AAX SDK  2.1.1
Macros | Typedefs | Enumerations | Functions
AAX_Enums.h File Reference
#include <stdint.h>
Go to the source code of this file.
Description
Utility functions for byte-swapping. Used by AAX_CChunkDataParser.
Macros
#define AAX_INT32_MIN   (-2147483647 - 1) /** minimum signed 32 bit value */
#define AAX_INT32_MAX   2147483647 /** maximum signed 32 bit value */
#define AAX_UINT32_MIN   0U /** minimum unsigned 32 bit value */
#define AAX_UINT32_MAX   4294967295U /** maximum unsigned 32 bit value */
#define AAX_INT16_MIN   (-32767 - 1) /** minimum signed 16 bit value */
#define AAX_INT16_MAX   32767 /** maximum signed 16 bit value */
#define AAX_UINT16_MIN   0U /** minimum unsigned 16 bit value */
#define AAX_UINT16_MAX   65535U /** maximum unsigned 16 bit value */
#define AAX_ENUM_SIZE_CHECK(x)   extern int __enumSizeCheck[ 2*(sizeof(uint32_t)==sizeof(x)) - 1]
 Macro to ensure enum type consistency across binaries. More...
#define AAX_STEM_FORMAT(aIndex, aChannelCount)   ( static_cast<uint32_t>( ( static_cast<uint16_t>(aIndex) << 16 ) | ( (aChannelCount >= AAX_UINT16_MIN) && (aChannelCount <= 0xFFFF) ? aChannelCount & 0xFFFF : 0x0000 ) ) )
#define AAX_STEM_FORMAT_CHANNEL_COUNT(aStemFormat)   ( static_cast<uint16_t>( aStemFormat & 0xFFFF ) )
#define AAX_STEM_FORMAT_INDEX(aStemFormat)   ( static_cast<int16_t>( ( aStemFormat >> 16 ) & 0xFFFF ) )
Typedefs
typedef enum AAX_EParameterType AAX_EParameterType
 FIC stuff that I can't include without DAE library dependence. More...
typedef int32_t AAX_EParameterOrientation
 Typedef for a bitfield of AAX_EParameterOrientationBits values. More...
Enumerations
enum  AAX_EIconGUIType { AAX_eIconGUIType_Undefined = -1, AAX_eIconGUIType_GuitarRig = 0, AAX_eIconGUIType_Num }
enum  AAX_EHighlightColor {
  AAX_eHighlightColor_Red = 0, AAX_eHighlightColor_Blue = 1, AAX_eHighlightColor_Green = 2, AAX_eHighlightColor_Yellow = 3,
  AAX_eHighlightColor_Num
 Highlight color selector. More...
enum  AAX_ETracePriorityHost { AAX_eTracePriorityHost_None = 0, AAX_eTracePriorityHost_High = 0x08000000, AAX_eTracePriorityHost_Normal = 0x04000000, AAX_eTracePriorityHost_Low = 0x02000000 }
 Platform-specific tracing priorities. More...
enum  AAX_ETracePriorityDSP {
  AAX_eTracePriorityDSP_None = 0, AAX_eTracePriorityDSP_Assert, AAX_eTracePriorityDSP_High, AAX_eTracePriorityDSP_Normal,
  AAX_eTracePriorityDSP_Low
enum  AAX_EModifiers {
  AAX_eModifiers_None = 0, AAX_eModifiers_Shift = ( 1 << 0 ), AAX_eModifiers_Control = ( 1 << 1 ), AAX_eModifiers_Option = ( 1 << 2 ),
  AAX_eModifiers_Command = ( 1 << 3 ), AAX_eModifiers_SecondaryButton = ( 1 << 4 ), AAX_eModifiers_Alt = AAX_eModifiers_Option, AAX_eModifiers_Cntl = AAX_eModifiers_Command,
  AAX_eModifiers_WINKEY = AAX_eModifiers_Control
 Modifier key definitions used by AAX API. More...
enum  AAX_EAudioBufferLength {
  AAX_eAudioBufferLength_Undefined = -1, AAX_eAudioBufferLength_1 = 0, AAX_eAudioBufferLength_2 = 1, AAX_eAudioBufferLength_4 = 2,
  AAX_eAudioBufferLength_8 = 3, AAX_eAudioBufferLength_16 = 4, AAX_eAudioBufferLength_32 = 5, AAX_eAudioBufferLength_64 = 6,
  AAX_eAudioBufferLength_128 = 7, AAX_eAudioBufferLength_256 = 8, AAX_eAudioBufferLength_512 = 9, AAX_eAudioBufferLength_1024 = 10,
  AAX_eAudioBufferLength_Max = AAX_eAudioBufferLength_1024
 Generic buffer length definitions. More...
enum  AAX_EAudioBufferLengthDSP {
  AAX_eAudioBufferLengthDSP_Default = AAX_eAudioBufferLength_4, AAX_eAudioBufferLengthDSP_4 = AAX_eAudioBufferLength_4, AAX_eAudioBufferLengthDSP_16 = AAX_eAudioBufferLength_16, AAX_eAudioBufferLengthDSP_32 = AAX_eAudioBufferLength_32,
  AAX_eAudioBufferLengthDSP_64 = AAX_eAudioBufferLength_64, AAX_eAudioBufferLengthDSP_Max = AAX_eAudioBufferLengthDSP_64
 Currently supported processing buffer length definitions for AAX DSP hosts. More...
enum  AAE_EAudioBufferLengthNative { AAX_eAudioBufferLengthNative_Min = AAX_eAudioBufferLength_32, AAX_eAudioBufferLengthNative_Max = AAX_eAudioBufferLength_Max }
 Processing buffer length definitions for Native AAX hosts. More...
enum  AAX_EMaxAudioSuiteTracks { AAX_eMaxAudioSuiteTracks = 48 }
 The maximum number of tracks that an AAX host will process in a non-real-time context. More...
enum  AAX_EStemFormat {
  AAX_eStemFormat_Mono = AAX_STEM_FORMAT ( 0, 1 ), AAX_eStemFormat_Stereo = AAX_STEM_FORMAT ( 1, 2 ), AAX_eStemFormat_LCR = AAX_STEM_FORMAT ( 2, 3 ), AAX_eStemFormat_LCRS = AAX_STEM_FORMAT ( 3, 4 ),
  AAX_eStemFormat_Quad = AAX_STEM_FORMAT ( 4, 4 ), AAX_eStemFormat_5_0 = AAX_STEM_FORMAT ( 5, 5 ), AAX_eStemFormat_5_1 = AAX_STEM_FORMAT ( 6, 6 ), AAX_eStemFormat_6_0 = AAX_STEM_FORMAT ( 7, 6 ),
  AAX_eStemFormat_6_1 = AAX_STEM_FORMAT ( 8, 7 ), AAX_eStemFormat_7_0_SDDS = AAX_STEM_FORMAT ( 9, 7 ), AAX_eStemFormat_7_1_SDDS = AAX_STEM_FORMAT ( 10, 8 ), AAX_eStemFormat_7_0_DTS = AAX_STEM_FORMAT ( 11, 7 ),
  AAX_eStemFormat_7_1_DTS = AAX_STEM_FORMAT ( 12, 8 ), AAX_eStemFormatNum = 13, AAX_eStemFormat_None = AAX_STEM_FORMAT ( -100, 0 ), AAX_eStemFormat_Any = AAX_STEM_FORMAT ( -1, 0 ),
  AAX_eStemFormat_INT32_MAX = AAX_INT32_MAX
enum  AAX_EPlugInCategory {
  AAX_ePlugInCategory_None = 0x00000000, AAX_ePlugInCategory_EQ = 0x00000001, AAX_ePlugInCategory_Dynamics = 0x00000002, AAX_ePlugInCategory_PitchShift = 0x00000004,
  AAX_ePlugInCategory_Reverb = 0x00000008, AAX_ePlugInCategory_Delay = 0x00000010, AAX_ePlugInCategory_Modulation = 0x00000020, AAX_ePlugInCategory_Harmonic = 0x00000040,
  AAX_ePlugInCategory_NoiseReduction = 0x00000080, AAX_ePlugInCategory_Dither = 0x00000100, AAX_ePlugInCategory_SoundField = 0x00000200, AAX_ePlugInCategory_HWGenerators = 0x00000400,
  AAX_ePlugInCategory_SWGenerators = 0x00000800, AAX_ePlugInCategory_WrappedPlugin = 0x00001000, AAX_ePlugInCategory_Example = 0x00004000, AAX_ePlugInCategory_INT32_MAX = AAX_INT32_MAX
 Effect category definitions. More...
enum  AAX_EPlugInStrings {
  AAX_ePlugInStrings_Analysis = 0, AAX_ePlugInStrings_MonoMode = 1, AAX_ePlugInStrings_MultiInputMode = 2, AAX_ePlugInStrings_RegionByRegionAnalysis = 3,
  AAX_ePlugInStrings_AllSelectedRegionsAnalysis = 4, AAX_ePlugInStrings_RegionName = 5, AAX_ePlugInStrings_ClipName = 5, AAX_ePlugInStrings_Progress = 6,
  AAX_ePlugInStrings_PlugInFileName = 7, AAX_ePlugInStrings_Preview = 8, AAX_ePlugInStrings_Process = 9, AAX_ePlugInStrings_Bypass = 10,
  AAX_ePlugInStrings_INT32_MAX = AAX_INT32_MAX
 Effect string identifiers. More...
enum  AAX_EMeterOrientation {
  AAX_eMeterOrientation_Default = 0, AAX_eMeterOrientation_BottomLeft = AAX_eMeterOrientation_Default, AAX_eMeterOrientation_TopRight = 1, AAX_eMeterOrientation_Center = 2,
  AAX_eMeterOrientation_PhaseDot = 3
 Meter orientation. More...
enum  AAX_EMeterBallisticType { AAX_eMeterBallisticType_Host = 0, AAX_eMeterBallisticType_NoDecay = 1 }
 Meter ballistics type. More...
enum  AAX_EMeterType {
  AAX_eMeterType_Input = 0, AAX_eMeterType_Output = 1, AAX_eMeterType_CLGain = 2, AAX_eMeterType_EGGain = 3,
  AAX_eMeterType_Analysis = 4, AAX_eMeterType_Other = 5
 Meter type. More...
enum  AAX_ECurveType { AAX_eCurveType_EQ = 'AXeq', AAX_eCurveType_Dynamics = 'AXdy', AAX_eCurveType_Reduction = 'AXdr' }
 Different Curve Types that can be queried from the Host. More...
enum  AAX_EResourceType { AAX_eResourceType_None = 0, AAX_eResourceType_PageTable }
 Types of resources that can be added to an Effect's description. More...
enum  AAX_ENotificationEvent {
  AAX_eNotificationEvent_ASProcessingState = 'AXPr', AAX_eNotificationEvent_ASPreviewState = 'ASPv', AAX_eNotificationEvent_SessionBeingOpened = 'AXso', AAX_eNotificationEvent_PresetOpened = 'AXpo',
  AAX_eNotificationEvent_EnteringOfflineMode = 'AXof', AAX_eNotificationEvent_ExitingOfflineMode = 'AXox', AAX_eNotificationEvent_SessionPathChanged = 'AXsp', AAX_eNotificationEvent_SignalLatencyChanged = 'AXsl',
  AAX_eNotificationEvent_MaxViewSizeChanged = 'AXws', AAX_eNotificationEvent_SideChainBeingConnected = 'AXsc', AAX_eNotificationEvent_SideChainBeingDisconnected = 'AXsd'
 Events IDs that can be passed into the. More...
enum  AAX_EPrivateDataOptions {
  AAX_ePrivateDataOptions_DefaultOptions = 0, AAX_ePrivateDataOptions_KeepOnReset = (1 << 0), AAX_ePrivateDataOptions_External = (1 << 1), AAX_ePrivateDataOptions_Align8 = (1 << 2),
  AAX_ePrivateDataOptions_INT32_MAX = AAX_INT32_MAX
 Options for algorithm private data fields. More...
enum  AAX_EConstraintLocationMask { AAX_eConstraintLocationMask_None = 0, AAX_eConstraintLocationMask_DataModel = (1 << 0), AAX_eConstraintLocationMask_DLLChipAffinity = (1 << 1) }
 Property values to describe location constraints placed on the plug-in's algorithm component (ProcessProc) More...
enum  AAX_EConstraintTopology { AAX_eConstraintTopology_None = 0, AAX_eConstraintTopology_Monolithic = 1 }
 Property values to describe the topology of the plug-in's modules (e.g. data model, GUI.) More...
enum  AAX_EComponentInstanceInitAction { AAX_eComponentInstanceInitAction_AddingNewInstance = 0, AAX_eComponentInstanceInitAction_RemovingInstance = 1, AAX_eComponentInstanceInitAction_ResetInstance = 2 }
 Selector indicating the action that occurred to prompt a component initialization callback. More...
enum  AAX_ESampleRateMask {
  AAX_eSampleRateMask_No = 0, AAX_eSampleRateMask_44100 = (1 << 0), AAX_eSampleRateMask_48000 = (1 << 1), AAX_eSampleRateMask_88200 = (1 << 2),
  AAX_eSampleRateMask_96000 = (1 << 3), AAX_eSampleRateMask_176400 = (1 << 4), AAX_eSampleRateMask_192000 = (1 << 5), AAX_eSampleRateMask_All = AAX_INT32_MAX
 Property values to describe various sample rates. More...
enum  AAX_EParameterType { AAX_eParameterType_Discrete, AAX_eParameterType_Continuous }
enum  AAX_EParameterOrientationBits {
  AAX_eParameterOrientation_BottomMinTopMax = 0, AAX_eParameterOrientation_TopMinBottomMax = 1, AAX_eParameterOrientation_LeftMinRightMax = 0, AAX_eParameterOrientation_RightMinLeftMax = 2,
  AAX_eParameterOrientation_RotarySingleDotMode = 0, AAX_eParameterOrientation_RotaryBoostCutMode = 4, AAX_eParameterOrientation_RotaryWrapMode = 8, AAX_eParameterOrientation_RotarySpreadMode = 12,
  AAX_eParameterOrientation_RotaryLeftMinRightMax = 0, AAX_eParameterOrientation_RotaryRightMinLeftMax = 16
 Visual Orientation of a parameter. More...
enum  AAX_EParameterValueInfoSelector { AAX_ePageTable_EQ_Band_Type = 0, AAX_ePageTable_EQ_InCircuitPolarity = 1, AAX_ePageTable_UseAlternateControl = 2 }
 Query type selectors for use with AAX_IEffectParameters::GetParameterValueInfo() More...
enum  AAX_EEQBandTypes {
  AAX_eEQBandType_HighPass = 0, AAX_eEQBandType_LowShelf = 1, AAX_eEQBandType_Parametric = 2, AAX_eEQBandType_HighShelf = 3,
  AAX_eEQBandType_LowPass = 4, AAX_eEQBandType_Notch = 5
 Definitions of band types for EQ page table. More...
enum  AAX_EEQInCircuitPolarity { AAX_eEQInCircuitPolarity_Enabled = 0, AAX_eEQInCircuitPolarity_Bypassed = 1, AAX_eEQInCircuitPolarity_Disabled = 2 }
 Definitions for band in/out for EQ page table. More...
enum  AAX_EUseAlternateControl { AAX_eUseAlternateControl_No = 0, AAX_eUseAlternateControl_Yes = 1 }
 Definitions for Use Alternate Control parameter. More...
enum  AAX_EMIDINodeType { AAX_eMIDINodeType_LocalInput = 0, AAX_eMIDINodeType_LocalOutput = 1, AAX_eMIDINodeType_Global = 2, AAX_eMIDINodeType_Transport = 3 }
 MIDI node types. More...
enum  AAX_EUpdateSource { AAX_eUpdateSource_Unspecified = 0, AAX_eUpdateSource_Parameter = 1, AAX_eUpdateSource_Chunk = 2, AAX_eUpdateSource_Delay = 3 }
 Source for values passed into UpdateParameterNormalizedValue(). More...
enum  AAX_EDataInPortType { AAX_eDataInPortType_Unbuffered = 0, AAX_eDataInPortType_Buffered }
 Property value for whether a data in port should be buffered or not. More...
enum  AAX_EFrameRate {
  AAX_eFrameRate_Undeclared = 0, AAX_eFrameRate_24Frame, AAX_eFrameRate_25Frame, AAX_eFrameRate_2997NonDrop,
  AAX_eFrameRate_2997DropFrame, AAX_eFrameRate_30NonDrop, AAX_eFrameRate_30DropFrame, AAX_eFrameRate_23976
 FrameRate types. More...
enum  AAX_EFeetFramesRate { AAX_eFeetFramesRate_23976 = 0, AAX_eFeetFramesRate_24, AAX_eFeetFramesRate_25 }
 FeetFramesRate types. More...
enum  AAX_EMidiGlobalNodeSelectors { AAX_eMIDIClick = 1 << 0, AAX_eMIDIMtc = 1 << 1, AAX_eMIDIBeatClock = 1 << 2 }
 The Global MIDI Node Selectors. More...
enum  AAX_EPreviewState { AAX_ePreviewState_Stop = 0, AAX_ePreviewState_Start = 1 }
 Offline preview states for use with AAX_eNotificationEvent_ASPreviewState. More...
enum  AAX_EProcessingState { AAX_eProcessingState_Stop = 2, AAX_eProcessingState_Start = 3 }
 Offline preview states for use with AAX_eNotificationEvent_ASProcessingState. More...
Functions
 AAX_ENUM_SIZE_CHECK (AAX_EIconGUIType)
 AAX_ENUM_SIZE_CHECK (AAX_EHighlightColor)
 AAX_ENUM_SIZE_CHECK (AAX_ETracePriorityHost)
 AAX_ENUM_SIZE_CHECK (AAX_ETracePriorityDSP)
 AAX_ENUM_SIZE_CHECK (AAX_EModifiers)
 AAX_ENUM_SIZE_CHECK (AAX_EAudioBufferLength)
 AAX_ENUM_SIZE_CHECK (AAX_EAudioBufferLengthDSP)
 AAX_ENUM_SIZE_CHECK (AAE_EAudioBufferLengthNative)
 AAX_ENUM_SIZE_CHECK (AAX_EMaxAudioSuiteTracks)
 AAX_ENUM_SIZE_CHECK (AAX_EStemFormat)
 AAX_ENUM_SIZE_CHECK (AAX_EPlugInCategory)
 AAX_ENUM_SIZE_CHECK (AAX_EPlugInStrings)
 AAX_ENUM_SIZE_CHECK (AAX_EMeterOrientation)
 AAX_ENUM_SIZE_CHECK (AAX_EMeterBallisticType)
 AAX_ENUM_SIZE_CHECK (AAX_EMeterType)
 AAX_ENUM_SIZE_CHECK (AAX_ECurveType)
 AAX_ENUM_SIZE_CHECK (AAX_EResourceType)
 AAX_ENUM_SIZE_CHECK (AAX_ENotificationEvent)
 AAX_ENUM_SIZE_CHECK (AAX_EPrivateDataOptions)
 AAX_ENUM_SIZE_CHECK (AAX_EConstraintLocationMask)
 AAX_ENUM_SIZE_CHECK (AAX_EConstraintTopology)
 AAX_ENUM_SIZE_CHECK (AAX_EComponentInstanceInitAction)
 AAX_ENUM_SIZE_CHECK (AAX_ESampleRateMask)
 AAX_ENUM_SIZE_CHECK (AAX_EParameterType)
 AAX_ENUM_SIZE_CHECK (AAX_EParameterOrientationBits)
 AAX_ENUM_SIZE_CHECK (AAX_EParameterValueInfoSelector)
 AAX_ENUM_SIZE_CHECK (AAX_EEQBandTypes)
 AAX_ENUM_SIZE_CHECK (AAX_EEQInCircuitPolarity)
 AAX_ENUM_SIZE_CHECK (AAX_EUseAlternateControl)
 AAX_ENUM_SIZE_CHECK (AAX_EMIDINodeType)
 AAX_ENUM_SIZE_CHECK (AAX_EUpdateSource)
 AAX_ENUM_SIZE_CHECK (AAX_EDataInPortType)
 AAX_ENUM_SIZE_CHECK (AAX_EFrameRate)
 AAX_ENUM_SIZE_CHECK (AAX_EFeetFramesRate)
 AAX_ENUM_SIZE_CHECK (AAX_EMidiGlobalNodeSelectors)
 AAX_ENUM_SIZE_CHECK (AAX_EPreviewState)
 AAX_ENUM_SIZE_CHECK (AAX_EProcessingState)
Macro Definition Documentation
#define AAX_ENUM_SIZE_CHECK (   x)    extern int __enumSizeCheck[ 2*(sizeof(uint32_t)==sizeof(x)) - 1]
#define AAX_STEM_FORMAT (   aIndex,
  aChannelCount
#define AAX_STEM_FORMAT_CHANNEL_COUNT (   aStemFormat)    ( static_cast<uint16_t>( aStemFormat & 0xFFFF ) )
#define AAX_STEM_FORMAT_INDEX (   aStemFormat)    ( static_cast<int16_t>( ( aStemFormat >> 16 ) & 0xFFFF ) )
Typedef Documentation
Legacy Porting Notes:
Values must match unnamed type enum in FicTDMControl.h
Todo:
FLAGGED FOR REMOVAL
Enumeration Type Documentation
Todo:
Not used by AAX plug-ins
Enumerator
See Also
AAX_IEffectGUI::SetControlHighlightInfo()
Enumerator
Use the generic EAAX_Trace_Priority in plug-ins for cross-platform tracing (see AAX_Assert.h)
Enumerator
Enumerator
Enumerator
AAX_eModifiers_None
Shift.
Control on Mac, Winkey/Start on PC.
Option on Mac, Alt on PC.
Command on Mac, Ctrl on PC.
Secondary mouse button.
AAX_eModifiers_Alt
AAX_eModifiers_Cntl
Command on Mac, Cntl on PC.
Control on Mac, WINKEY on PC.
These enum values can be used to calculate literal values as powers of two:
See Also
Enumerator
Maximum buffer length for ProcessProc processing buffers.
Audio buffers for other methods, such as the high-latency render callback for AAX Hybrid or the offline render callback for Host Processor effects, may contain more samples than AAX_eAudioBufferLength_Max.
AAX DSP decks must support at least these buffer lengths. All AAX DSP algorithm ProcessProcs must support exactly one of these buffer lengths.
See Also
AAX_eProperty_AudioBufferLength
Enumerator
All AAX Native plug-ins must support variable buffer lengths. The buffer lengths that a host will use are constrained by the values in this enum. All Native buffer lengths will be powers of two, as per AAX_EAudioBufferLength
See Also
Enumerator
Minimum Native buffer length.
Maximum Native buffer length.
Enumerator
Enumerator
M.
L R.
AAX_eStemFormat_LCR
L C R.
L C R S.
L R Ls Rs.
AAX_eStemFormat_5_0
L C R Ls Rs.
AAX_eStemFormat_5_1
L C R Ls Rs LFE.
AAX_eStemFormat_6_0
L C R Ls Cs Rs.
AAX_eStemFormat_6_1
L C R Ls Cs Rs LFE.
L Lc C Rc R Ls Rs.
L Lc C Rc R Ls Rs LFE.
L C R Lss Rss Lsr Rsr.
L C R Lss Rss Lsr Rsr LFE.
AAX_eStemFormatNum
AAX_eStemFormat_Any
Used with AAX_IEffectDescriptor::AddCategory() to categorize an Effect.
These values are bitwise-exclusive and may be used in a bitmask to define multiple categories:
Note
The host may handle plug-ins with different categories in different manners, e.g. replacing "analyze" with "reverse" for offline processing of delays and reverbs.
Enumerator
Equalization.
Compressor, expander, limiter, etc.
Pitch processing.
Reverberation and room/space simulation.
Delay and echo.
Phasing, flanging, chorus, etc.
Distortion, saturation, and harmonic enhancement.
Noise reduction.
Dither, noise shaping, etc.
Pan, auto-pan, upmix and downmix, and surround handling.
Fixed hardware audio sources such as SampleCell.
Virtual instruments, metronomes, and other software audio sources.
All plug-ins wrapped by a thrid party wrapper (i.e. VST to RTAS wrapper), except for VI plug-ins which should be mapped to AAX_PlugInCategory_SWGenerators.
SDK example plug-ins.
Host Compatibility Notes:
AAX_ePlugInCategory_Example is compatible with Pro Tools 11 and higher. Effects with this category will not appear in Pro Tools 10.
The AAX host may associate certain plug-in display strings with these identifiers.
See Also
AAX_IEffectGUI::GetCustomLabel()
Enumerator
"Analyze" button label (AudioSuite)
Was pluginStrings_Analysis in the RTAS/TDM SDK
"Mono Mode" selector label (AudioSuite)
Was pluginStrings_MonoMode in the RTAS/TDM SDK
"Multi-Input Mode" selector label (AudioSuite)
Was pluginStrings_MultiInputMode in the RTAS/TDM SDK
"Clip-by-Clip Analysis" selector label (AudioSuite)
Was pluginStrings_RegionByRegionAnalysis in the RTAS/TDM SDK
"Whole File Analysis" selector label (AudioSuite)
Was pluginStrings_AllSelectedRegionsAnalysis in the RTAS/TDM SDK
Deprecated:
Clip name label (AudioSuite)
Was pluginStrings_RegionName in the RTAS/TDM SDK
Progress bar label (AudioSuite)
Was pluginStrings_Progress in the RTAS/TDM SDK
Deprecated:
Deprecated:
"Render" button label (AudioSuite)
Was pluginStrings_Process in the RTAS/TDM SDK
"Bypass" button label (AudioSuite)
Was pluginStrings_Bypass in the RTAS/TDM SDK
Meter orientation.
Use this enum in conjunction with the AAX_eProperty_Meter_Orientation property
For more information about meters in AAX, see Plug-in meters
Enumerator
the default orientation
Some dynamics plug-in orient their gain reduction like so.
A plug-in that does gain increase and decrease may want this. meter values less than 0x40000000 would display downward from the mid-point. meter values greater than 0x40000000 would display upward from the mid-point.
linear scale, displays 2 dots around the value ( currently D-Control only )
Use this enum in conjunction with the AAX_eProperty_Meter_Ballistics property
Enumerator
The ballistics follow the host settings.
No decay ballistics.
Meter type.
Use this enum in conjunction with the AAX_eProperty_Meter_Type property
Enumerator
e.g. Your typical input meter (possibly after an input gain stage)
e.g. Your typical output meter (possibly after an output gain stage)
e.g. Compressor/Limiter gain reduction
e.g. Expander/Gate gain reduction
e.g. multi-band amplitude from a Spectrum analyzer
e.g. a meter that does not fit in any of the above categories
Note
All 'AX__' IDs are reserved for host messages
Enumerator
AAX_eCurveType_EQ
EQ Curve, input values are in Hz, output values are in dB.
Dynamics Curve showing input vs. output, input and output values are in dB.
Gain-reduction curve showing input vs. gain reduction, input and output values are in dB.
See Also
AAX_IEffectDescriptor::AddResourceInfo()
Enumerator
Info is the file name of the page table xml file.
NotificationReceived hook functions.
Note
Enumerator
(int32_t) AudioSuite processing state change notification. One of AAX_EProcessingState.
(int32_t) AudioSuite preview state change notification. One of AAX_EPreviewState.
Replacement for SetPreviewState()
(no data) Tell the plug-in that chunk data is coming from a PTX
(no data) Tell the plug-in that chunk data is coming from a TFX
(no data) Entering offline processing mode ( i.e. offline bounce )
(no data) Exiting offline processing mode ( i.e. offline bounce )
(const AAX_IString) A string representing the path of the current session
(no data) The host has changed its latency compensation for this plug-in instance.
Note
This notification may be sent redundantly just after plug-in instantiation when the AAX_eProperty_LatencyContribution property is described.
(AAX_Point) Tell the plug-in the maximum allowed GUI dimensions
(no data) Tell the plug-in about connection of the sidechain input
(no data) Tell the plug-in about disconnection of the sidechain input
Enumerator
Retain data upon plug-in reset.
Warning
Not currently implemented. If this functionality is desired, the recommended workaround is to cache the desired private data to be set during AAX_IEffectParameters::ResetFieldData().
Place the block in external memory (internal by default)
Place the block in mem aligned by 64 bits.
See Also
AAX_eProperty_Constraint_Location
Enumerator
No constraint placed on component's location.
This ProcessProc must be co-located with the plug-in's data model object.
This ProcessProc should be instantiated on the same chip as other effects that use the same DLL.
  • This constraint is only applicable to DSP algorithms
See Also
AAX_eProperty_Constraint_Topology
Enumerator
No constraint placed on plug-in's topology.
All plug-in modules (e.g. data model, GUI) must be co-located and non-relocatable.
See Also
AAX_CInstanceInitProc
Enumerator
These values may be used as a bitmask, so e.g. a particular Effect may declare compatibility with AAX_eSampleRateMask_44100 | AAX_eSampleRateMask_48000
See Also
kAAX_Property_SampleRate
Enumerator
Todo:
FLAGGED FOR REMOVAL
Enumerator
Matches kDAE_DiscreteValues
Matches kDAE_ContinuousValues
Todo:
FLAGGED FOR REVISION
Enumerator
See Also
AAX_EEQBandTypes
converted from EControlValueInfo in the legacy SDK
Enumerator
EQ filter band type.
Possible response values are listed in AAX_EEQBandTypes
converted from eDigi_PageTable_EQ_Band_Type in the legacy SDK
Description of whether a particular EQ band is active.
Possible response values are listed in AAX_EEQInCircuitPolarity
converted from eDigi_PageTable_EQ_InCircuitPolarity in the legacy SDK
Description of whether an alternate parameter should be used for a given slot.
For example, some control surfaces support Q/Slope encoders. Using an alternate control mechanism, plug-ins mapped to these devices can assign a different slope control to the alternate slot and have it coexist with a Q control for each band. This is only applicable when mapping separate parameters to the same encoder; if the Q and Slope controls are implemented as the same parameter object in the plug-in then customization is not needed.
Possible response values are listed in AAX_EUseAlternateControl
converted from eDigi_PageTable_UseAlternateControl in the legacy SDK
For the AAX_ePageTable_EQ_Band_Type parameter value info selector
Enumerator
Freq, Slope
Freq, Gain, Slope
Freq, Gain, Q
Freq, Gain, Slope
Freq, Slope
Freq, Q
For the AAX_ePageTable_EQ_InCircuitPolarity parameter value selector
Enumerator
EQ band is in the signal path and enabled
EQ band is in the signal path but bypassed/off
EQ band is completely removed from signal path
For the AAX_ePageTable_UseAlternateControl parameter value info selector
Enumerator
MIDI node types.
See Also
AAX_IComponentDescriptor::AddMIDINode()
Enumerator
Local MIDI input.
Local MIDI input nodes receive MIDI by accessing AAX_CMidiStream buffers filled with MIDI messages. These buffers of MIDI data are available within the algorithm context with data corresponding to the current audio buffer being computed. The Effect can step through this buffer like a "script" to respond to MIDI events within the audio callback.
Corresponds to RTAS Buffered MIDI input nodes in the legacy SDK
Local MIDI output.
Local MIDI output nodes send MIDI by filling buffers with MIDI messages. Messages posted to MIDI output nodes will be available in the host as MIDI streams, routable to MIDI track inputs and elsewhere.
Data posted to a MIDI output buffer will be timed to correspond with the current audio buffer being processed. MIDI outputs support custom timestamping relative to the first sample of the audio buffer.
The delivery of variable length SysEx messages is also supported. There are no buffer size limitations for output of SysEx messages.
To post a MIDI output buffer, an Effect must construct a series of AAX_CMidiPacket objects and place them in the output buffer provided in the port's AAX_CMidiStream
Corresponds to RTAS Buffered MIDI output nodes in the legacy SDK
Global MIDI node.
Global MIDI nodes allow an Effect to receive streaming global MIDI data like MIDI Time Code, MIDI Beat Clock, and host-specific message formats such as the Click messages used in Pro Tools.
The specific kind of data that will be received by a Global MIDI node is specified using a mask of AAX_EMidiGlobalNodeSelectors values.
Global MIDI nodes are like local MIDI nodes, except they do not show up as assignable outputs in the host. Instead the MIDI data is automatically routed to the plug-in, without the user making any connections.
The buffer of data provided via a Global MIDI node may be shared between all currently active Effect instances, and this node may include both explicitly requested data and data not requested by the current Effect. For example, if one plug-in requests MTC and another plug-in requests Click, all plug-ins connected to this global node will get both MTC and Click messages in the shared buffer.
Corresponds to RTAS Shared Buffer global nodes in the legacy SDK
Transport node.
Call AAX_IMIDINode::GetTransport() on this node to access the AAX_ITransport interface.
Enumerator
Parameter updates of unknown / unspecified origin, currently including all updates from control surfaces, GUI edit events, and edits originating in the plug-in outside of the context of UpdateParameterNormalizedValue() or SetChunk().
Parameter updates originating (via AAX_IAutomationDelegate::PostSetValueRequest() ) within the scope of UpdateParameterNormalizedValue().
Parameter updates originating (via AAX_IAutomationDelegate::PostSetValueRequest() ) within the scope of SetChunk().
:Not Used by AAX Plug-Ins:
See Also
AAX_IComponentDescriptor::AddDataInPort()
Enumerator
Data port is unbuffered.
Data port is buffered both on the host and DSP.
FrameRate types.
See Also
AAX_ITransport::GetTimeCodeInfo()
Enumerator
See Also
AAX_ITransport::GetFeetFramesInfo()
Enumerator
These selectors are used in the channelMask argument of AAX_IComponentDescriptor::AddMIDINode() and AAX_IEffectDescriptor::AddControlMIDINode() to request one or more kinds of global data.
Enumerator
AAX_eMIDIClick
Selector to request click messages.
The click messages are special 2-byte messages encoded as follows:
  • Accented click: Note on pitch 0 (0x90 0x00)
  • Unaccented click: Note on pitch 1 (0x90 0x01)
    Note
    No Note Off messages are ever sent. This isn't up-to-spec MIDI data, just a way of encoding click events.
AAX_eMIDIMtc
Selector to request MIDI Time Code (MTC) data.
The Standard MIDI Time Code format.
AAX_eMIDIBeatClock
Selector to request MIDI Beat Clock (MBC) messages.
This includes Song Position Pointer, Start/Stop/Continue, and Midi Clock (F8).
Note
Do not perform any non-trivial processing within the notification handler. Instead, use the processing state notification to inform the processing that is performed in methods such as PreRender().
Enumerator
Offline preview has ended.
For Host Processor plug-ins, this notification is sent just before the final call to PostRender(), or after analysis is complete for plug-ins with analysis-only preview.
Offline preview is beginning.
For Host Processor plug-ins, this notification is sent before any calls to PreAnalyze() or to PreRender().
Note
Enumerator
Offline processing has ended.
For Host Processor plug-ins, this notification is sent just before the final call to PostRender(), or after analysis is complete for analysis-only offline plug-ins.
Offline processing is beginning.
Function Documentation
AAX_ENUM_SIZE_CHECK ( AAX_EIconGUIType  )
AAX_ENUM_SIZE_CHECK ( AAX_EHighlightColor  )
AAX_ENUM_SIZE_CHECK ( AAX_ETracePriorityHost  )
AAX_ENUM_SIZE_CHECK ( AAX_ETracePriorityDSP  )
AAX_ENUM_SIZE_CHECK ( AAX_EModifiers  )
AAX_ENUM_SIZE_CHECK ( AAX_EAudioBufferLength  )
AAX_ENUM_SIZE_CHECK ( AAX_EAudioBufferLengthDSP  )
AAX_ENUM_SIZE_CHECK ( AAE_EAudioBufferLengthNative  )
AAX_ENUM_SIZE_CHECK ( AAX_EMaxAudioSuiteTracks  )
AAX_ENUM_SIZE_CHECK ( AAX_EStemFormat  )
AAX_ENUM_SIZE_CHECK ( AAX_EPlugInCategory  )
AAX_ENUM_SIZE_CHECK ( AAX_EPlugInStrings  )
AAX_ENUM_SIZE_CHECK ( AAX_EMeterOrientation  )
AAX_ENUM_SIZE_CHECK ( AAX_EMeterBallisticType  )
AAX_ENUM_SIZE_CHECK ( AAX_EMeterType  )
AAX_ENUM_SIZE_CHECK ( AAX_ECurveType  )
AAX_ENUM_SIZE_CHECK ( AAX_EResourceType  )
AAX_ENUM_SIZE_CHECK ( AAX_ENotificationEvent  )
AAX_ENUM_SIZE_CHECK ( AAX_EPrivateDataOptions  )
AAX_ENUM_SIZE_CHECK ( AAX_EConstraintLocationMask  )
AAX_ENUM_SIZE_CHECK ( AAX_EConstraintTopology  )
AAX_ENUM_SIZE_CHECK ( AAX_EComponentInstanceInitAction  )
AAX_ENUM_SIZE_CHECK ( AAX_ESampleRateMask  )
AAX_ENUM_SIZE_CHECK ( AAX_EParameterType  )
AAX_ENUM_SIZE_CHECK ( AAX_EParameterOrientationBits  )
AAX_ENUM_SIZE_CHECK ( AAX_EParameterValueInfoSelector  )
AAX_ENUM_SIZE_CHECK ( AAX_EEQBandTypes  )
AAX_ENUM_SIZE_CHECK ( AAX_EEQInCircuitPolarity  )
AAX_ENUM_SIZE_CHECK ( AAX_EUseAlternateControl  )
AAX_ENUM_SIZE_CHECK ( AAX_EMIDINodeType  )
AAX_ENUM_SIZE_CHECK ( AAX_EUpdateSource  )
AAX_ENUM_SIZE_CHECK ( AAX_EDataInPortType  )
AAX_ENUM_SIZE_CHECK ( AAX_EFrameRate  )
AAX_ENUM_SIZE_CHECK ( AAX_EFeetFramesRate  )
AAX_ENUM_SIZE_CHECK ( AAX_EMidiGlobalNodeSelectors  )
AAX_ENUM_SIZE_CHECK ( AAX_EPreviewState  )
AAX_ENUM_SIZE_CHECK ( AAX_EProcessingState  )
