AAX SDK  2.1.1
AAX_IController Class Referenceabstract
#include <AAX_IController.h>
Inheritance diagram for AAX_IController:
Inheritance graph
[legend]
Description
Interface for the AAX host's view of a single instance of an effect. Used by both clients of the AAX host and by effect components.
:Implemented by the AAX Host:
Public Member Functions
virtual ~AAX_IController (void)
virtual AAX_Result GetHybridSignalLatency (int32_t *oSamples) const =0
 CALL: Returns the latency between the algorithm normal input samples and the inputs returning from the hyrbid component. More...
virtual AAX_Result GetCurrentAutomationTimestamp (AAX_CTransportCounter *oTimestamp) const =0
 CALL: Returns the current automation timestamp if called during the GenerateCoefficients() call AND the generation of coefficients is being triggered by an automation point instead of immediate changes. More...
virtual AAX_Result GetHostName (AAX_IString *oHostNameString) const =0
 CALL: Returns name of the host application this plug-in instance is being loaded by. This string also typically includes version information. More...
Host information getters
Call these methods to retrieve environment and run-time information from the AAX host.
virtual AAX_Result GetEffectID (AAX_IString *oEffectID) const =0
virtual AAX_Result GetSampleRate (AAX_CSampleRate *oSampleRate) const =0
 CALL: Returns the current literal sample rate. More...
virtual AAX_Result GetInputStemFormat (AAX_EStemFormat *oStemFormat) const =0
 CALL: Returns the plug-in's input stem format. More...
virtual AAX_Result GetOutputStemFormat (AAX_EStemFormat *oStemFormat) const =0
 CALL: Returns the plug-in's output stem format. More...
virtual AAX_Result GetSignalLatency (int32_t *oSamples) const =0
 CALL: Returns the most recent signal (algorithmic) latency that has been published by the plug-in. More...
virtual AAX_Result GetCycleCount (AAX_EProperty iWhichCycleCount, AAX_CPropertyValue *oValue) const =0
 CALL: returns the plug-in's current real-time DSP cycle count. More...
virtual AAX_Result GetTODLocation (AAX_CTimeOfDay *oTODLocation) const =0
 CALL: Returns the current Time Of Day (TOD) of the system. More...
Host information setters
Call these methods to set dynamic plug-in run-time information on the AAX host.
virtual AAX_Result SetSignalLatency (int32_t iNumSamples)=0
 CALL: Submits a request to change the delay compensation value that the host uses to account for the plug-in's signal (algorithmic) latency. More...
virtual AAX_Result SetCycleCount (AAX_EProperty *iWhichCycleCounts, AAX_CPropertyValue *iValues, int32_t oNumValues)=0
 CALL: Indicates a change in the plug-in's real-time DSP cycle count. More...
Posting methods
Call these methods to post new plug-in information to the host's data management system.
virtual AAX_Result PostPacket (AAX_CFieldIndex iFieldIndex, const void *iPayloadP, uint32_t iPayloadSize)=0
 CALL: Posts a data packet to the host for routing between plug-in components. More...
Notification methods
Call these methods to send events among plug-in components
virtual AAX_Result SendNotification (AAX_CTypeID iNotificationType, const void *iNotificationData, uint32_t iNotificationDataSize)=0
 CALL: Sends an event to the GUI. More...
Metering methods
Methods to access the plug-in's host-managed metering information.
See Also
Plug-in meters
virtual AAX_Result GetCurrentMeterValue (AAX_CTypeID iMeterID, float *oMeterValue) const =0
 CALL: Retrieves the current value of a host-managed plug-in meter. More...
virtual AAX_Result GetMeterPeakValue (AAX_CTypeID iMeterID, float *oPeakValue) const =0
 CALL: Retrieves the currently held peak value of a host-managed plug-in meter. More...
virtual AAX_Result ClearMeterPeakValue (AAX_CTypeID iMeterID) const =0
 CALL: Clears the peak value from a host-managed plug-in meter. More...
virtual AAX_Result GetMeterCount (uint32_t *oMeterCount) const =0
 CALL: Retrieves the number of host-managed meters registered by a plug-in. More...
virtual AAX_Result GetMeterClipped (AAX_CTypeID iMeterID, AAX_CBoolean *oClipped) const =0
 CALL: Retrieves the clipped flag from a host-managed plug-in meter. More...
virtual AAX_Result ClearMeterClipped (AAX_CTypeID iMeterID) const =0
 CALL: Clears the clipped flag from a host-managed plug-in meter. More...
MIDI methods
Methods to access the plug-in's host-managed MIDI information.
virtual AAX_Result GetNextMIDIPacket (AAX_CFieldIndex *oPort, AAX_CMidiPacket *oPacket)=0
 CALL: Retrieves MIDI packets for described MIDI nodes. More...
Constructor & Destructor Documentation
virtual AAX_IController::~AAX_IController ( void  )
inlinevirtual
Member Function Documentation
virtual AAX_Result AAX_IController::GetEffectID ( AAX_IString *  oEffectID) const
pure virtual
Implemented in AAX_VController.
virtual AAX_Result AAX_IController::GetSampleRate ( AAX_CSampleRate *  oSampleRate) const
pure virtual
Parameters
[out]oSampleRateThe current sample rate
virtual AAX_Result AAX_IController::GetInputStemFormat ( AAX_EStemFormat *  oStemFormat) const
pure virtual
Parameters
[out]oStemFormatThe current input stem format
virtual AAX_Result AAX_IController::GetOutputStemFormat ( AAX_EStemFormat *  oStemFormat) const
pure virtual
Parameters
[out]oStemFormatThe current output stem format
virtual AAX_Result AAX_IController::GetSignalLatency ( int32_t *  oSamples) const
pure virtual
This method provides the most recently published signal latency. The host may not have updated its delay compensation to match this signal latency yet, so plug-ins that dynamically change their latency using SetSignalLatency() should always wait for an AAX_eNotificationEvent_SignalLatencyChanged notification before updating its algorithm to incur this latency.
See Also
SetSignalLatency()
Parameters
[out]oSamplesThe number of samples of signal delay published by the plug-in
virtual AAX_Result AAX_IController::GetCycleCount ( AAX_EProperty  iWhichCycleCount,
AAX_CPropertyValue *  oValue
) const
pure virtual
This method provides the number of cycles that the AAX host expects the DSP plug-in to consume. The host uses this value when allocating DSP resources for the plug-in.
Note
A plug-in should never apply a DSP algorithm with more demanding resource requirements than what is currently accounted for by the host. To set a higher cycle count value, a plug-in must call AAX_IController::SetCycleCount(), then poll AAX_IController::GetCycleCount() until the new value has been applied. Once the host has recognized the new cycle count value, the plug-in may apply the more demanding algorithm.
Parameters
[in]iWhichCycleCountSelector for the requested cycle count metric. One of:
[in]oValueThe current value of the selected cycle count metric
Todo:
PLACEHOLDER - NOT CURRENTLY IMPLEMENTED IN HOST
virtual AAX_Result AAX_IController::GetTODLocation ( AAX_CTimeOfDay *  oTODLocation) const
pure virtual
This method provides a plug-in the TOD (in samples) of the current system.
Parameters
[out]oTODLocationThe current Time Of Day as set by the host
virtual AAX_Result AAX_IController::SetSignalLatency ( int32_t  iNumSamples)
pure virtual
This method is used to request a change in the number of samples that the AAX host expects the plug-in to delay a signal.
The host is not guaranteed to immediately apply the new latency value. A plug-in should avoid incurring an actual algorithmic latency that is different than the latency accounted for by the host.
To set a new latency value, a plug-in must call AAX_IController::SetSignalLatency(), then wait for an AAX_eNotificationEvent_SignalLatencyChanged notification. Once this notification has been received, AAX_IController::GetSignalLatency() will reflect the updated latency value and the plug-in should immediately apply any relevant algorithmic changes that alter its latency to this new value.
Parameters
[in]iNumSamplesThe number of samples of signal delay that the plug-in requests to incur
virtual AAX_Result AAX_IController::SetCycleCount ( AAX_EProperty *  iWhichCycleCounts,
AAX_CPropertyValue *  iValues,
int32_t  oNumValues
pure virtual
This method is used to request a change in the number of cycles that the AAX host expects the DSP plug-in to consume.
Note
Parameters
[in]iWhichCycleCountsArray of selectors indicating the specific cycle count metrics that should be set. Each selector must be one of:
[in]iValuesAn array of values requested, one for each of the selected cycle count metrics.
[out]oNumValuesThe number of values provided
Todo:
virtual AAX_Result AAX_IController::PostPacket ( AAX_CFieldIndex  iFieldIndex,
const void *  iPayloadP,
pure virtual
The posted packet is identified with a AAX_CFieldIndex packet index value, which is equivalent to the target data port's identifier. The packet's payload must have the expected size for the given packet index / data port, as defined when the port is created in Describe. See AAX_IComponentDescriptor::AddDataInPort().
Parameters
[in]iFieldIndexThe packet's destination port
[in]iPayloadPA pointer to the packet's payload data
[in]iPayloadSizeThe size, in bytes, of the payload data
virtual AAX_Result AAX_IController::SendNotification ( AAX_CTypeID  iNotificationType,
const void *  iNotificationData,
pure virtual
This is supported by AAX V2 Hosts only. Check the return code on the return of this function. If the error is AAX_ERROR_UNIMPLEMENTED, your plug-in is being loaded into a host that doesn't support this feature.
Parameters
[in]iNotificationTypeType of notification to send
[in]iNotificationDataBlock of notification data
[in]iNotificationDataSizeSize of iNotificationData, in bytes
virtual AAX_Result AAX_IController::GetCurrentMeterValue ( AAX_CTypeID  iMeterID,
float *  oMeterValue
) const
pure virtual
Parameters
[in]iMeterIDID of the meter that is being queried
[out]oMeterValueThe queried meter's current value
virtual AAX_Result AAX_IController::GetMeterPeakValue ( AAX_CTypeID  iMeterID,
float *  oPeakValue
) const
pure virtual
Parameters
[out]oPeakValueThe queried meter's currently held peak value
virtual AAX_Result AAX_IController::ClearMeterPeakValue ( AAX_CTypeID  iMeterID) const
pure virtual
Parameters
[in]iMeterIDID of the meter that is being cleared
virtual AAX_Result AAX_IController::GetMeterCount ( uint32_t *  oMeterCount) const
pure virtual
See AAX_IComponentDescriptor::AddMeters().
Parameters
[out]oMeterCountThe number of registered plug-in meters.
virtual AAX_Result AAX_IController::GetMeterClipped ( AAX_CTypeID  iMeterID,
AAX_CBoolean *  oClipped
) const
pure virtual
Parameters
[in]iMeterIDID of the meter that is being queried.
[out]oClippedThe queried meter's clipped flag.
virtual AAX_Result AAX_IController::ClearMeterClipped ( AAX_CTypeID  iMeterID) const
pure virtual
Parameters
[in]iMeterIDID of the meter that is being cleared.
virtual AAX_Result AAX_IController::GetNextMIDIPacket ( AAX_CFieldIndex *  oPort,
AAX_CMidiPacket *  oPacket
pure virtual
Parameters
[out]oPortport ID of the MIDI node that has unhandled packet
[out]oPacketThe MIDI packet
virtual AAX_Result AAX_IController::GetCurrentAutomationTimestamp ( AAX_CTransportCounter *  oTimestamp) const
pure virtual
Note
This function will return 0 if called from outside of GenerateCoefficients() or if the GenerateCoefficients() call was initiated due to a non-automated change. In those cases, you can get your sample offset from the transport start using getTODLocation().
Parameters
[out]oTimestampThe current coefficient timestamp. Sample count from transport start.
virtual AAX_Result AAX_IController::GetHostName ( AAX_IString *  oHostNameString) const
pure virtual
Parameters
[out]oHostNameStringThe name of the current host application.
