AAX SDK
2.1.1
Supported features in each AAX host.
| Pro Tools | VENUE S3L System | ||||
| 10.0.0 | 11.0 | 11.1 | 4.1.0 | ||
| AAX Native | X | X | X | ||
| AAX DSP | X | X | X | X | |
| AAX Hybrid | * | X | |||
| Offline processing (AudioSuite) | X | X | X | ||
| Surround Stem Formats | X | X | X | ||
ProcessProc / data model co-location constraint | X | X | X | ||
Monolithic native component topology constraint | X | X | X | X | |
| 10.0.0 | 10.3.7 | 11.0.0 | 4.1.0 | ||
| AAX_IACFCollection | X | X | X | X | |
| AAX_IACFComponentDescriptor | X | X | X | X | |
| V2 | X | ||||
| AAX_IACFEffectDescriptor | X | X | X | X | |
| V2 | X | ||||
| AAX_IACFPropertyMap | X | X | X | X | |
| V2 | X | ||||
| 10.0.0 | 10.3.7 | 11.0.0 | 4.1 | ||
| AAX_IACFAutomationDelegate | X | X | X | X | |
| AAX_IACFController | X | X | X | X | |
| V2 | X | ||||
| AAX_IACFEffectDirectData | X | X | X | X | |
| AAX_IACFEffectGUI | X | X | X | X | |
| AAX_IACFEffectParameters | X | X | X | X | |
| V2 | X | ||||
| AAX_IACFHostProcessor | X | X | X | ||
| AAX_IACFHostProcessorDelegate | X | X | X | ||
| V2 | X | ||||
| AAX_IACFHostServices | X | X | X | X | |
| AAX_IACFPrivateDataAccess | X | X | X | X | |
| AAX_IACFTransport | X | X | X | ||
| V2 | X | X | |||
| AAX_IACFViewContainer | X | X | X | X | |
| Pro Tools | VENUE S3L System | |||||
| 10.0 | 10.3.8 | 11.0 | 11.1 | 4.1.0 | ||
| Plug-in type conversion | X | * | X | |||
As of Pro Tools 10.2, DAE will check for a matching parameter NAME and not an ID when reading in automation data from a session saved with an AAX plug-ins RTAS/TDM counter part.
As of Pro Tools 11.1, AAE will first try to match ID. If that fails, AAE will fall back to matching by Name.
aChunkP then the plug-in's Compare Light will be illuminated in the plug-in header, allowing users to toggle between the plug-in's custom state and its saved state. There is a hard limit to the number of outputs that Pro Tools supports for a single plug-in instance. This limit is currently set at 256 channels, which includes all of the plug-in's output channels in addition to the sum total of all of its aux output stem channels.
Pro Tools supports only mono and stereo auxiliary output stem formats
Pro Tools 11 requires PACE Eden digital signatures for AAX plug-ins.
Pro Tools 10 requires either PACE DSig or Eden digital signatures for AAX plug-ins.
As of Pro Tools 10.2, support has been added to allow binary-level encryption of AAX DSP algorithms. Please note that this is NOT a requirement of AAX DSP plug-ins, and serves only as an additional security measure to protect an algorithm’s DLL.
In Pro Tools 11 and above, the Avid Audio Engine (AAE) no longer automatically generates clipping indication for plug-ins. This is because the new engine can operate properly well beyond a unity sample value of 1.0. Thus, it is up to the plug-in itself to set and clear its clip indicators as needed.
32 and 64-sample quantum is available in Pro Tools 10.2 and higher
Beginning in Pro Tools 11, AAX DSP algorithms also support optional temporary data spaces that can be described in the Describe module and are shared among all instances on a DSP. This is an alternative to declaring large data blocks on the stack for better memory management and to prevent stack overflows. Please refer to AAX_IComponentDescriptor::AddTemporaryData() for usage instructions.
Beginning with Pro Tools 10.2, the TI shell supports a "processor affinity" property, which indicates that a DSP ProcessProc should be preferentially loaded onto the same DSP as other instances from the same DLL binary. This is a requirement for some designs that must share global data between different processing configurations.
Note that this property should only be used when absolutely required, as it will constrain the DSP manager and reduce overall DSP plug-in instance counts on the system.
*The plug-in's binary filename must not contain any spaces. There is a bug in Pro Tools that will prevent binaries with spaces from being loaded properly. This is logged as PTSW-189928.
*_ACFGetSDKVersion is required for 64-bit AAX plug-ins only
1.8.5
