AAX SDK  2.1.1
AAX_VEffectDescriptor Class Reference
#include <AAX_VEffectDescriptor.h>
Inheritance diagram for AAX_VEffectDescriptor:
Inheritance graph
[legend]
Collaboration diagram for AAX_VEffectDescriptor:
Collaboration graph
[legend]
Description
Version-managed concrete AAX_IEffectDescriptor class.
Public Member Functions
 AAX_VEffectDescriptor (IACFUnknown *pUnkHost)
virtual ~AAX_VEffectDescriptor ()
virtual AAX_IComponentDescriptor * NewComponentDescriptor ()
 Create an instance of a component descriptor. More...
virtual AAX_Result AddComponent (AAX_IComponentDescriptor *inComponentDescriptor)
 Add a component to an instance of a component descriptor. More...
virtual AAX_Result AddName (const char *inPlugInName)
 Add a name to the Effect. More...
virtual AAX_Result AddCategory (uint32_t inCategory)
 Add a category to your plug-in. See AAX_EPlugInCategory. More...
virtual AAX_Result AddCategoryBypassParameter (uint32_t inCategory, AAX_CParamID inParamID)
virtual AAX_Result AddProcPtr (void *inProcPtr, AAX_CProcPtrID inProcID)
 Add a process pointer. More...
virtual AAX_IPropertyMap * NewPropertyMap ()
 Create a new property map. More...
virtual AAX_Result SetProperties (AAX_IPropertyMap *inProperties)
 Set the properties of a new property map. More...
virtual AAX_Result AddResourceInfo (AAX_EResourceType inResourceType, const char *inInfo)
 Set resource file info. More...
virtual AAX_Result AddMeterDescription (AAX_CTypeID inMeterID, const char *inMeterName, AAX_IPropertyMap *inProperties)
 Add name and property map to meter with given ID. More...
virtual AAX_Result AddControlMIDINode (AAX_CTypeID iNodeID, AAX_EMIDINodeType iNodeType, const char iNodeName[], uint32_t channelMask)
 Add control MIDI node. More...
IACFUnknown * GetIUnknown (void) const
- Public Member Functions inherited from AAX_IEffectDescriptor
virtual ~AAX_IEffectDescriptor ()
Constructor & Destructor Documentation
AAX_VEffectDescriptor::AAX_VEffectDescriptor ( IACFUnknown *  pUnkHost)
virtual AAX_VEffectDescriptor::~AAX_VEffectDescriptor ( )
virtual
Member Function Documentation
virtual AAX_IComponentDescriptor* AAX_VEffectDescriptor::NewComponentDescriptor ( )
virtual
This implementation retains each generated AAX_IComponentDescriptor and destroys the property map upon AAX_VEffectDescriptor destruction
Implements AAX_IEffectDescriptor.
virtual AAX_Result AAX_VEffectDescriptor::AddComponent ( AAX_IComponentDescriptor *  iComponentDescriptor)
virtual
Unlike with AAX_ICollection::AddEffect(), the AAX_IEffectDescriptor does not take ownership of the AAX_IComponentDescriptor that is passed to it in this method. The host copies out the contents of this descriptor, and thus the plug-in may re-use the same descriptor object when creating additional similar components.
Parameters
[in]iComponentDescriptor
virtual AAX_Result AAX_VEffectDescriptor::AddName ( const char *  iPlugInName)
virtual
May be called multiple times to add abbreviated Effect names.
Note
Every Effect must include at least one name variant with 31 or fewer characters, plus a null terminating character
Parameters
[in]iPlugInNameThe name assigned to the plug-in.
virtual AAX_Result AAX_VEffectDescriptor::AddCategory ( uint32_t  iCategory)
virtual
Parameters
[in]iCategoryOne of the categories for the plug-in.
virtual AAX_Result AAX_VEffectDescriptor::AddCategoryBypassParameter ( uint32_t  iCategory,
AAX_CParamID  iParamID
virtual
Parameters
[in]iParamIDThe parameter ID of the parameter used to bypass the category seciont of the plug-in.
virtual AAX_Result AAX_VEffectDescriptor::AddProcPtr ( void *  iProcPtr,
AAX_CProcPtrID  iProcID
virtual
Parameters
[in]iProcPtrA process pointer.
[in]iProcIDA process ID.
virtual AAX_IPropertyMap* AAX_VEffectDescriptor::NewPropertyMap ( )
virtual
This implementation retains each generated AAX_IPropertyMap and destroys the property map upon AAX_VEffectDescriptor destruction
virtual AAX_Result AAX_VEffectDescriptor::SetProperties ( AAX_IPropertyMap *  iProperties)
virtual
Parameters
[in]iPropertiesDescription
virtual AAX_Result AAX_VEffectDescriptor::AddResourceInfo ( AAX_EResourceType  iResourceType,
const char *  iInfo
virtual
Parameters
[in]iResourceTypeSee AAX_EResourceType.
[in]iInfoDefinition varies on the resource type.
virtual AAX_Result AAX_VEffectDescriptor::AddMeterDescription ( AAX_CTypeID  iMeterID,
const char *  iMeterName,
virtual
Parameters
[in]iMeterIDThe ID of the meter being described.
[in]iMeterNameThe name of the meter.
[in]iPropertiesThe property map containing meter related data such as meter type, orientation, etc.
virtual AAX_Result AAX_VEffectDescriptor::AddControlMIDINode ( AAX_CTypeID  iNodeID,
uint32_t  iChannelMask
virtual
Parameters
[in]iNodeIDThe ID for the new control MIDI node.
[in]iNodeTypeThe type of the node.
[in]iNodeNameThe name of the node.
[in]iChannelMaskThe bit mask for required nodes channels (up to 16) or required global events for global node.
IACFUnknown* AAX_VEffectDescriptor::GetIUnknown ( void  ) const
