AAX SDK  2.1.1
List of all members | Public Member Functions | Protected Attributes
AAX_CParameterManager Class Reference
#include <AAX_CParameterManager.h>
Collaboration diagram for AAX_CParameterManager:
Collaboration graph
[legend]
Description
A container object for plug-in parameters.
This implementation uses a STL vector to store a plug-in's set of parameters. This class contains a real implementation of the Parameter Manager (as opposed to a proxy.)
For more information, see Parameter Manager.
Todo:
Should the Parameter Manager return error codes?
 AAX_CParameterManager ()
 ~AAX_CParameterManager ()
void Initialize (AAX_IAutomationDelegate *iAutomationDelegateUnknown)
 Initialize the parameter manager. More...
int32_t NumParameters () const
 Returns the number of parameters in this instance of the parameter manager. More...
void RemoveParameterByID (AAX_CParamID identifier)
 Removes a parameter from the manager. More...
void RemoveAllParameters ()
 Removes all parameters from the manager. More...
AAX_IParameter * GetParameterByID (AAX_CParamID identifier)
 Given a parameter ID, retrieves a reference to the requested parameter. More...
const AAX_IParameter * GetParameterByID (AAX_CParamID identifier) const
 Given a parameter ID, retrieves a const reference to the requested parameter. More...
AAX_IParameter * GetParameter (int32_t index)
 Given a parameter index, retrieves a reference to the requested parameter. More...
const AAX_IParameter * GetParameter (int32_t index) const
 Given a parameter index, retrieves a const reference to the requested parameter. More...
int32_t ControlIndexFromID (AAX_CParamID identifier) const
void AddParameter (AAX_IParameter *param)
void RemoveParameter (AAX_IParameter *param)
AAX_IAutomationDelegate * mAutomationDelegate
std::vector< AAX_IParameter * > mParameters
std::map< std::string,
AAX_IParameter * >
mParametersMap
Constructor & Destructor Documentation
AAX_CParameterManager::AAX_CParameterManager ( )
AAX_CParameterManager::~AAX_CParameterManager ( )
Member Function Documentation
void AAX_CParameterManager::Initialize ( AAX_IAutomationDelegate *  iAutomationDelegateUnknown)
Called when plug-in instance is first instantiated. This method will initialize the plug-in's automation delegate, among other set-up tasks.
Parameters
[in]iAutomationDelegateUnknownA reference to the plug-in's AAX_IAutomationDelegate interface
int32_t AAX_CParameterManager::NumParameters ( ) const
void AAX_CParameterManager::RemoveParameterByID ( AAX_CParamID  identifier)
Todo:
Should this method return success/failure code?
Parameters
[in]identifierID of the parameter that will be removed
void AAX_CParameterManager::RemoveAllParameters ( )
Todo:
AAX_IParameter* AAX_CParameterManager::GetParameterByID ( AAX_CParamID  identifier)
Parameters
[in]identifierID of the parameter that will be retrieved
const AAX_IParameter* AAX_CParameterManager::GetParameterByID ( AAX_CParamID  identifier) const
Parameters
AAX_IParameter* AAX_CParameterManager::GetParameter ( int32_t  index)
Parameter indices are incremented in the order that parameters are added to the manager. See AddParameter().
Parameters
[in]indexIndex of the parameter that will be retrieved
const AAX_IParameter* AAX_CParameterManager::GetParameter ( int32_t  index) const
Parameters
int32_t AAX_CParameterManager::ControlIndexFromID ( AAX_CParamID  identifier) const
Given a parameter ID, retrieves the index for the specified parameter
Todo:
This should be deprecated. Historically used for mouse-over GUI events.
Parameters
void AAX_CParameterManager::AddParameter ( AAX_IParameter *  param)
Adds a parameter to the manager
Todo:
Parameters
[in]paramReference to the parameter that will be added
void AAX_CParameterManager::RemoveParameter ( AAX_IParameter *  param)
Removes a parameter to the manager
Todo:
Parameters
[in]paramReference to the parameter that will be removed
Member Data Documentation
AAX_IAutomationDelegate* AAX_CParameterManager::mAutomationDelegate
protected
std::vector<AAX_IParameter*> AAX_CParameterManager::mParameters
protected
std::map<std::string, AAX_IParameter*> AAX_CParameterManager::mParametersMap
protected
