AAX SDK  2.1.1
Macros | Enumerations
AAX_Properties.h File Reference
#include "AAX.h"
Go to the source code of this file.
Description
Contains IDs for properties that can be added to an AAX_IPropertyMap.
Macros
#define AAX_PROPERTIES_H
Enumerations
enum  AAX_EProperty {
  AAX_eProperty_NoID = 0, AAX_eProperty_MinProp = 10, AAX_eProperty_PlugInSpecPropsBase = 10, AAX_eProperty_ManufacturerID = 11,
  AAX_eProperty_ProductID = 12, AAX_eProperty_PlugInID_Native = 13, AAX_eProperty_PlugInID_RTAS = AAX_eProperty_PlugInID_Native, AAX_eProperty_PlugInID_AudioSuite = 14,
  AAX_eProperty_PlugInID_TI = 15, AAX_eProperty_PlugInID_UI = 16, AAX_eProperty_PlugInID_Dither = 17, AAX_eProperty_PlugInID_Deprecated = 18,
  AAX_eProperty_PlugInID_Elastic = 19, AAX_eProperty_PlugInID_Analysis = 20, AAX_eProperty_Deprecated_Plugin_List = 21, AAX_eProperty_Related_DSP_Plugin_List = 22,
  AAX_eProperty_Related_Native_Plugin_List = 23, AAX_eProperty_GeneralPropsBase = 50, AAX_eProperty_InputStemFormat = 51, AAX_eProperty_OutputStemFormat = 52,
  AAX_eProperty_DSP_AudioBufferLength = 54, AAX_eProperty_AudioBufferLength = 54, AAX_eProperty_LatencyContribution = 56, AAX_eProperty_SampleRate = 58,
  AAX_eProperty_CanBypass = 60, AAX_eProperty_TI_SharedCycleCount = 62, AAX_eProperty_TI_InstanceCycleCount = 63, AAX_eProperty_TI_MaxInstancesPerChip = 64,
  AAX_eProperty_HybridOutputStemFormat = 90, AAX_eProperty_HybridInputStemFormat = 91, AAX_eProperty_AudiosuitePropsBase = 100, AAX_eProperty_UsesRandomAccess = 101,
  AAX_eProperty_RequiresAnalysis = 102, AAX_eProperty_OptionalAnalysis = 103, AAX_eProperty_AllowPreviewWithoutAnalysis = 104, AAX_eProperty_DestinationTrack = 105,
  AAX_eProperty_RequestsAllTrackData = 106, AAX_eProperty_ContinuousOnly = 107, AAX_eProperty_MultiInputModeOnly = 108, AAX_eProperty_DisablePreview = 110,
  AAX_eProperty_SupportsProgressDialog = 111, AAX_eProperty_DoesntIncrOutputSample = 112, AAX_eProperty_NumberOfInputs = 113, AAX_eProperty_NumberOfOutputs = 114,
  AAX_eProperty_DisableHandles = 115, AAX_eProperty_SupportsSideChainInput = 116, AAX_eProperty_NeedsOutputDithered = 117, AAX_eProperty_DisableAudiosuiteReverse = 117,
  AAX_eProperty_MaxASProp, AAX_eProperty_GUIBase = 150, AAX_eProperty_UsesClientGUI = 151, AAX_ePropety_MeterBase = 199,
  AAX_eProperty_Meter_Type = 200, AAX_eProperty_Meter_Orientation = 201, AAX_eProperty_Meter_Ballistics = 202, AAX_eProperty_ConstraintBase = 299,
  AAX_eProperty_Constraint_Location = 300, AAX_eProperty_Constraint_Topology = 301, AAX_eProperty_Constraint_NeverUnload = 302, AAX_eProperty_Constraint_NeverCache = 303,
  AAX_eProperty_Constraint_MultiMonoSupport = 304, AAX_eProperty_SupportsSaveRestore = 305, AAX_eProperty_UsesTransport = 306, AAX_eProperty_StoreXMLPageTablesByType = 307,
  AAX_eProperty_RequiresChunkCallsOnMainThread = 308, AAX_eProperty_Constraint_AlwaysProcess = 351, AAX_eProperty_MaxProp
 The list of properties that can be added to an AAX_IPropertyMap. More...
Macro Definition Documentation
Enumeration Type Documentation
See AAX_IPropertyMap::AddProperty() for more information
Sections
Legacy Porting Notes:
These property IDs are somewhat analogous to the pluginGestalt system in the legacy SDK, and several AAX_EProperty values correlate directly with a corresponding legacy plug-in gestalt.
To ensure session interchange compatibility, make sure the 4 character ID's for AAX_eProperty_ManufacturerID, AAX_eProperty_ProductID, AAX_eProperty_PlugInID_RTAS, and AAX_eProperty_PlugInID_AudioSuite are identical to the legacy SDK's counterpart.
Note
Currently, automation is linked by Parameter Name and not Parameter ID. As per PTSW-165992, this will be re-worked to include automation remains compatible for plug-ins with identical Parameter ID's as well.
Enumerator
AAX_eProperty_NoID
Four-character osid-style manufacturer identifier. Should be registered with Avid, and must be identical for all plug-ins from the same manufacturer.
  • Apply this property at the ProcessProc level
For legacy plug-in session compatibility, this ID should match the Manufacturer ID used in the corresponding legacy plug-ins.
Four-character osid-style Collection identifier. Should be identical for all Effects in the same Collection.
For legacy plug-in session compatibility, this ID should match the Product ID used in the corresponding legacy plug-in.
Four-character osid-style Effect identifier for real-time native audio Effects. Must be unique for all Effects in the Collection.
For legacy plug-in session compatibility, this ID should match the Type ID used in the corresponding legacy RTAS plug-in Types.
Deprecated:
Use AAX_eProperty_PlugInID_Native
Four-character osid-style Effect identifier for offline native audio Effects. Must be unique for all Effects in the Collection.
For legacy plug-in session compatibility, this ID should match the Type ID used in the corresponding legacy AudioSuite plug-in Types.
Four-character osid-style Effect identifier for real-time TI-accelerated audio Effects. Must be unique for all Effects in the Collection.
For legacy plug-in session compatibility, this ID should match the Type ID used in the corresponding legacy TDM plug-in Types.
This property is not used by plug-ins based on the AAX SDK.
Four-character osid-style Effect identifier for dither native audio Effects. Must be unique for all Effects in the Collection.
For legacy plug-in session compatibility, this ID should match the Type ID used in the corresponding legacy Dither plug-in Types.
Four-character osid-style Effect identifier for a corresponding deprecated Effect. Only one deprecated effect ID may correspond to each valid (non-deprecated) effect ID.
Specify a list of plug-ins that are deprecated by a new plug-in type.
  • This property must be applied at the ProcessProc level and used with the AddPropertyWithIDArray, which is a list of full plug-in specs (ManufacturerID, ProductID, PluginID)
Specify a list of DSP plug-ins that are related to a plug-in type.
  • For example, use this property inside a Native process to tell the host that this plug-in can be used in place of a DSP version.
Specify a list of Native plug-ins that are related to a plug-in type.
Input stem format. One of AAX_EStemFormat.
For offline processing, use AAX_eProperty_NumberOfInputs
Output stem format. One of AAX_EStemFormat.
For offline processing, use AAX_eProperty_NumberOfOutputs
Audio buffer length for DSP processing callbacks. One of AAX_EAudioBufferLengthDSP.
  • This property is only applicable to DSP algorithms
Deprecated:
Use AAX_eProperty_DSP_AudioBufferLength
Default latency contribution of a given processing callback, in samples.
Unlike most properties, an Effect's latency contribution may also be changed dynamically at runtime. This is done via AAX_IController::SetSignalLatency(). Dynamic latency reporting may not be recognized by the host application in all circumstances, however, so Effects should always define any nonzero initial latency value using AAX_eProperty_LatencyContribution
Specifies which sample rates the Effect supports. A mask of AAX_ESampleRateMask.
See Also
AAX_IComponentDescriptor::AddSampleRate()
The plug-in supports a Master Bypass control.
Was pluginGestalt_CanBypass.
Todo:
This property should always be enabled for AAX plug-ins
Shared cycle count (outer, per clump, loop overhead)
Instance cycle count (inner, per instance, loop overhead)
Maximum number of instances of this plug-in that can be loaded on a chip. This property is only used for DMA and background thread-enabled plug-ins.
Hybrid Output stem format. One of AAX_EStemFormat.
Hybrid Input stem format. One of AAX_EStemFormat.
The Effect requires random access to audio data.
Was pluginGestalt_UsesRandomAccess
The Effect requires an analysis pass.
  • Apply this property at the AAX_IEffectDescriptor level
  • This property is only applicable to offline processing
Was pluginGestalt_RequiresAnalysis
The Effect supports an analysis pass, but does not require it.
Was pluginGestalt_OptionalAnalysis
The Effect requires analysis, but is also allowed to preview.
Was pluginGestalt_AnalyzeOnTheFly
Informs the host application to reassign output to a different track.
Was pluginGestalt_DestinationTrack
The host should make all of the processed track's data available to the Effect.
Was pluginGestalt_RequestsAllTrackData
The Effect only processes on continuous data and does not support 'clip by clip' rendering.
Was pluginGestalt_ContinuousOnly
The Effect wants multi-input mode only (no mono mode option)
Was pluginGestalt_MultiInputModeOnly
The Effect does not support preview.
Was pluginGestalt_DisablePreview
The Effect controls its own progress dialog. If unsupported, the host manages this dialog.
Was pluginGestalt_SupportsProgressDialog
The Effect may not increment its output sample during some rendering calls.
Was pluginGestalt_DoesntIncrOutputSample
The number of input channels that the plug-in supports.
For real-time processing, use AAX_eProperty_InputStemFormat
The number of output channels that the plug-in supports.
For real-time processing, use AAX_eProperty_OutputStemFormat
Prevents the application of rendered region handles by the host.
Tells the host that the plug-in supports side chain inputs.
Requests that the host apply dithering to the Effect's output.
Was pluginGestalt_NeedsOutputDithered
The plug-in supports audiosuite reverse. By default, all reverb and delay plug-ins support this feature. If a plug-in needs to opt out of this feature, they can set this property to true.
Requests a host-generated GUI based on the Effect's parameters.
Indicates meter type as one of AAX_EMeterType.
Indicates meter orientation as one of AAX_EMeterOrientation.
Indicates meter ballistics preference as one of AAX_EMeterBallisticType.
Constraint on the algorithm's location, as a mask of AAX_EConstraintLocationMask.
Constraint on the topology of the Effect's modules, as one of AAX_EConstraintTopology.
Tells the host that it should never unload the plug-in binary.
Host Compatibility Notes:
AAX_eProperty_Constraint_NeverUnload is not currently implemented in DAE or AAE
Tells the host that it should never cache the plug-in binary. Only use this if required as there is a performance penalty on launch to not use the Cache. Set this property to 1, if you really need to not cache. Default is 0.
This property should be applied at the collection level as it affects the entire bundle.
Indicates whether or not the plug-in supports multi-mono configurations (true/false)
Indicates whether or not the plug-in supports Save/Restore features. (true/false)
  • Apply this property to show or hide the Settings section in the plug-in window.
  • This property value is true by default.
Was pluginGestalt_SupportsSaveRestore
Indicates whether or not the plug-in uses transport requests. (true/false)
This property specifies whether the plug-in bundle contains an XML file per plug-in type.
This property needs to be set at the collection level.
Indicates whether the plug-in supports SetChunk and GetChunk calls on threads other than the main thread. It is actually important for plug-ins to support these calls on non-main threads, so that is the default. However, in response to a few companies having issues with this, we have decided to support this constraint for now.
property value should be set to true if you need Chunk calls on the main thread.
Indicates that the plug-in's processing should never be disabled by the host (true/false)
Some hosts will disable processing for plug-in chains in certain circumstances to conserve system resources, e.g. when the chains' output drops to silence for an extended period.
