AAX SDK  2.1.1
AAX_IParameter Class Referenceabstract
#include <AAX_IParameter.h>
Inheritance diagram for AAX_IParameter:
Inheritance graph
[legend]
Description
The base interface for all normalizable plug-in parameters.
:Internal to the AAX SDK:
This class is an outside interface for an arbitrarily typed parameter. The subclasses of this generic interface hold the parameter's state and conversion functionality.
Note
This class is not part of the AAX ABI and must not be passed between the plug-in and the host. Version checking is recommended when passing references to this interface between plug-in modules (e.g. between the data model and the GUI)
Public Member Functions
virtual ~AAX_IParameter ()
 Virtual destructor. More...
virtual void SetType (AAX_EParameterType iControlType)=0
 Sets the type of this parameter. More...
virtual AAX_EParameterType GetType () const =0
 Returns the type of this parameter as an AAX_EParameterType. More...
virtual void SetOrientation (AAX_EParameterOrientation iOrientation)=0
 Sets the orientation of this parameter. More...
virtual AAX_EParameterOrientation GetOrientation () const =0
 Returns the orientation of this parameter. More...
virtual void SetTaperDelegate (AAX_ITaperDelegateBase &iTaperDelegate, bool iPreserveValue)=0
virtual void SetDisplayDelegate (AAX_IDisplayDelegateBase &iDisplayDelegate)=0
Identification methods
virtual AAX_CParamID Identifier () const =0
 Returns the parameter's unique identifier. More...
virtual void SetName (const AAX_CString &name)=0
 Sets the parameter's display name. More...
virtual const AAX_CString & Name () const =0
 Returns the parameter's display name. More...
virtual void AddShortenedName (const AAX_CString &name)=0
 Sets the parameter's shortened display name. More...
virtual const AAX_CString & ShortenedName (int32_t iNumCharacters) const =0
 Returns the parameter's shortened display name. More...
virtual void ClearShortenedNames ()=0
 Clears the internal list of shortened display names. More...
Automation methods
virtual bool Automatable () const =0
 Returns true if the parameter is automatable, false if it is not. More...
virtual void SetAutomationDelegate (AAX_IAutomationDelegate *iAutomationDelegate)=0
 Sets the automation delegate (if one is required) More...
virtual void Touch ()=0
 Signals the automation system that a control has been touched. More...
virtual void Release ()=0
 Signals the automation system that a control has been released. More...
Taper methods
virtual void SetNormalizedValue (double newNormalizedValue)=0
 Sets a parameter value using it's normalized representation. More...
virtual double GetNormalizedValue () const =0
 Returns the normalized representation of the parameter's current real value. More...
virtual void SetNormalizedDefaultValue (double normalizedDefault)=0
 Sets the parameter's default value using its normalized representation. More...
virtual double GetNormalizedDefaultValue () const =0
 Returns the normalized representation of the parameter's real default value. More...
virtual void SetToDefaultValue ()=0
 Restores the state of this parameter to its default value. More...
virtual void SetNumberOfSteps (uint32_t numSteps)=0
 Sets the number of discrete steps for this parameter. More...
virtual uint32_t GetNumberOfSteps () const =0
 Returns the number of discrete steps used by the parameter. More...
virtual uint32_t GetStepValue () const =0
 Returns the current step for the current value of the parameter. More...
virtual void SetStepValue (uint32_t iStep)=0
Display methods
This functionality is most often used by GUIs, but can also be useful for state serialization.
virtual bool GetValueString (AAX_CString *valueString) const =0
 Serializes the parameter value into a string. More...
virtual bool GetValueString (int32_t iMaxNumChars, AAX_CString *valueString) const =0
 Serializes the parameter value into a string, size hint included. More...
virtual bool GetNormalizedValueFromString (const AAX_CString &valueString, double *normalizedValue) const =0
 Converts a given string to a normalized parameter value. More...
virtual bool GetStringFromNormalizedValue (double normalizedValue, AAX_CString &valueString) const =0
 Converts a normalized parameter value to a string representing the corresponding real value. More...
virtual bool GetStringFromNormalizedValue (double normalizedValue, int32_t iMaxNumChars, AAX_CString &valueString) const =0
 Converts a normalized parameter value to a string representing the corresponding real, size hint included. value. More...
virtual bool SetValueFromString (const AAX_CString &newValueString)=0
 Converts a string to a real parameter value and sets the parameter to this value. More...
Typed accessors
virtual bool GetValueAsBool (bool *value) const =0
 Retrieves the parameter's value as a bool. More...
virtual bool GetValueAsInt32 (int32_t *value) const =0
 Retrieves the parameter's value as an int32_t. More...
virtual bool GetValueAsFloat (float *value) const =0
 Retrieves the parameter's value as a float. More...
virtual bool GetValueAsDouble (double *value) const =0
 Retrieves the parameter's value as a double. More...
virtual bool GetValueAsString (AAX_IString *value) const =0
 Retrieves the parameter's value as a string. More...
virtual bool SetValueWithBool (bool value)=0
 Sets the parameter's value as a bool. More...
virtual bool SetValueWithInt32 (int32_t value)=0
 Sets the parameter's value as an int32_t. More...
virtual bool SetValueWithFloat (float value)=0
 Sets the parameter's value as a float. More...
virtual bool SetValueWithDouble (double value)=0
 Sets the parameter's value as a double. More...
virtual bool SetValueWithString (const AAX_IString &value)=0
 Sets the parameter's value as a string. More...
Host interface methods
virtual void UpdateNormalizedValue (double newNormalizedValue)=0
 Sets the parameter's state given a normalized value. More...
Constructor & Destructor Documentation
virtual AAX_IParameter::~AAX_IParameter ( )
inlinevirtual
Virtual destructor.
Note
This destructor MUST be virtual to prevent memory leaks.
Member Function Documentation
virtual AAX_CParamID AAX_IParameter::Identifier ( ) const
pure virtual
This unique ID is used by the Parameter Manager and by outside applications to uniquely identify and target control messages. This value may not be changed after the parameter has been constructed.
Implemented in AAX_CParameter< T >.
virtual void AAX_IParameter::SetName ( const AAX_CString &  name)
pure virtual
This name is used for display only, it is not used for indexing or identifying the parameter This name may be changed after the parameter has been created, but display name changes may not be recognized by all AAX hosts.
Parameters
[in]nameDisplay name that will be assigned to the parameter
virtual const AAX_CString& AAX_IParameter::Name ( ) const
pure virtual
Note
This method returns a const reference in order to prevent a string copy. Do not cast away the const to change this value.
virtual void AAX_IParameter::AddShortenedName ( const AAX_CString &  name)
pure virtual
This name is used for display only, it is not used for indexing or identifying the parameter These names show up when the host asks for shorter length parameter names for display on Control Surfaces or other string length constrained situations.
Parameters
[in]nameShortened display names that will be assigned to the parameter
virtual const AAX_CString& AAX_IParameter::ShortenedName ( int32_t  iNumCharacters) const
pure virtual
Note
virtual void AAX_IParameter::ClearShortenedNames ( )
pure virtual
virtual bool AAX_IParameter::Automatable ( ) const
pure virtual
Note
Subclasses that return true in this method must support host-based automation.
virtual void AAX_IParameter::SetAutomationDelegate ( AAX_IAutomationDelegate *  iAutomationDelegate)
pure virtual
Parameters
[in]iAutomationDelegateA reference to the parameter manager's automation delegate interface
virtual void AAX_IParameter::Touch ( )
pure virtual
Call this method in response to GUI events that begin editing, such as a mouse down. After this method has been called you are free to call SetNormalizedValue() as much as you need, e.g. in order to respond to subsequent mouse moved events. Call Release() to free the parameter for updates from other controls.
virtual void AAX_IParameter::Release ( )
pure virtual
Call this method in response to GUI events that complete editing, such as a mouse up. Once this method has been called you should not call SetNormalizedValue() again until after the next call to Touch().
virtual void AAX_IParameter::SetNormalizedValue ( double  newNormalizedValue)
pure virtual
For more information regarding normalized values, see Parameter Manager
Parameters
[in]newNormalizedValueNew value (normalized) to which the parameter will be set
virtual double AAX_IParameter::GetNormalizedValue ( ) const
pure virtual
virtual void AAX_IParameter::SetNormalizedDefaultValue ( double  normalizedDefault)
pure virtual
virtual double AAX_IParameter::GetNormalizedDefaultValue ( ) const
pure virtual
virtual void AAX_IParameter::SetToDefaultValue ( )
pure virtual
virtual void AAX_IParameter::SetNumberOfSteps ( uint32_t  numSteps)
pure virtual
Stepped parameter values are useful for discrete parameters and for "jumping" events such as mouse wheels, page up/down, etc. The parameter's step size is used to specify the coarseness of those changes.
Note
numSteps MUST be greater than zero. All other values may be considered an error by the host.
Parameters
[in]numStepsThe number of steps that the parameter will use
virtual uint32_t AAX_IParameter::GetNumberOfSteps ( ) const
pure virtual
See SetNumberOfSteps() for more information about parameter steps.
virtual uint32_t AAX_IParameter::GetStepValue ( ) const
pure virtual
virtual void AAX_IParameter::SetStepValue ( uint32_t  iStep)
pure virtual
virtual bool AAX_IParameter::GetValueString ( AAX_CString *  valueString) const
pure virtual
Parameters
[out]valueStringA string representing the parameter's real value
Return values
trueThe string conversion was successful
falseThe string conversion was unsuccessful
virtual bool AAX_IParameter::GetValueString ( int32_t  iMaxNumChars,
) const
pure virtual
Parameters
[in]iMaxNumCharsA size hint for the size of the string being requested. Useful for control surfaces and other limited area text fields. (make sure that size of desired string also has room for null termination)
Return values
virtual bool AAX_IParameter::GetNormalizedValueFromString ( const AAX_CString &  valueString,
double *  normalizedValue
) const
pure virtual
Parameters
[in]valueStringA string representing a possible real value for the parameter
[out]normalizedValueThe normalized parameter value associated with valueString
Return values
virtual bool AAX_IParameter::GetStringFromNormalizedValue ( double  normalizedValue,
) const
pure virtual
Parameters
[in]normalizedValueA normalized parameter value
[out]valueStringA string representing the parameter value associated with normalizedValue
Return values
) const
pure virtual
Parameters
Return values
virtual bool AAX_IParameter::SetValueFromString ( const AAX_CString &  newValueString)
pure virtual
Parameters
[in]newValueStringA string representing the parameter's new real value
Return values
virtual bool AAX_IParameter::GetValueAsBool ( bool *  value) const
pure virtual
Parameters
[out]valueThe parameter's real value. Set only if conversion is successful.
Return values
trueThe conversion to bool was successful
falseThe conversion to bool was unsuccessful
Implemented in AAX_CParameter< T >, and AAX_CParameter< T >.
virtual bool AAX_IParameter::GetValueAsInt32 ( int32_t *  value) const
pure virtual
Parameters
Return values
trueThe conversion to int32_t was successful
falseThe conversion to int32_t was unsuccessful
virtual bool AAX_IParameter::GetValueAsFloat ( float *  value) const
pure virtual
Parameters
Return values
trueThe conversion to float was successful
falseThe conversion to float was unsuccessful
virtual bool AAX_IParameter::GetValueAsDouble ( double *  value) const
pure virtual
Parameters
Return values
trueThe conversion to double was successful
falseThe conversion to double was unsuccessful
virtual bool AAX_IParameter::GetValueAsString ( AAX_IString *  value) const
pure virtual
Parameters
Return values
trueThe conversion to string was successful
falseThe conversion to string was unsuccessful
virtual bool AAX_IParameter::SetValueWithBool ( bool  value)
pure virtual
Parameters
Return values
trueThe conversion from bool was successful
falseThe conversion from bool was unsuccessful
virtual bool AAX_IParameter::SetValueWithInt32 ( int32_t  value)
pure virtual
Parameters
Return values
trueThe conversion from int32_t was successful
falseThe conversion from int32_t was unsuccessful
virtual bool AAX_IParameter::SetValueWithFloat ( float  value)
pure virtual
Parameters
Return values
trueThe conversion from float was successful
falseThe conversion from float was unsuccessful
virtual bool AAX_IParameter::SetValueWithDouble ( double  value)
pure virtual
Parameters
Return values
trueThe conversion from double was successful
falseThe conversion from double was unsuccessful
virtual bool AAX_IParameter::SetValueWithString ( const AAX_IString &  value)
pure virtual
Parameters
Return values
trueThe conversion from string was successful
falseThe conversion from string was unsuccessful
virtual void AAX_IParameter::SetType ( AAX_EParameterType  iControlType)
pure virtual
See GetType for use cases
Parameters
[in]iControlTypeThe parameter's new type as an AAX_EParameterType
virtual AAX_EParameterType AAX_IParameter::GetType ( ) const
pure virtual
Todo:
Document use cases for control type
virtual void AAX_IParameter::SetOrientation ( AAX_EParameterOrientation  iOrientation)
pure virtual
Parameters
[in]iOrientationThe parameter's new orientation
virtual AAX_EParameterOrientation AAX_IParameter::GetOrientation ( ) const
pure virtual
virtual void AAX_IParameter::SetTaperDelegate ( AAX_ITaperDelegateBase &  iTaperDelegate,
bool  iPreserveValue
pure virtual
virtual void AAX_IParameter::SetDisplayDelegate ( AAX_IDisplayDelegateBase &  iDisplayDelegate)
pure virtual
virtual void AAX_IParameter::UpdateNormalizedValue ( double  newNormalizedValue)
pure virtual
This is the second half of the parameter setting operation that is initiated with a call to SetValue(). Parameters should not be set directly using this method; instead, use SetValue().
Parameters
[in]newNormalizedValueNormalized value that will be used to set the parameter's new state
