AAX SDK  2.1.1
AAX_IEffectGUI Class Reference
#include <AAX_IEffectGUI.h>
Inheritance diagram for AAX_IEffectGUI:
Inheritance graph
[legend]
Collaboration diagram for AAX_IEffectGUI:
Collaboration graph
[legend]
Description
The interface for a AAX Plug-in's user interface.
:Implemented by the Plug-In:
This is the interface for an instance of a plug-in's GUI that gets exposed to the host application. You need to inherit from this interface and override all of the virtual functions to create a plug-in GUI.
To create the GUI for an AAX plug-in it is required that you inherit from this interface and override all of the virtual functions from AAX_IACFEffectGUI. In nearly all cases you will be able to take advantage of the implementations in the AAX library's AAX_CEffectGUI class and only override the few specific methods that you want to explicitly customize.
Note
This class always inherits from the latest version of the interface and thus requires any subclass to implement all the methods in the latest version of the interface.
Public Member Functions
ACFMETHOD() InternalQueryInterface (const acfIID &riid, void **ppvObjOut)
- Public Member Functions inherited from AAX_IACFEffectGUI
virtual AAX_Result Initialize (IACFUnknown *iController)=0
 Main GUI initialization. More...
virtual AAX_Result Uninitialize ()=0
 Main GUI uninitialization. More...
virtual AAX_Result NotificationReceived (AAX_CTypeID iNotificationType, const void *iNotificationData, uint32_t iNotificationDataSize)=0
 Notification Hook. More...
virtual AAX_Result SetViewContainer (IACFUnknown *iViewContainer)=0
 Provides a handle to the main plug-in window. More...
virtual AAX_Result GetViewSize (AAX_Point *oViewSize) const =0
 Retrieves the size of the plug-in window. More...
virtual AAX_Result Draw (AAX_Rect *iDrawRect)=0
 DEPRECATED, Not called from host any longer. Your chosen graphics framework should be directly handling draw events from the OS. More...
virtual AAX_Result TimerWakeup ()=0
 Periodic wakeup callback for idle-time operations. More...
virtual AAX_Result ParameterUpdated (AAX_CParamID iParamID)=0
 Notifies the GUI that a parameter value has changed. More...
virtual AAX_Result GetCustomLabel (AAX_EPlugInStrings iSelector, AAX_IString *oString) const =0
 Called by host application to retrieve a custom plug-in string. More...
virtual AAX_Result SetControlHighlightInfo (AAX_CParamID iParameterID, AAX_CBoolean iIsHighlighted, AAX_EHighlightColor iColor)=0
 Called by host application. Indicates that a control widget should be updated with a highlight color. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
ACFMETHOD() AAX_IEffectGUI::InternalQueryInterface ( const acfIID &  riid,
void **  ppvObjOut
