AAX SDK  2.1.1
Classes | Typedefs | Enumerations
AAX_Callbacks.h File Reference
#include "AAX.h"
Go to the source code of this file.
Description
AAX callback prototypes and ProcPtr definitions.
Classes
class  AAX_Component< aContextType >
 Empty class containing type declarations for the AAX algorithm and associated callbacks. More...
Typedefs
typedef IACFUnknown *AAX_CALLBACK * AAXCreateObjectProc (void)
typedef AAX_Component< void >
::CProcessProc
AAX_CProcessProc
 A user-defined callback that AAX calls to process data packets and/or audio. More...
::CPacketAllocator
AAX_CPacketAllocator
 Used by AAX_SchedulePacket() More...
::CInstanceInitProc
AAX_CInstanceInitProc
 A user-defined callback that AAX calls to notify the component that an instance is being added or removed. More...
::CBackgroundProc
AAX_CBackgroundProc
 A user-defined callback that AAX calls in the AAX Idle time. More...
::CInitPrivateDataProc
AAX_CInitPrivateDataProc
 A user-defined callback to initialize a private data block. More...
Enumerations
enum  AAX_CProcPtrID {
  kAAX_ProcPtrID_Create_EffectParameters = 0, kAAX_ProcPtrID_Create_EffectGUI = 1, kAAX_ProcPtrID_Create_HostProcessor = 3, kAAX_ProcPtrID_Create_MixerParameters = 4,
  kAAX_ProcPtrID_Create_EffectDirectData = 5
Typedef Documentation
typedef IACFUnknown* AAX_CALLBACK* AAXCreateObjectProc(void)
typedef AAX_Component<void>::CProcessProc AAX_CProcessProc
iContextPtrsBegin
A vector of context pointers. Each element points to the context for one instance of this component. iContextPtrsEnd gives the upper bound of the vector and (inContextPtrsEnd - inContextPtrsBegin) gives the count.
iContextPtrsEnd
The upper bound of the vector at iContextPtrsBegin. (inContextPtrsEnd - iContextPtrsBegin) gives the count of this vector.
The instance vector was originally NULL-terminated in earlier versions of this API. However, the STL-style begin/end pattern was suggested as a more general representation that could, for instance, allow a vector to be split for parallel processing.
typedef AAX_Component<void>::CPacketAllocator AAX_CPacketAllocator
Deprecated:
A AAX_CProcessProc that calls AAX_SchedulePacket() must include a AAX_CPacketAllocator field in its context and register that field with AAX. AAX will then populate that field with a AAX_CPacketAllocator to pass to AAX_SchedulePacket().
See Also
typedef AAX_Component<void>::CInstanceInitProc AAX_CInstanceInitProc
This optional callback allows the component to keep per-instance data. It's called before the instance appears in the list supplied to CProcessProc, and then after the instance is removed from the list.
iInstanceContextPtr
A pointer to the context data structure of the instance being added or removed from the processing list.
iAction
Indicates the action that triggered the init callback, e.g. whether the instance is being added or removed.
Return values
Shouldreturn 0 on success, anything else on failure. Failure will prevent the instance from being created.
typedef AAX_Component<void>::CBackgroundProc AAX_CBackgroundProc
This optional callback allows the component to do background processing in whatever manner the plug-in developer desires
Return values
Shouldreturn 0 on success, anything else on failure. Failure will cause the AAX host to signal an error up the callchain.
typedef AAX_Component<void>::CInitPrivateDataProc AAX_CInitPrivateDataProc
Deprecated:
A component that requires private data supplies AAX_CInitPrivateDataProc callbacks to set its private data to the state it should be in at the start of audio. The component first declares one or more pointers to private data in its context. It then registers each such field with AAX along with its data size, various other attributes, and a AAX_CInitPrivateDataProc. The AAX_CInitPrivateDataProc always runs on the host system, not the DSP. AAX allocates storage for each private data block and calls its associated AAX_CInitPrivateDataProc to initialize it. If the component's AAX_CProcessProc runs on external hardware, AAX initializes private data blocks on the host system and copies them to the remote system.
See Also
alg_pd_init
inFieldIndex
The port ID of the block to be initialized, as generated by AAX_FIELD_INDEX(). A component can register a separate AAX_CInitPrivateDataProc for each of its private data blocks, or it can use fewer functions that switch on iFieldIndex.
inNewBlock
A pointer to the block to be initialized. If the component runs externally, AAX will copy this block to the remote system after it is initialized.
inSize
The size of the block to be initialized. If a component has multiple private blocks that only need to be zeroed out, say, it can use a single AAX_CInitPrivateDataProc for all of these blocks that zeroes them out according to iSize.
inController
A pointer to the current Effect instance's AAX_IController.
Note
Do not directly reference data from this interface when populating iNewBlock. The data in this block must be fully self-contained to ensure portability to a new device or memory space.
Deprecated:
Enumeration Type Documentation
Enumerator
AAX_IEffectParameters creation procedure.
AAX_IEffectGUI creation procedure.
AAX_IHostProcessor creation procedure.
AAX_IMixerParameters creation procedure, used by PIs that want ramped timestamp control changes.
AAX_IEffectDirectData creation procedure, used by PIs that want direct access to their alg memory.
