AAX SDK  2.1.1
AAX_VTransport Class Reference
#include <AAX_VTransport.h>
Inheritance diagram for AAX_VTransport:
Inheritance graph
[legend]
Collaboration diagram for AAX_VTransport:
Collaboration graph
[legend]
Description
Version-managed concrete AAX_ITransport class.
Public Member Functions
 AAX_VTransport (IACFUnknown *pUnknown)
virtual ~AAX_VTransport ()
virtual AAX_Result GetCurrentTempo (double *TempoBPM) const
 CALL: Gets the current tempo. More...
virtual AAX_Result GetCurrentMeter (int32_t *MeterNumerator, int32_t *MeterDenominator) const
 CALL: Gets the current meter. More...
virtual AAX_Result IsTransportPlaying (bool *isPlaying) const
 CALL: Indicates whether or not the transport is playing back. More...
virtual AAX_Result GetCurrentTickPosition (int64_t *TickPosition) const
 CALL: Gets the current tick position. More...
virtual AAX_Result GetCurrentLoopPosition (bool *bLooping, int64_t *LoopStartTick, int64_t *LoopEndTick) const
 CALL: Gets current information on loop playback. More...
virtual AAX_Result GetCurrentNativeSampleLocation (int64_t *SampleLocation) const
 CALL: Gets the current playback location of the native audio engine. More...
virtual AAX_Result GetCustomTickPosition (int64_t *oTickPosition, int64_t iSampleLocation) const
 CALL: Given an absolute sample position, gets the corresponding tick position. More...
virtual AAX_Result GetBarBeatPosition (int32_t *Bars, int32_t *Beats, int64_t *DisplayTicks, int64_t SampleLocation) const
 CALL: Given an absolute sample position, gets the corresponding bar and beat position. More...
virtual AAX_Result GetTicksPerQuarter (uint32_t *ticks) const
 CALL: Retrieves the number of ticks per quarter note. More...
virtual AAX_Result GetCurrentTicksPerBeat (uint32_t *ticks) const
 CALL: Retrieves the number of ticks per beat. More...
virtual AAX_Result GetTimelineSelectionStartPosition (int64_t *oSampleLocation) const
 CALL: Retrieves the current absolute sample position of the beginning of the current transport selection. More...
virtual AAX_Result GetTimeCodeInfo (AAX_EFrameRate *oFrameRate, int32_t *oOffset) const
 CALL: Retrieves the current time code frame rate and offset. More...
virtual AAX_Result GetFeetFramesInfo (AAX_EFeetFramesRate *oFeetFramesRate, int64_t *oOffset) const
 CALL: Retrieves the current timecode feet/frames rate and offset. More...
virtual AAX_Result IsMetronomeEnabled (int32_t *isEnabled) const
 Sets isEnabled to true if the metronome is enabled. More...
- Public Member Functions inherited from AAX_ITransport
virtual ~AAX_ITransport ()
 Virtual destructor. More...
Constructor & Destructor Documentation
AAX_VTransport::AAX_VTransport ( IACFUnknown *  pUnknown)
virtual AAX_VTransport::~AAX_VTransport ( )
virtual
Member Function Documentation
virtual AAX_Result AAX_VTransport::GetCurrentTempo ( double *  TempoBPM) const
virtual
Returns the tempo corresponding to the current position of the transport counter
Note
The resolution of the tempo returned here is based on the host's tempo resolution, so it will match the tempo displayed in the host. Use GetCurrentTicksPerBeat() to calculate the tempo resolution note.
Parameters
[out]TempoBPMThe current tempo in beats per minute
Implements AAX_ITransport.
virtual AAX_Result AAX_VTransport::GetCurrentMeter ( int32_t *  MeterNumerator,
int32_t *  MeterDenominator
) const
virtual
Returns the meter corresponding to the current position of the transport counter
Parameters
[out]MeterNumeratorThe numerator portion of the meter
[out]MeterDenominatorThe denominator portion of the meter
virtual AAX_Result AAX_VTransport::IsTransportPlaying ( bool *  isPlaying) const
virtual
Parameters
[out]isPlayingtrue if the transport is currently in playback
virtual AAX_Result AAX_VTransport::GetCurrentTickPosition ( int64_t *  TickPosition) const
virtual
Returns the current tick position corresponding to the current transport position. One "Tick" is represented here as 1/960000 of a quarter note. That is, there are 960,000 of these ticks in a quarter note.
Host Compatibility Notes:
The tick resolution here is different than that of the tick displayed in Pro Tools. "Display ticks" (as they are called) are 1/960 of a quarter note.
Parameters
[out]TickPositionThe tick position value
virtual AAX_Result AAX_VTransport::GetCurrentLoopPosition ( bool *  bLooping,
int64_t *  LoopStartTick,
int64_t *  LoopEndTick
) const
virtual
This does not indicate anything about the status of the "Loop Record" option. Even when the host is configured to loop playback, looping may not occur if certain conditions are not met (i.e. the length of the selection is too short)
Parameters
[out]bLoopingtrue if the host is configured to loop playback
[out]LoopStartTickThe starting tick position of the selection being looped (see GetCurrentTickPosition())
[out]LoopEndTickThe ending tick position of the selection being looped (see GetCurrentTickPosition())
virtual AAX_Result AAX_VTransport::GetCurrentNativeSampleLocation ( int64_t *  SampleLocation) const
virtual
Note
This method only returns a value during playback. It cannot be used to determine, e.g., the location of the timeline selector while the host is not in playback.
Parameters
[out]SampleLocationAbsolute sample location of the first sample in the current native processing buffer
virtual AAX_Result AAX_VTransport::GetCustomTickPosition ( int64_t *  oTickPosition,
) const
virtual
There is a minor performance cost associated with using this API in Pro Tools. It should not be used excessively without need.
Parameters
[out]oTickPositionthe timeline tick position corresponding to iSampleLocation
[in]iSampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_VTransport::GetBarBeatPosition ( int32_t *  Bars,
int32_t *  Beats,
int64_t *  DisplayTicks,
) const
virtual
Parameters
[out]BarsThe bar corresponding to SampleLocation
[out]BeatsThe beat corresponding to SampleLocation
[out]DisplayTicksThe ticks corresponding to SampleLocation
[in]SampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_VTransport::GetTicksPerQuarter ( uint32_t *  ticks) const
virtual
Parameters
[out]ticks
virtual AAX_Result AAX_VTransport::GetCurrentTicksPerBeat ( uint32_t *  ticks) const
virtual
Parameters
[out]ticks
virtual AAX_Result AAX_VTransport::GetTimelineSelectionStartPosition ( int64_t *  oSampleLocation) const
virtual
Note
This method is part of the version 2 transport interface
Parameters
[out]oSampleLocation
virtual AAX_Result AAX_VTransport::GetTimeCodeInfo ( AAX_EFrameRate *  oFrameRate,
int32_t *  oOffset
) const
virtual
Note
Parameters
[out]oFrameRate
[out]oOffset
virtual AAX_Result AAX_VTransport::GetFeetFramesInfo ( AAX_EFeetFramesRate *  oFeetFramesRate,
int64_t *  oOffset
) const
virtual
Note
Parameters
[out]oFeetFramesRate
[out]oOffset
virtual AAX_Result AAX_VTransport::IsMetronomeEnabled ( int32_t *  isEnabled) const
virtual
Note
Parameters
[out]isEnabled
