AAX SDK  2.1.1
AAX_VCollection Class Reference
#include <AAX_VCollection.h>
Inheritance diagram for AAX_VCollection:
Inheritance graph
[legend]
Collaboration diagram for AAX_VCollection:
Collaboration graph
[legend]
Description
Version-managed concrete AAX_ICollection class.
Public Member Functions
 AAX_VCollection (IACFUnknown *pUnkHost)
virtual ~AAX_VCollection ()
virtual AAX_IEffectDescriptor * NewDescriptor ()
 Create a new Effect descriptor. More...
virtual AAX_Result AddEffect (const char *inEffectID, AAX_IEffectDescriptor *inEffectDescriptor)
 Add an Effect description to the collection. More...
virtual AAX_Result SetManufacturerName (const char *inPackageName)
 Set the plug-in manufacturer name. More...
virtual AAX_Result AddPackageName (const char *inPackageName)
 Set the plug-in package name. More...
virtual AAX_Result SetPackageVersion (uint32_t inVersion)
 Set the plug-in package version number. More...
virtual AAX_IPropertyMap * NewPropertyMap ()
 Create a new property map. More...
virtual AAX_Result SetProperties (AAX_IPropertyMap *iProperties)
 Set the properties of a new property map. More...
IACFPluginDefinition * GetIUnknown (void) const
- Public Member Functions inherited from AAX_ICollection
virtual ~AAX_ICollection ()
Constructor & Destructor Documentation
AAX_VCollection::AAX_VCollection ( IACFUnknown *  pUnkHost)
virtual AAX_VCollection::~AAX_VCollection ( )
virtual
Member Function Documentation
virtual AAX_IEffectDescriptor* AAX_VCollection::NewDescriptor ( )
virtual
This implementation retains each generated AAX_IEffectDescriptor and destroys the descriptor upon AAX_VCollection destruction
Implements AAX_ICollection.
virtual AAX_Result AAX_VCollection::AddEffect ( const char *  iEffectID,
AAX_IEffectDescriptor *  iEffectDescriptor
virtual
This method passes ownership of an AAX_IEffectDescriptor object to the AAX_ICollection. The AAX_IEffectDescriptor must not be deleted by the AAX plug-in, nor should it be edited in any way after it is passed to the AAX_ICollection.
Parameters
[in]iEffectIDThe effect ID.
[in]iEffectDescriptorThe Effect descriptor.
virtual AAX_Result AAX_VCollection::SetManufacturerName ( const char *  iPackageName)
virtual
Parameters
[in]iPackageNameThe name of the manufacturer.
virtual AAX_Result AAX_VCollection::AddPackageName ( const char *  iPackageName)
virtual
May be called multiple times to add abbreviated package names.
Note
Every plug-in must include at least one name variant with 16 or fewer characters, plus a null terminating character. Used for Presets folder.
Parameters
[in]iPackageNameThe name of the package.
virtual AAX_Result AAX_VCollection::SetPackageVersion ( uint32_t  iVersion)
virtual
Parameters
[in]iVersionThe package version numner.
virtual AAX_IPropertyMap* AAX_VCollection::NewPropertyMap ( )
virtual
virtual AAX_Result AAX_VCollection::SetProperties ( AAX_IPropertyMap *  iProperties)
virtual
Parameters
[in]iPropertiesDescription
IACFPluginDefinition* AAX_VCollection::GetIUnknown ( void  ) const
