AAX SDK  2.1.1
AAX_IAutomationDelegate Class Referenceabstract
#include <AAX_IAutomationDelegate.h>
Inheritance diagram for AAX_IAutomationDelegate:
Inheritance graph
[legend]
Description
Interface allowing an AAX plug-in to interact with the host's event system.
:Implemented by the AAX Host:
This delegate provides a means of interacting with the host's event system in order to ensure that events such as parameter updates are properly arbitrated and broadcast to all listeners. The automation delegate is used regardless of whether an individual parameter is "automatable" or "automation-enabled".
A parameter must be registered with the automation delegate in order for updates to the parameter's control in the plug-in's GUI or other controller (control surface, etc.) to be successfully processed by the host and sent to the AAX_IEffectParameters object.
The parameter identifiers used by this interface correspond to the control IDs used to identify parameters in the Parameter Mananger.
Public Member Functions
virtual ~AAX_IAutomationDelegate ()
virtual AAX_Result RegisterParameter (AAX_CParamID iParameterID)=0
virtual AAX_Result UnregisterParameter (AAX_CParamID iParameterID)=0
virtual AAX_Result PostSetValueRequest (AAX_CParamID iParameterID, double normalizedValue) const =0
virtual AAX_Result PostCurrentValue (AAX_CParamID iParameterID, double normalizedValue) const =0
virtual AAX_Result PostTouchRequest (AAX_CParamID iParameterID)=0
virtual AAX_Result PostReleaseRequest (AAX_CParamID iParameterID)=0
virtual AAX_Result GetTouchState (AAX_CParamID iParameterID, AAX_CBoolean *oTouched)=0
Constructor & Destructor Documentation
virtual AAX_IAutomationDelegate::~AAX_IAutomationDelegate ( )
inlinevirtual
Member Function Documentation
virtual AAX_Result AAX_IAutomationDelegate::RegisterParameter ( AAX_CParamID  iParameterID)
pure virtual
Register a control with the automation system using a char* based control identifier.
The automation delegate owns a list of the IDs of all of the parameters that have been registered with it. This list is used to set up listeners for all of the registered parameters such that the automation delegate may update the plug-in when the state of any of the registered parameters have been modified.
See Also
AAX_IAutomationDelegate::UnregisterParameter()
Parameters
[in]iParameterIDParameter ID that is being registered
Implemented in AAX_VAutomationDelegate.
Referenced by AAX_CParameter< T >::SetAutomationDelegate().
Here is the caller graph for this function:
virtual AAX_Result AAX_IAutomationDelegate::UnregisterParameter ( AAX_CParamID  iParameterID)
pure virtual
Unregister a control with the automation system using a char* based control identifier.
Note
All registered controls should be unregistered or the system might leak.
See Also
AAX_IAutomationDelegate::RegisterParameter()
Parameters
virtual AAX_Result AAX_IAutomationDelegate::PostSetValueRequest ( AAX_CParamID  iParameterID,
) const
pure virtual
Submits a request for the given parameter's value to be changed.
Parameters
[in]iParameterIDID of the parameter for which a change is requested
[in]normalizedValueThe requested new parameter value, formatted as a double and normalized to [0 1]
virtual AAX_Result AAX_IAutomationDelegate::PostCurrentValue ( AAX_CParamID  iParameterID,
) const
pure virtual
Notifies listeners that a parameter's value has changed.
Parameters
[in]iParameterIDID of the parameter that has been updated
[in]normalizedValueThe current parameter value, formatted as a double and normalized to [0 1]
virtual AAX_Result AAX_IAutomationDelegate::PostTouchRequest ( AAX_CParamID  iParameterID)
pure virtual
Requests that the given parameter be "touched", i.e. locked for updates by the current client
Parameters
[in]iParameterIDID of the parameter that will be touched
virtual AAX_Result AAX_IAutomationDelegate::PostReleaseRequest ( AAX_CParamID  iParameterID)
pure virtual
Requests that the given parameter be "released", i.e. available for updates from any client
Parameters
[in]iParameterIDID of the parameter that will be released
virtual AAX_Result AAX_IAutomationDelegate::GetTouchState ( AAX_CParamID  iParameterID,
AAX_CBoolean *  oTouched
pure virtual
Gets the current touched state of a parameter.
Parameters
[in]iParameterIDID of the parameter that is being queried
[out]oTouchedThe current touch state of the parameter
