AAX SDK  2.1.1
AAX_IEffectDescriptor Class Referenceabstract
#include <AAX_IEffectDescriptor.h>
Inheritance diagram for AAX_IEffectDescriptor:
Inheritance graph
[legend]
Description
Description interface for an effect's (plug-in type's) components.
:Implemented by the AAX Host:
Each Effect represents a different "type" of plug-in. The host will present different Effects to the user as separate products, even if they are derived from the same AAX_ICollection description.
Public Member Functions
virtual ~AAX_IEffectDescriptor ()
virtual AAX_IComponentDescriptor * NewComponentDescriptor ()=0
 Create an instance of a component descriptor. More...
virtual AAX_Result AddComponent (AAX_IComponentDescriptor *iComponentDescriptor)=0
 Add a component to an instance of a component descriptor. More...
virtual AAX_Result AddName (const char *iPlugInName)=0
 Add a name to the Effect. More...
virtual AAX_Result AddCategory (uint32_t iCategory)=0
 Add a category to your plug-in. See AAX_EPlugInCategory. More...
virtual AAX_Result AddCategoryBypassParameter (uint32_t iCategory, AAX_CParamID iParamID)=0
virtual AAX_Result AddProcPtr (void *iProcPtr, AAX_CProcPtrID iProcID)=0
 Add a process pointer. More...
virtual AAX_IPropertyMap * NewPropertyMap ()=0
 Create a new property map. More...
virtual AAX_Result SetProperties (AAX_IPropertyMap *iProperties)=0
 Set the properties of a new property map. More...
virtual AAX_Result AddResourceInfo (AAX_EResourceType iResourceType, const char *iInfo)=0
 Set resource file info. More...
virtual AAX_Result AddMeterDescription (AAX_CTypeID iMeterID, const char *iMeterName, AAX_IPropertyMap *iProperties)=0
 Add name and property map to meter with given ID. More...
virtual AAX_Result AddControlMIDINode (AAX_CTypeID iNodeID, AAX_EMIDINodeType iNodeType, const char iNodeName[], uint32_t iChannelMask)=0
 Add control MIDI node. More...
Constructor & Destructor Documentation
virtual AAX_IEffectDescriptor::~AAX_IEffectDescriptor ( )
inlinevirtual
Member Function Documentation
virtual AAX_IComponentDescriptor* AAX_IEffectDescriptor::NewComponentDescriptor ( )
pure virtual
Implemented in AAX_VEffectDescriptor.
virtual AAX_Result AAX_IEffectDescriptor::AddComponent ( AAX_IComponentDescriptor *  iComponentDescriptor)
pure virtual
Unlike with AAX_ICollection::AddEffect(), the AAX_IEffectDescriptor does not take ownership of the AAX_IComponentDescriptor that is passed to it in this method. The host copies out the contents of this descriptor, and thus the plug-in may re-use the same descriptor object when creating additional similar components.
Parameters
[in]iComponentDescriptor
virtual AAX_Result AAX_IEffectDescriptor::AddName ( const char *  iPlugInName)
pure virtual
May be called multiple times to add abbreviated Effect names.
Note
Every Effect must include at least one name variant with 31 or fewer characters, plus a null terminating character
Parameters
[in]iPlugInNameThe name assigned to the plug-in.
virtual AAX_Result AAX_IEffectDescriptor::AddCategory ( uint32_t  iCategory)
pure virtual
Parameters
[in]iCategoryOne of the categories for the plug-in.
virtual AAX_Result AAX_IEffectDescriptor::AddCategoryBypassParameter ( uint32_t  iCategory,
pure virtual
Parameters
[in]iParamIDThe parameter ID of the parameter used to bypass the category seciont of the plug-in.
virtual AAX_Result AAX_IEffectDescriptor::AddProcPtr ( void *  iProcPtr,
pure virtual
Parameters
[in]iProcPtrA process pointer.
[in]iProcIDA process ID.
virtual AAX_IPropertyMap* AAX_IEffectDescriptor::NewPropertyMap ( )
pure virtual
virtual AAX_Result AAX_IEffectDescriptor::SetProperties ( AAX_IPropertyMap *  iProperties)
pure virtual
Parameters
[in]iPropertiesDescription
virtual AAX_Result AAX_IEffectDescriptor::AddResourceInfo ( AAX_EResourceType  iResourceType,
const char *  iInfo
pure virtual
Parameters
[in]iResourceTypeSee AAX_EResourceType.
[in]iInfoDefinition varies on the resource type.
virtual AAX_Result AAX_IEffectDescriptor::AddMeterDescription ( AAX_CTypeID  iMeterID,
const char *  iMeterName,
pure virtual
Parameters
[in]iMeterIDThe ID of the meter being described.
[in]iMeterNameThe name of the meter.
[in]iPropertiesThe property map containing meter related data such as meter type, orientation, etc.
virtual AAX_Result AAX_IEffectDescriptor::AddControlMIDINode ( AAX_CTypeID  iNodeID,
pure virtual
Parameters
[in]iNodeIDThe ID for the new control MIDI node.
[in]iNodeTypeThe type of the node.
[in]iNodeNameThe name of the node.
[in]iChannelMaskThe bit mask for required nodes channels (up to 16) or required global events for global node.
