AAX SDK  2.1.1
AAX_VAutomationDelegate Class Reference
#include <AAX_VAutomationDelegate.h>
Inheritance diagram for AAX_VAutomationDelegate:
Inheritance graph
[legend]
Collaboration diagram for AAX_VAutomationDelegate:
Collaboration graph
[legend]
Description
Version-managed concrete automation delegate class.
Public Member Functions
 AAX_VAutomationDelegate (IACFUnknown *pUnknown)
virtual ~AAX_VAutomationDelegate ()
IACFUnknown * GetUnknown () const
AAX_Result RegisterParameter (AAX_CParamID iParameterID)
AAX_Result UnregisterParameter (AAX_CParamID iParameterID)
AAX_Result PostSetValueRequest (AAX_CParamID iParameterID, double iNormalizedValue) const
AAX_Result PostCurrentValue (AAX_CParamID iParameterID, double iNormalizedValue) const
AAX_Result PostTouchRequest (AAX_CParamID iParameterID)
AAX_Result PostReleaseRequest (AAX_CParamID iParameterID)
AAX_Result GetTouchState (AAX_CParamID iParameterID, AAX_CBoolean *outTouched)
- Public Member Functions inherited from AAX_IAutomationDelegate
virtual ~AAX_IAutomationDelegate ()
Constructor & Destructor Documentation
AAX_VAutomationDelegate::AAX_VAutomationDelegate ( IACFUnknown *  pUnknown)
virtual AAX_VAutomationDelegate::~AAX_VAutomationDelegate ( )
virtual
Member Function Documentation
IACFUnknown* AAX_VAutomationDelegate::GetUnknown ( ) const
inline
AAX_Result AAX_VAutomationDelegate::RegisterParameter ( AAX_CParamID  iParameterID)
virtual
Register a control with the automation system using a char* based control identifier.
The automation delegate owns a list of the IDs of all of the parameters that have been registered with it. This list is used to set up listeners for all of the registered parameters such that the automation delegate may update the plug-in when the state of any of the registered parameters have been modified.
See Also
AAX_IAutomationDelegate::UnregisterParameter()
Parameters
[in]iParameterIDParameter ID that is being registered
Implements AAX_IAutomationDelegate.
AAX_Result AAX_VAutomationDelegate::UnregisterParameter ( AAX_CParamID  iParameterID)
virtual
Unregister a control with the automation system using a char* based control identifier.
Note
All registered controls should be unregistered or the system might leak.
See Also
AAX_IAutomationDelegate::RegisterParameter()
Parameters
AAX_Result AAX_VAutomationDelegate::PostSetValueRequest ( AAX_CParamID  iParameterID,
double  normalizedValue
) const
virtual
Submits a request for the given parameter's value to be changed.
Parameters
[in]iParameterIDID of the parameter for which a change is requested
[in]normalizedValueThe requested new parameter value, formatted as a double and normalized to [0 1]
AAX_Result AAX_VAutomationDelegate::PostCurrentValue ( AAX_CParamID  iParameterID,
) const
virtual
Notifies listeners that a parameter's value has changed.
Parameters
[in]iParameterIDID of the parameter that has been updated
[in]normalizedValueThe current parameter value, formatted as a double and normalized to [0 1]
AAX_Result AAX_VAutomationDelegate::PostTouchRequest ( AAX_CParamID  iParameterID)
virtual
Requests that the given parameter be "touched", i.e. locked for updates by the current client
Parameters
[in]iParameterIDID of the parameter that will be touched
AAX_Result AAX_VAutomationDelegate::PostReleaseRequest ( AAX_CParamID  iParameterID)
virtual
Requests that the given parameter be "released", i.e. available for updates from any client
Parameters
[in]iParameterIDID of the parameter that will be released
AAX_Result AAX_VAutomationDelegate::GetTouchState ( AAX_CParamID  iParameterID,
AAX_CBoolean *  oTouched
virtual
Gets the current touched state of a parameter.
Parameters
[in]iParameterIDID of the parameter that is being queried
[out]oTouchedThe current touch state of the parameter
