods
virtual AAX_Result DoMIDITransfers ()
 MIDI update callback. More...
virtual AAX_Result UpdateMIDINodes (AAX_CFieldIndex iFieldIndex, AAX_CMidiPacket &iPacket)
virtual AAX_Result UpdateControlMIDINodes (AAX_CTypeID nodeID, AAX_CMidiPacket &iPacket)
 MIDI update callback for control MIDI nodes. More...
Hybrid audio methods
virtual AAX_Result RenderAudio_Hybrid (AAX_SHybridRenderInfo *ioRenderInfo)
 Hybrid audio render function. More...
Private data accessors
AAX_IController * Controller ()
 Access to the Effect controller. More...
const AAX_IController * Controller () const
 const access to the Effect controller More...
AAX_ITransport * Transport ()
 Access to the Transport object. More...
const AAX_ITransport * Transport () const
 const access to the Transport object More...
AAX_IAutomationDelegate * AutomationDelegate ()
const AAX_IAutomationDelegate * AutomationDelegate () const
- Public Member Functions inherited from AAX_IEffectParameters
ACFMETHOD() InternalQueryInterface (const acfIID &riid, void **ppvObjOut)
MIDI methods
Note
Note
Todo:
Chunk methods
Thread Methods
EUCON Methods
Custom Data Methods
Note
MIDI methods
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
void BuildChunkData (void) const
 Clears out the current chunk in Chunk Parser and adds all of the new values. Used by default implementations of GetChunk() and GetChunkSize(). More...
Parameter management methods
AAX_Result SetTaperDelegate (AAX_CParamID iParameterID, AAX_ITaperDelegateBase &iTaperDelegate, bool iPreserveValue)
AAX_Result SetDisplayDelegate (AAX_CParamID iParameterID, AAX_IDisplayDelegateBase &iDisplayDelegate)
bool IsParameterTouched (AAX_CParamID iParameterID) const
bool IsParameterLinkReady (AAX_CParamID inParameterID, AAX_EUpdateSource inSource) const
Convenience functions
These convenience functions provide quick access to various aspects of the default AAX_CEffectParameters implementation.
virtual AAX_Result EffectInit (void)
 Initialization helper routine. Called from AAX_CEffectParameters::Initialize. More...
void FilterParameterIDOnSave (AAX_CParamID controlID)
 CALL: Indicates the indices of parameters that should not be saved in the default AAX_CEffectParameters chunk. More...
int32_t mNumPlugInChanges
int32_t mChunkSize
AAX_CChunkDataParser mChunkParser
int32_t mNumChunkedParameters
AAX_CBoolean mClipped
 Set by SetClipped() and returned by GetClipped(). More...
AAX_CPacketDispatcher mPacketDispatcher
AAX_CParameterManager mParameterManager
std::set< std::string > mFilteredParameters
Constructor & Destructor Documentation
AAX_CEffectParameters::AAX_CEffectParameters ( void  )
virtual AAX_CEffectParameters::~AAX_CEffectParameters ( void  )
virtual
Member Function Documentation
AAX_CEffectParameters& AAX_CEffectParameters::operator= ( const AAX_CEffectParameters &  other)
virtual AAX_Result AAX_CEffectParameters::Initialize ( IACFUnknown *  iController)
virtual
Note
Most plug-ins should override AAX_CEffectParameters::EffectInit() rather than directly overriding this method
Parameters
[in]iControllerA versioned reference that resolves to an AAX_IController interface
This default implementation calls EffectInit(). Only override Initialize() when additional initialization steps must be performed prior to EffectInit().
Implements AAX_IACFEffectParameters.
virtual AAX_Result AAX_CEffectParameters::Uninitialize ( void  )
virtual
Todo:
Docs: When exactly is AAX_IACFEffectParameters::Uninitialize() called, and under what conditions?
virtual AAX_Result AAX_CEffectParameters::NotificationReceived ( AAX_CTypeID  iNotificationType,
const void *  iNotificationData,
virtual
Notification Hook.
Called from the host when major changes take place such as instantiation, insert position, track name. Most of these notifications are not sent from the host at this point, but we're putting this function in as a placeholder for plug-ins to be notified when events happen.
Look at the AAX_ENotificationEvent enumeration to see a description of events you can listen for and the data they come with.
Parameters
[in]iNotificationTypeType of notification being received
[in]iNotificationDataBlock of incoming notification data
[in]iNotificationDataSizeSize of iNotificationData, in bytes
virtual AAX_Result AAX_CEffectParameters::GetNumberOfParameters ( int32_t *  oNumControls) const
virtual
Parameters
[out]oNumControlsThe number of parameters in the plug-in's Parameter Manager
virtual AAX_Result AAX_CEffectParameters::GetMasterBypassParameter ( AAX_IString *  oIDString) const
virtual
This is required if you want our master bypass functionality in the host to hook up to your bypass parameters.
Parameters
[out]oIDStringThe ID of the plug-in's Master Bypass control
virtual AAX_Result AAX_CEffectParameters::GetParameterIsAutomatable ( AAX_CParamID  iParameterID,
AAX_CBoolean *  oAutomatable
) const
virtual
Parameters
[in]iParameterIDThe ID of the parameter that is being queried
[out]oAutomatableTrue if the queried parameter is automatable, false if it is not
virtual AAX_Result AAX_CEffectParameters::GetParameterNumberOfSteps ( AAX_CParamID  iParameterID,
int32_t *  oNumSteps
) const
virtual
Note
The value returned for oNumSteps MUST be greater than zero. All other values will be considered an error by the host.
Parameters
[out]oNumStepsThe number of steps for this parameter
virtual AAX_Result AAX_CEffectParameters::GetParameterName ( AAX_CParamID  iParameterID,
AAX_IString *  oName
) const
virtual
Parameters
[out]oNameThe parameter's name, formatted as a char*. Currently DAE does not be allow names longer that 31 characters.
virtual AAX_Result AAX_CEffectParameters::GetParameterNameOfLength ( AAX_CParamID  iParameterID,
AAX_IString *  oName,
int32_t  iNameLength
) const
virtual
In general, lengths of 3 through 8 and 31 should be specifically addressed.
Host Compatibility Notes:
In most cases, the AAX host will call GetParameterName() to retrieve parameter names for display. However, when Pro Tools is retrieving a plug-in name for display on a control surface the XML data stored in the plug-in's page tables will be used in preference to values retrieved from GetParameterName().
Parameters
[out]oNameThe name of the plug-in, abbreviated to aNameLength characters or fewer, formatted as a char*
[in]iNameLengthThe maximum number of characters in aName
virtual AAX_Result AAX_CEffectParameters::GetParameterDefaultNormalizedValue ( AAX_CParamID  iParameterID,
double *  oValue
) const
virtual
Parameters
[out]oValueThe parameter's default value
virtual AAX_Result AAX_CEffectParameters::SetParameterDefaultNormalizedValue ( AAX_CParamID  iParameterID,
double  iValue
virtual
Parameters
[in]iParameterIDThe ID of the parameter that is being updated
[out]iValueThe parameter's new default value
Todo:
THIS IS NOT CALLED FROM HOST. USEFUL FOR INTERNAL USE ONLY?
virtual AAX_Result AAX_CEffectParameters::GetParameterType ( AAX_CParamID  iParameterID,
AAX_EParameterType *  oParameterType
) const
virtual
Todo:
The concept of parameter type needs more documentation
Parameters
[out]oParameterTypeThe parameter's type
virtual AAX_Result AAX_CEffectParameters::GetParameterOrientation ( AAX_CParamID  iParameterID,
AAX_EParameterOrientation *  oParameterOrientation
) const
virtual
Todo:
update this documentation
This method allows you to specify the orientation of knob controls that are managed by the host (e.g. knobs on an attached control surface.)
Here is an example override of this method that reverses the orientation of a control for a parameter:
// AAX_IParameter* myBackwardsParameter
if (iParameterID == myBackwardsParameter->Identifier())
*oParameterType =
The orientation options are set according to AAX_EParameterOrientationBits
AAX_IEffectParameters::GetParameterOrientation() corresponds to the GetControlOrientation() method in the legacy RTAS/TDM SDK.
Parameters
[out]oParameterOrientationThe orientation of the parameter
virtual AAX_Result AAX_CEffectParameters::GetParameter ( AAX_CParamID  iParameterID,
AAX_IParameter **  oParameter
virtual
This is a convenience function for accessing the richer parameter interface from the plug-in's other modules.
Note
This function must not be called by the host; AAX_IParameter is not safe for passing across the binary boundary with the host!
Parameters
[out]oParameterA pointer to the returned parameter
virtual AAX_Result AAX_CEffectParameters::GetParameterIndex ( AAX_CParamID  iParameterID,
int32_t *  oControlIndex
) const
virtual
Although parameters are normally referenced by their AAX_CParamID, each parameter is also associated with a unique numeric index.
Parameters
[out]oControlIndexThe parameter's numeric index
virtual AAX_Result AAX_CEffectParameters::GetParameterIDFromIndex ( int32_t  iControlIndex,
AAX_IString *  oParameterIDString
) const
virtual
This method can be used to convert a parameter's unique numeric index to its AAX_CParamID
Parameters
[in]iControlIndexThe numeric index of the parameter that is being queried
[out]oParameterIDStringThe parameter's ID, written into an AAX_IString for safefy.
virtual AAX_Result AAX_CEffectParameters::GetParameterValueInfo ( AAX_CParamID  iParameterID,
int32_t  iSelector,
int32_t *  oValue
) const
virtual
This is a general purpose query that is specialized based on the value of iSelector. The currently supported selector values are described by AAX_EParameterValueInfoSelector . The meaning of oValue is dependent upon iSelector .
Parameters
[in]iSelectorThe selector of the parameter value to retrieve. See AAX_EParameterValueInfoSelector
[out]oValueThe value of the specified parameter
virtual AAX_Result AAX_CEffectParameters::GetParameterValueFromString ( AAX_CParamID  iParameterID,
double *  oValue,
const AAX_IString &  iValueString
) const
virtual
This method uses the queried parameter's display delegate and taper to convert a char* string into its corresponding value. The formatting of valueString must be supported by the parameter's display delegate in order for this call to succeed.
This method corresponds to CProcess::MapControlStringToVal() in the RTAS/TDM SDK
Parameters
[out]oValueThe value associated with valueString
[in]iValueStringThe formatted value string that will be converted into a value
virtual AAX_Result AAX_CEffectParameters::GetParameterStringFromValue ( AAX_CParamID  iParameterID,
double  iValue,
AAX_IString *  oValueString,
int32_t  iMaxLength
) const
virtual
This method uses the queried parameter's display delegate and taper to convert a normalized value into the corresponding char* value string for its real value.
This method corresponds to CProcess::MapControlValToString() in the RTAS/TDM SDK
Parameters
[in]iValueThe normalized value that will be converted to a formatted valueString
[out]oValueStringThe formatted value string associated with value
[in]iMaxLengthThe maximum length of valueString
virtual AAX_Result AAX_CEffectParameters::GetParameterValueString ( AAX_CParamID  iParameterID,
int32_t  iMaxLength
) const
virtual
This method uses the queried parameter's display delegate and taper to convert its current value into a corresponding char* value string.
Parameters
[out]oValueStringThe formatted value string associated with the parameter's current value
virtual AAX_Result AAX_CEffectParameters::GetParameterNormalizedValue ( AAX_CParamID  iParameterID,
double *  oValuePtr
) const
virtual
Parameters
[out]oValuePtrThe parameter's current value
virtual AAX_Result AAX_CEffectParameters::SetParameterNormalizedValue ( AAX_CParamID  iParameterID,
double  iValue
virtual
SetParameterNormalizedValue() is responsible for initiating any process that is required in order to update all of the parameter's controls (e.g. in the plug-in's GUI, on control surfaces, in automation lanes, etc.) In most cases, the parameter manager will handle this initiation step.
Parameters
[in]iParameterIDThe ID of the parameter that is being set
[in]iValueThe value to which the parameter should be set
virtual AAX_Result AAX_CEffectParameters::SetParameterNormalizedRelative ( AAX_CParamID  iParameterID,
double  iValue
virtual
This method is used in cases when a relative control value is more convenient, for example when updating a GUI control using a mouse wheel or the arrow keys. Note that the host may apply the parameter's step size prior to calling SetParameterNormalizedRelative() in order to determine the correct value for aValue.
SetParameterNormalizedRelative() can be used to incorporate "wrapping" behavior in a parameter's controls, if desired. If this behavior is not desired, then this method must properly account for overflow of the parameter's normalized value.
SetParameterNormalizedRelative() is responsible for initiating any process that is required in order to update all of the parameter's controls (e.g. in the plug-in's GUI, on control surfaces, in automation lanes, etc.) In most cases, the parameter manager will handle this initiation step.
See also UpdateParameterNormalizedRelative().
Todo:
REMOVE THIS METHOD (?)
Parameters
[in]iValueThe change in value that should be applied to the parameter
Todo:
NOT CURRENTLY CALLED FROM THE HOST. USEFUL FOR INTERNAL USE ONLY?
virtual AAX_Result AAX_CEffectParameters::TouchParameter ( AAX_CParamID  iParameterID)
virtual
This method is called by the Parameter Manager to prime a parameter for receiving new automation data. When an automatable parameter is touched by a control, it will reject input from other controls until it is released.
Note
You should never need to override this method when using AAX_CEffectParameters.
Parameters
[in]iParameterIDThe parameter that is being touched
virtual AAX_Result AAX_CEffectParameters::ReleaseParameter ( AAX_CParamID  iParameterID)
virtual
This method is called by the Parameter Manager to release a parameter so that any control may send updates to the parameter.
Note
Parameters
[in]iParameterIDThe parameter that is being released
virtual AAX_Result AAX_CEffectParameters::UpdateParameterTouch ( AAX_CParamID  iParameterID,
virtual
Note
This method should be overriden when dealing with linked parameters. Do NOT use this method to keep track of touch states. Use the automation delegate for that.
Parameters
[in]iParameterIDThe parameter that is changing touch states.
[in]iTouchStateThe touch state of the parameter.
virtual AAX_Result AAX_CEffectParameters::UpdateParameterNormalizedValue ( AAX_CParamID  iParameterID,
double  iValue,
virtual
Note
Do not call this method from the plug-in. This method should be called by the host only. To set parameter values from within the plug-in, use the AAX_IParameter interface.
Todo:
FLAGGED FOR CONSIDERATION OF REVISION
Parameters
[in]iValueThe parameter's current value, to which its internal state must be updated
[in]iSourceThe source of the update
virtual AAX_Result AAX_CEffectParameters::UpdateParameterNormalizedRelative ( AAX_CParamID  iParameterID,
double  iValue
virtual
Deprecated:
This is not called from the host. It may still be useful for internal calls within the plug-in, though it should only ever be used to update non-automatable parameters. Automatable parameters should always be updated through the AAX_IParameter interface, which will ensure proper coordination with other automation clients.
UpdateParameterNormalizedRelative() can be used to incorporate "wraparound" behavior in a parameter's controls, if desired. If this behavior is not desired, then this method must properly account for overflow of the parameter's normalized value.
See Also
Parameters
[in]iValueThe difference between the parameter's current value and its previous value (normalized). The parameter's state must be updated to reflect this difference.
virtual AAX_Result AAX_CEffectParameters::GenerateCoefficients ( void  )
virtual
This method is responsible for updating the coefficient packets associated with all parameters whose states have changed since the last call to GenerateCoefficients(). The host may call this method once for every parameter update, or it may "batch" parameter updates such that changes for several parameters are all handled by a single call to GenerateCoefficients().
For more information on tracking parameters' statuses using the AAX_CPacketDispatcher, helper class, see AAX_CPacketDispatcher::SetDirty().
Note
virtual AAX_Result AAX_CEffectParameters::ResetFieldData ( AAX_CFieldIndex  iFieldIndex,
void *  oData,
uint32_t  iDataSize
) const
virtual
This method is called sequentially for all private data fields on Effect initialization and during any "reset" event, such as priming for a non-real-time render. This method is called before the algorithm's optional initialization callback, and the initialized private data will be available within that callback via its context block.
See Also
Algorithm initialization.
Parameters
[in]iFieldIndexThe index of the field that is being initialized
[out]oDataThe pre-allocated block of data that should be initialized
[in]iDataSizeThe size of the data block, in bytes
Reimplemented in AAX_CInstrumentParameters.
virtual AAX_Result AAX_CEffectParameters::GetNumberOfChunks ( int32_t *  oNumChunks) const
virtual
Parameters
[out]oNumChunksThe number of distinct chunks used by this plug-in
virtual AAX_Result AAX_CEffectParameters::GetChunkIDFromIndex ( int32_t  iIndex,
AAX_CTypeID *  oChunkID
) const
virtual
Parameters
[in]iIndexIndex of the queried chunk
[out]oChunkIDID of the queried chunk
virtual AAX_Result AAX_CEffectParameters::GetChunkSize ( AAX_CTypeID  iChunkID,
uint32_t *  oSize
) const
virtual
If chunkID is one of the plug-in's custom chunks, initialize *size to the size of the chunk's data in bytes.
This method is invoked every time a chunk is saved, therefore it is possible to have dynamically sized chunks. However, note that each call to GetChunkSize() will correspond to a following call to GetChunk(). The chunk provided in GetChunk() must have the same size as the size provided by GetChunkSize().
In AAX, the value provided by GetChunkSize() should NOT include the size of the chunk header. The value should ONLY reflect the size of the chunk's data.
Parameters
[in]iChunkIDID of the queried chunk
[out]oSizeThe chunk's size in bytes
virtual AAX_Result AAX_CEffectParameters::GetChunk ( AAX_CTypeID  iChunkID,
AAX_SPlugInChunk *  oChunk
) const
virtual
By calling this method, the host is requesting information about the current state of the plug-in. The following chunk fields should be explicitly populated in this method. Other fields will be populated by the host.
Parameters
[in]iChunkIDID of the chunk that should be provided
[out]oChunkA preallocated block of memory that should be populated with the chunk's data.
virtual AAX_Result AAX_CEffectParameters::SetChunk ( AAX_CTypeID  iChunkID,
const AAX_SPlugInChunk *  iChunk
virtual
By calling this method, the host is attempting to update the plug-in's current state to match the data stored in a chunk. The plug-in should initialize itself to this new state by calling SetParameterNormalizedValue() for each of the relevant parameters.
Parameters
[in]iChunkIDID of the chunk that is being set
[in]iChunkThe chunk
virtual AAX_Result AAX_CEffectParameters::CompareActiveChunk ( const AAX_SPlugInChunk *  iChunkP,
AAX_CBoolean *  oIsEqual
) const
virtual
In Pro Tools, this method will only be called if a prior call to GetNumberOfChanges() has indicated that the plug-in's state has changed. If the plug-in's current settings are different from the settings in aChunkP then the plug-in's Compare Light will be illuminated in the plug-in header, allowing users to toggle between the plug-in's custom state and its saved state.
Parameters
[in]iChunkPThe chunk that is to be tested
[out]oIsEqualTrue if the chunk represents equivalent settings when compared with the plug-in's current state. False if the chunk represents
virtual AAX_Result AAX_CEffectParameters::GetNumberOfChanges ( int32_t *  oNumChanges) const
virtual
This method is polled regularly by the host, and can additionally be triggered by some events such as mouse clicks. When the number provided by this method changes, the host subsequently calls CompareActiveChunk() to determine if the plug-in's Compare light should be activated.
The value provided by this method should increment with each call to UpdateParameterNormalizedValue()
Parameters
[out]oNumChangesMust be set to indicate the number of parameter changes that have occurred since plug-in initialization.Chunk 8
virtual AAX_Result AAX_CEffectParameters::TimerWakeup ( )
virtual
This method is called from the host using a non-main thread. In general, it should be driven at approximately one call per 30 ms. However, the wakeup is not guaranteed to be called at any regular interval - for example, it could be held off by a high real-time processing load - and there is no host contract regarding maximum latency between wakeup calls.
This wakeup thread runs continuously and cannot be armed/disarmed or by the plug-in.
virtual AAX_Result AAX_CEffectParameters::GetCurveData ( AAX_CTypeID  iCurveType,
const float *  iValues,
float *  oValues
) const
virtual
This method is used by the host to generate EQ and Dynamics curves. Given a set of input values, e.g. frequencies in Hz, this method should generate a corresponding set of output values, e.g. dB gain at each frequency. The semantics of these input and output values are dictated by iCurveType.
Plug-ins may also define custom curve type IDs to use this method internally. For example, the plug-in's GUI could use this method to request curve data in an arbitrary format.
Note
oValues must be allocated by caller with the same size as iValues (iNumValues).
Parameters
[in]iCurveTypeOne of AAX_ECurveType
[in]iValuesAn array of input values
[in]iNumValuesThe size of iValues
[out]oValuesAn array of ouptut values
Returns
This method should return AAX_ERROR_UNIMPLEMENTED if the plug-in does not support curve data.
virtual AAX_Result AAX_CEffectParameters::GetCustomData ( AAX_CTypeID  iDataBlockID,
uint32_t  iDataSize,
void *  oData,
uint32_t *  oDataWritten
) const
virtual
Parameters
[in]iDataBlockIDIdentifier for the requested block of custom data
[in]iDataSizeSize of provided buffer, in bytes
[out]oDataPointer to an allocated buffer. Data will be written here.
[out]oDataWrittenThe number of bytes actually written
virtual AAX_Result AAX_CEffectParameters::SetCustomData ( AAX_CTypeID  iDataBlockID,
uint32_t  iDataSize,
const void *  iData
virtual
Parameters
[in]iDataBlockIDIdentifier for the provided block of custom data
[in]iDataPointer to the data buffer
virtual AAX_Result AAX_CEffectParameters::DoMIDITransfers ( )
inlinevirtual
Call AAX_IController::GetNextMIDIPacket() from within this method to retrieve and process MIDI packets directly within the Effect's data model. MIDI data will also be delivered to the Effect algorithm.
This method is called regularly by the host, similarly to AAX_IEffectParameters::TimerWakeup()
References AAX_SUCCESS.
virtual AAX_Result AAX_CEffectParameters::UpdateMIDINodes ( AAX_CFieldIndex  iFieldIndex,
AAX_CMidiPacket &  iPacket
virtual
This method is called by the host for each pending MIDI packet for MIDI nodes in algorithm context structure. Overwrite this method in Plug-In's EffectParameter class if you want to receive MIDI data packets directly in the data model. MIDI data will also be delivered to the Effect algorithm.
Note
This method called by the host for the nodes described with AAX_IComponentDescriptor::AddMIDINode()
To use this method plug-in should register some MIDI nodes in Describe
Parameters
[in]iFieldIndexMIDI node field index in algorithm context structure
[in]iPacketThe incoming MIDI packet for the node
Implements AAX_IACFEffectParameters_V2.
virtual AAX_Result AAX_CEffectParameters::UpdateControlMIDINodes ( AAX_CTypeID  nodeID,
virtual
This method is called by the host for each pending MIDI packets for Control MIDI nodes. Overwrite this method in Plug-In's EffectParameter class if you want to receive MIDI data packets directly in the data model. MIDI data will NOT be delivered to the Effect algorithm.
Note
This method called for Host only nodes which were described with AAX_IEffectDescriptor::AddControlMIDINode()
Parameters
[in]nodeIDIdentifier for the MIDI node
virtual AAX_Result AAX_CEffectParameters::RenderAudio_Hybrid ( AAX_SHybridRenderInfo *  ioRenderInfo)
virtual
This method is called from the host to render audio for the hybrid piece of the algorithm.
Note
To use this method plug-in should register some hybrid inputs and ouputs in "Describe"
AAX_IController* AAX_CEffectParameters::Controller ( )
const AAX_IController* AAX_CEffectParameters::Controller ( ) const
AAX_ITransport* AAX_CEffectParameters::Transport ( )
const AAX_ITransport* AAX_CEffectParameters::Transport ( ) const
AAX_IAutomationDelegate* AAX_CEffectParameters::AutomationDelegate ( )
const AAX_IAutomationDelegate* AAX_CEffectParameters::AutomationDelegate ( ) const
AAX_Result AAX_CEffectParameters::SetTaperDelegate ( AAX_CParamID  iParameterID,
AAX_ITaperDelegateBase &  iTaperDelegate,
bool  iPreserveValue
protected
AAX_Result AAX_CEffectParameters::SetDisplayDelegate ( AAX_CParamID  iParameterID,
AAX_IDisplayDelegateBase &  iDisplayDelegate
protected
bool AAX_CEffectParameters::IsParameterTouched ( AAX_CParamID  iParameterID) const
protected
bool AAX_CEffectParameters::IsParameterLinkReady ( AAX_CParamID  inParameterID,
) const
protected
virtual AAX_Result AAX_CEffectParameters::EffectInit ( void  )
inlineprotectedvirtual
Override to add parameters, packets, meters, and to do any other custom initialization.
Add custom parameters:
Register packets:
void AAX_CEffectParameters::FilterParameterIDOnSave ( AAX_CParamID  controlID)
protected
Allows specific parameters to filtered out of the default AAX_CEffectParameters "Save Settings" functionality. This call is automatically invoked on the Master Bypass control when specified by the DefineMasterBypassControlIndex() call.
Parameters
[in]controlIDThe ID of the parameter that should be removed from the default chunk
void AAX_CEffectParameters::BuildChunkData ( void  ) const
protected
Member Data Documentation
int32_t AAX_CEffectParameters::mNumPlugInChanges
protected
int32_t AAX_CEffectParameters::mChunkSize
mutableprotected
AAX_CChunkDataParser AAX_CEffectParameters::mChunkParser
mutableprotected
int32_t AAX_CEffectParameters::mNumChunkedParameters
protected
AAX_CBoolean AAX_CEffectParameters::mClipped
protected
AAX_CPacketDispatcher AAX_CEffectParameters::mPacketDispatcher
protected
AAX_CParameterManager AAX_CEffectParameters::mParameterManager
protected
std::set<std::string> AAX_CEffectParameters::mFilteredParameters
protected
