AAX SDK  2.1.1
AAX_CEffectDirectData Class Reference
#include <AAX_CEffectDirectData.h>
Inheritance diagram for AAX_CEffectDirectData:
Inheritance graph
[legend]
Collaboration diagram for AAX_CEffectDirectData:
Collaboration graph
[legend]
Description
Default implementation of the AAX_IEffectDirectData interface.
This class provides a default implementation of the AAX_IEffectDirectData interface.
Public Member Functions
 AAX_CEffectDirectData (void)
virtual ~AAX_CEffectDirectData (void)
Initialization and uninitialization
AAX_Result Initialize (IACFUnknown *iController)
 Non-virtual implementation of AAX_IEfectDirectData::Initialize() More...
virtual AAX_Result Uninitialize (void)
 Main uninitialization. More...
Data update callbacks
AAX_Result TimerWakeup (IACFUnknown *iDataAccessInterface)
 Non-virtual implementation of AAX_IEfectDirectData::TimerWakeup() More...
Private member accessors
AAX_IController * Controller (void)
 Returns a pointer to the plug-in's controller interface. More...
AAX_IEffectParameters * EffectParameters (void)
 Returns a pointer to the plug-in's data model interface. More...
- Public Member Functions inherited from AAX_IEffectDirectData
ACFMETHOD() InternalQueryInterface (const acfIID &riid, void **ppvObjOut)
Safe data update callbacks
These callbacks provide a safe context from which to directly access the algorithm's private data blocks. Each callback is called regularly with roughly the schedule of its corresponding AAX_IEffectParameters counterpart.
Note
Do not attempt to directly access the algorithm's data from outside these callbacks. Instead, use the packet system to route data to the algorithm using the AAX host's buffered data transfer facilities.
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Protected Member Functions
AAX_CEffectDirectData virtual interface
virtual AAX_Result Initialize_PrivateDataAccess ()
 Initialization routine for classes that inherit from AAX_CEffectDirectData. This method is called by the default Initialize() implementation after all internal members have been initialized, and provides a safe location in which to perform any additional initialization tasks. More...
virtual AAX_Result TimerWakeup_PrivateDataAccess (AAX_IPrivateDataAccess *iPrivateDataAccess)
 Callback provided with an AAX_IPrivateDataAccess. Override this method to access the algorithm's private data using the AAX_IPrivateDataAccess interface. More...
Constructor & Destructor Documentation
AAX_CEffectDirectData::AAX_CEffectDirectData ( void  )
virtual AAX_CEffectDirectData::~AAX_CEffectDirectData ( void  )
virtual
Member Function Documentation
AAX_Result AAX_CEffectDirectData::Initialize ( IACFUnknown *  iController)
virtual
This implementation initializes all private AAX_CEffectDirectData members and calls Initialize_PrivateDataAccess(). For custom initialization, inherited classes should override Initialize_PrivateDataAccess().
Parameters
[in]iControllerUnknown pointer that resolves to an AAX_IController.
Implements AAX_IACFEffectDirectData.
virtual AAX_Result AAX_CEffectDirectData::Uninitialize ( void  )
virtual
Called when the interface is destroyed.
AAX_Result AAX_CEffectDirectData::TimerWakeup ( IACFUnknown *  iDataAccessInterface)
virtual
This implementation interprets the IACFUnknown and forwards the resulting AAX_IPrivateDataAccess to TimerWakeup_PrivateDataAccess()
Parameters
[in]iDataAccessInterfaceUnknown pointer that resolves to an AAX_IPrivateDataAccess. This interface is only valid for the duration of this method's execution and is discarded when the method returns.
AAX_IController* AAX_CEffectDirectData::Controller ( void  )
Todo:
Change to GetController to match other AAX_CEffect modules
AAX_IEffectParameters* AAX_CEffectDirectData::EffectParameters ( void  )
Todo:
virtual AAX_Result AAX_CEffectDirectData::Initialize_PrivateDataAccess ( )
protectedvirtual
virtual AAX_Result AAX_CEffectDirectData::TimerWakeup_PrivateDataAccess ( AAX_IPrivateDataAccess *  iPrivateDataAccess)
protectedvirtual
Parameters
[in]iPrivateDataAccessPointer to an AAX_IPrivateDataAccess interface. This interface is only valid for the duration of this method.
