AAX SDK  2.1.1
List of all members | Public Attributes
AAX_CMidiStream Struct Reference
#include <AAX.h>
Collaboration diagram for AAX_CMidiStream:
Collaboration graph
[legend]
Description
MIDI stream data structure used by AAX_IMIDINode.
For MIDI input, mBufferSize is set by the AAX host when the buffer is filled.
For MIDI output, the plug-in sets mBufferSize with the number of AAX_CMidiPacket objects it has filled mBuffer with. The AAX host will reset mBufferSize to 0 after it has received the buffer of MIDI.
System Exclusive (SysEx) messages that are greater than 4 bytes in length can be transmitted via a series of concurrent AAX_CMidiPacket objects in mBuffer. In accordance with the MIDI Specification, 0xF0 indicates the beginning of a SysEx message and 0xF7 indicates its end.
Legacy Porting Notes:
Corresponds to DirectMidiNode in the legacy SDK
Public Attributes
uint32_t mBufferSize
 The number of AAX_CMidiPacket objects contained in the node's buffer. More...
AAX_CMidiPacket * mBuffer
 Pointer to the first element of the node's buffer. More...
Member Data Documentation
uint32_t AAX_CMidiStream::mBufferSize
AAX_CMidiPacket* AAX_CMidiStream::mBuffer
The documentation for this struct was generated from the following file:
