AAX SDK  2.1.1
AAX_ITransport Class Referenceabstract
#include <AAX_ITransport.h>
Inheritance diagram for AAX_ITransport:
Inheritance graph
[legend]
Description
Interface to information about the host's transport state.
:Implemented by the AAX Host:
Plug-ins that use this interface should describe AAX_eProperty_UsesTransport as 1
Acquire this interface using AAX_IMIDINode::GetTransport(). Classes that inherit from AAX_CEffectParameters or AAX_CEffectGUI can also use AAX_CEffectParameters::Transport() / AAX_CEffectGUI::Transport().
Public Member Functions
virtual ~AAX_ITransport ()
 Virtual destructor. More...
virtual AAX_Result GetCurrentTempo (double *TempoBPM) const =0
 CALL: Gets the current tempo. More...
virtual AAX_Result GetCurrentMeter (int32_t *MeterNumerator, int32_t *MeterDenominator) const =0
 CALL: Gets the current meter. More...
virtual AAX_Result IsTransportPlaying (bool *isPlaying) const =0
 CALL: Indicates whether or not the transport is playing back. More...
virtual AAX_Result GetCurrentTickPosition (int64_t *TickPosition) const =0
 CALL: Gets the current tick position. More...
virtual AAX_Result GetCurrentLoopPosition (bool *bLooping, int64_t *LoopStartTick, int64_t *LoopEndTick) const =0
 CALL: Gets current information on loop playback. More...
virtual AAX_Result GetCurrentNativeSampleLocation (int64_t *SampleLocation) const =0
 CALL: Gets the current playback location of the native audio engine. More...
virtual AAX_Result GetCustomTickPosition (int64_t *oTickPosition, int64_t iSampleLocation) const =0
 CALL: Given an absolute sample position, gets the corresponding tick position. More...
virtual AAX_Result GetBarBeatPosition (int32_t *Bars, int32_t *Beats, int64_t *DisplayTicks, int64_t SampleLocation) const =0
 CALL: Given an absolute sample position, gets the corresponding bar and beat position. More...
virtual AAX_Result GetTicksPerQuarter (uint32_t *ticks) const =0
 CALL: Retrieves the number of ticks per quarter note. More...
virtual AAX_Result GetCurrentTicksPerBeat (uint32_t *ticks) const =0
 CALL: Retrieves the number of ticks per beat. More...
virtual AAX_Result GetTimelineSelectionStartPosition (int64_t *oSampleLocation) const =0
 CALL: Retrieves the current absolute sample position of the beginning of the current transport selection. More...
virtual AAX_Result GetTimeCodeInfo (AAX_EFrameRate *oFrameRate, int32_t *oOffset) const =0
 CALL: Retrieves the current time code frame rate and offset. More...
virtual AAX_Result GetFeetFramesInfo (AAX_EFeetFramesRate *oFeetFramesRate, int64_t *oOffset) const =0
 CALL: Retrieves the current timecode feet/frames rate and offset. More...
virtual AAX_Result IsMetronomeEnabled (int32_t *isEnabled) const =0
 Sets isEnabled to true if the metronome is enabled. More...
Constructor & Destructor Documentation
virtual AAX_ITransport::~AAX_ITransport ( )
inlinevirtual
Virtual destructor.
Note
This destructor MUST be virtual to prevent memory leaks.
Member Function Documentation
virtual AAX_Result AAX_ITransport::GetCurrentTempo ( double *  TempoBPM) const
pure virtual
Returns the tempo corresponding to the current position of the transport counter
Note
The resolution of the tempo returned here is based on the host's tempo resolution, so it will match the tempo displayed in the host. Use GetCurrentTicksPerBeat() to calculate the tempo resolution note.
Parameters
[out]TempoBPMThe current tempo in beats per minute
Implemented in AAX_VTransport.
virtual AAX_Result AAX_ITransport::GetCurrentMeter ( int32_t *  MeterNumerator,
int32_t *  MeterDenominator
) const
pure virtual
Returns the meter corresponding to the current position of the transport counter
Parameters
[out]MeterNumeratorThe numerator portion of the meter
[out]MeterDenominatorThe denominator portion of the meter
virtual AAX_Result AAX_ITransport::IsTransportPlaying ( bool *  isPlaying) const
pure virtual
Parameters
[out]isPlayingtrue if the transport is currently in playback
virtual AAX_Result AAX_ITransport::GetCurrentTickPosition ( int64_t *  TickPosition) const
pure virtual
Returns the current tick position corresponding to the current transport position. One "Tick" is represented here as 1/960000 of a quarter note. That is, there are 960,000 of these ticks in a quarter note.
Host Compatibility Notes:
The tick resolution here is different than that of the tick displayed in Pro Tools. "Display ticks" (as they are called) are 1/960 of a quarter note.
Parameters
[out]TickPositionThe tick position value
virtual AAX_Result AAX_ITransport::GetCurrentLoopPosition ( bool *  bLooping,
int64_t *  LoopStartTick,
int64_t *  LoopEndTick
) const
pure virtual
This does not indicate anything about the status of the "Loop Record" option. Even when the host is configured to loop playback, looping may not occur if certain conditions are not met (i.e. the length of the selection is too short)
Parameters
[out]bLoopingtrue if the host is configured to loop playback
[out]LoopStartTickThe starting tick position of the selection being looped (see GetCurrentTickPosition())
[out]LoopEndTickThe ending tick position of the selection being looped (see GetCurrentTickPosition())
virtual AAX_Result AAX_ITransport::GetCurrentNativeSampleLocation ( int64_t *  SampleLocation) const
pure virtual
Note
This method only returns a value during playback. It cannot be used to determine, e.g., the location of the timeline selector while the host is not in playback.
Parameters
[out]SampleLocationAbsolute sample location of the first sample in the current native processing buffer
virtual AAX_Result AAX_ITransport::GetCustomTickPosition ( int64_t *  oTickPosition,
) const
pure virtual
There is a minor performance cost associated with using this API in Pro Tools. It should not be used excessively without need.
Parameters
[out]oTickPositionthe timeline tick position corresponding to iSampleLocation
[in]iSampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_ITransport::GetBarBeatPosition ( int32_t *  Bars,
int32_t *  Beats,
int64_t *  DisplayTicks,
) const
pure virtual
Parameters
[out]BarsThe bar corresponding to SampleLocation
[out]BeatsThe beat corresponding to SampleLocation
[out]DisplayTicksThe ticks corresponding to SampleLocation
[in]SampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_ITransport::GetTicksPerQuarter ( uint32_t *  ticks) const
pure virtual
Parameters
[out]ticks
virtual AAX_Result AAX_ITransport::GetCurrentTicksPerBeat ( uint32_t *  ticks) const
pure virtual
Parameters
[out]ticks
virtual AAX_Result AAX_ITransport::GetTimelineSelectionStartPosition ( int64_t *  oSampleLocation) const
pure virtual
Note
This method is part of the version 2 transport interface
Parameters
[out]oSampleLocation
virtual AAX_Result AAX_ITransport::GetTimeCodeInfo ( AAX_EFrameRate *  oFrameRate,
int32_t *  oOffset
) const
pure virtual
Note
Parameters
[out]oFrameRate
[out]oOffset
virtual AAX_Result AAX_ITransport::GetFeetFramesInfo ( AAX_EFeetFramesRate *  oFeetFramesRate,
int64_t *  oOffset
) const
pure virtual
Note
Parameters
[out]oFeetFramesRate
[out]oOffset
virtual AAX_Result AAX_ITransport::IsMetronomeEnabled ( int32_t *  isEnabled) const
pure virtual
Note
Parameters
[out]isEnabled
