AAX SDK  2.1.1
AAX_IPropertyMap Class Referenceabstract
#include <AAX_IPropertyMap.h>
Inheritance diagram for AAX_IPropertyMap:
Inheritance graph
[legend]
Description
Generic plug-in description property map.
:Implemented by the AAX Host:
Property Maps are used to associate specific sets of properties with plug-in description interfaces. For example, an audio processing component might register mono and stereo callbacks, or Native and TI callbacks, assigning each ProcessProc the applicable property mapping. This allows the host to determine the correct callback to use depending on the environment in which the plug-in is instantiated.
AAX does not require that every value in AAX IPropertyMap be assigned by the developer. Unassigned properties do not have defined default values; if a specific value is not assigned to one of an element's properties then the element must support any value for that property. For example, if an audio processing component does not define its callback's audio buffer length property, the host will assume that the callback will support any buffer length.
Public Member Functions
virtual ~AAX_IPropertyMap ()
virtual AAX_CBoolean GetProperty (AAX_EProperty iProperty, AAX_CPropertyValue *oValue) const =0
 Get a property value from a property map. More...
virtual AAX_Result AddProperty (AAX_EProperty iProperty, AAX_CPropertyValue iValue)=0
 Add a callback property to a property map. More...
virtual AAX_Result RemoveProperty (AAX_EProperty iProperty)=0
 Remove a callback property from a property map. More...
virtual AAX_Result AddPropertyWithIDArray (AAX_EProperty iProperty, const AAX_SPlugInIdentifierTriad *iPluginIDs, uint32_t iNumPluginIDs)=0
 Add an array of plug-in IDs to a property map. More...
virtual AAX_CBoolean GetPropertyWithIDArray (AAX_EProperty iProperty, const AAX_SPlugInIdentifierTriad **oPluginIDs, uint32_t *oNumPluginIDs) const =0
 Get an array of plug-in IDs from a property map. More...
Constructor & Destructor Documentation
virtual AAX_IPropertyMap::~AAX_IPropertyMap ( )
inlinevirtual
Member Function Documentation
virtual AAX_CBoolean AAX_IPropertyMap::GetProperty ( AAX_EProperty  iProperty,
AAX_CPropertyValue *  oValue
) const
pure virtual
Returns true if the selected property is supported, false if it is not
Parameters
[in]iPropertyThe property ID
[in]oValueThe property value
Implemented in AAX_VPropertyMap.
virtual AAX_Result AAX_IPropertyMap::AddProperty ( AAX_EProperty  iProperty,
pure virtual
Parameters
[in]iPropertyThe property ID.
[in]iValue
virtual AAX_Result AAX_IPropertyMap::RemoveProperty ( AAX_EProperty  iProperty)
pure virtual
Parameters
virtual AAX_Result AAX_IPropertyMap::AddPropertyWithIDArray ( AAX_EProperty  iProperty,
const AAX_SPlugInIdentifierTriad *  iPluginIDs,
pure virtual
Parameters
[in]iPluginIDsAn array of AAX_SPlugInIdentifierTriad
[in]iNumPluginIDsThe length of iPluginIDs
virtual AAX_CBoolean AAX_IPropertyMap::GetPropertyWithIDArray ( AAX_EProperty  iProperty,
const AAX_SPlugInIdentifierTriad **  oPluginIDs,
uint32_t *  oNumPluginIDs
) const
pure virtual
Parameters
[out]oPluginIDsA pointer that will be set to reference an array of AAX_SPlugInIdentifierTriad
[in]oNumPluginIDsThe length of oPluginIDs
