AAX SDK
2.1.1
UpdateAllParameterViews() or another name that does not lead to confusion regarding what exactly this method should be doing. REMOVE THIS METHOD (?)
NOT CURRENTLY CALLED FROM THE HOST. USEFUL FOR INTERNAL USE ONLY?
Add information about Hybrid compatibility with AudioSuite or offline processing (PTSW-185422)
Document what exactly the fixed delay is between samples from the Hybrid context and samples from the signal net
Document whether the hybrid render method will always be invoked with the same buffer size (1024 samples)
Document use of AAX_IController::GetHybridSignalLatency
1.8.5
