AAX SDK  2.1.1
AAX_ICollection Class Referenceabstract
#include <AAX_ICollection.h>
Inheritance diagram for AAX_ICollection:
Inheritance graph
[legend]
Description
Interface to represent a plug-in binary's static description.
:Implemented by the AAX Host:
The AAX_ICollection interface provides a creation function for new plug-in descriptors, which in turn provides access to the various interfaces necessary for describing a plug-in. When a plug-in description is complete, it is added to the collection via the AddEffect method. The AAX_ICollection interface also provides some additional description methods that are used to describe the overall plug-in package. These methods can be used to describe the plug-in package's name, the name of the plug-in's manufacturer, and the plug-in package version.
Legacy Porting Notes:
The information in AAX_ICollection is roughly analogous to the information provided by CProcessGroup in the legacy plug-in library
Public Member Functions
virtual ~AAX_ICollection ()
virtual AAX_IEffectDescriptor * NewDescriptor ()=0
 Create a new Effect descriptor. More...
virtual AAX_Result AddEffect (const char *iEffectID, AAX_IEffectDescriptor *iEffectDescriptor)=0
 Add an Effect description to the collection. More...
virtual AAX_Result SetManufacturerName (const char *iPackageName)=0
 Set the plug-in manufacturer name. More...
virtual AAX_Result AddPackageName (const char *iPackageName)=0
 Set the plug-in package name. More...
virtual AAX_Result SetPackageVersion (uint32_t iVersion)=0
 Set the plug-in package version number. More...
virtual AAX_IPropertyMap * NewPropertyMap ()=0
 Create a new property map. More...
virtual AAX_Result SetProperties (AAX_IPropertyMap *iProperties)=0
 Set the properties of a new property map. More...
Constructor & Destructor Documentation
virtual AAX_ICollection::~AAX_ICollection ( )
inlinevirtual
Member Function Documentation
virtual AAX_IEffectDescriptor* AAX_ICollection::NewDescriptor ( )
pure virtual
Implemented in AAX_VCollection.
virtual AAX_Result AAX_ICollection::AddEffect ( const char *  iEffectID,
AAX_IEffectDescriptor *  iEffectDescriptor
pure virtual
This method passes ownership of an AAX_IEffectDescriptor object to the AAX_ICollection. The AAX_IEffectDescriptor must not be deleted by the AAX plug-in, nor should it be edited in any way after it is passed to the AAX_ICollection.
Parameters
[in]iEffectIDThe effect ID.
[in]iEffectDescriptorThe Effect descriptor.
virtual AAX_Result AAX_ICollection::SetManufacturerName ( const char *  iPackageName)
pure virtual
Parameters
[in]iPackageNameThe name of the manufacturer.
virtual AAX_Result AAX_ICollection::AddPackageName ( const char *  iPackageName)
pure virtual
May be called multiple times to add abbreviated package names.
Note
Every plug-in must include at least one name variant with 16 or fewer characters, plus a null terminating character. Used for Presets folder.
Parameters
[in]iPackageNameThe name of the package.
virtual AAX_Result AAX_ICollection::SetPackageVersion ( uint32_t  iVersion)
pure virtual
Parameters
[in]iVersionThe package version numner.
virtual AAX_IPropertyMap* AAX_ICollection::NewPropertyMap ( )
pure virtual
virtual AAX_Result AAX_ICollection::SetProperties ( AAX_IPropertyMap *  iProperties)
pure virtual
Parameters
[in]iPropertiesDescription
