AAX SDK  2.1.1
List of all members
AAX_IACFViewContainer Class Referenceabstract
#include <AAX_IACFViewContainer.h>
Inheritance diagram for AAX_IACFViewContainer:
Inheritance graph
[legend]
Collaboration diagram for AAX_IACFViewContainer:
Collaboration graph
[legend]
Description
Interface for the AAX host's view of a single instance of an effect. Used by both clients of the host app and by effect components.
See Also
AAX_IViewContainer
Public Member Functions
View and GUI state queries
virtual int32_t GetType ()=0
 Returns the raw view type as one of AAX_EViewContainer_Type. More...
virtual void * GetPtr ()=0
 Returns a pointer to the raw view. More...
virtual AAX_Result GetModifiers (uint32_t *oModifiers)=0
 Queries the host for the current modifier keys. More...
View change requests
virtual AAX_Result SetViewSize (AAX_Point &iSize)=0
 Request a change to the main view size. More...
Host event handlers
virtual AAX_Result HandleParameterMouseDown (AAX_CParamID iParamID, uint32_t iModifiers)=0
 Alert the host to a mouse down event. More...
virtual AAX_Result HandleParameterMouseDrag (AAX_CParamID iParamID, uint32_t iModifiers)=0
 Alert the host to a mouse drag event. More...
virtual AAX_Result HandleParameterMouseUp (AAX_CParamID iParamID, uint32_t iModifiers)=0
 Alert the host to a mouse up event. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
virtual int32_t AAX_IACFViewContainer::GetType ( )
pure virtual
virtual void* AAX_IACFViewContainer::GetPtr ( )
pure virtual
virtual AAX_Result AAX_IACFViewContainer::GetModifiers ( uint32_t *  oModifiers)
pure virtual
This method returns a bit mask with bits set for each of the currently active modifier keys. This method does not return the state of the AAX_eModifiers_SecondaryButton.
Host Compatibility Notes:
Although this method allows plug-ins to acquire the current state of the Windows key (normally blocked by Pro Tools), plug-ins should not use key combinations that require this key.
virtual AAX_Result AAX_IACFViewContainer::SetViewSize ( AAX_Point &  iSize)
pure virtual
Note
  • For compatibility with the smallest supported displays, plug-in GUI dimensions should not exceed 749x617 pixels, or 749x565 pixels for plug-ins with sidechain support.
Parameters
[in]iSizeThe new size to which the plug-in view should be set
virtual AAX_Result AAX_IACFViewContainer::HandleParameterMouseDown ( AAX_CParamID  iParamID,
uint32_t  iModifiers
pure virtual
Parameters
[in]iParamIDID of the parameter whose control is being edited
[in]iModifiersA bitmask of AAX_EModifiers values
virtual AAX_Result AAX_IACFViewContainer::HandleParameterMouseDrag ( AAX_CParamID  iParamID,
uint32_t  iModifiers
pure virtual
Parameters
virtual AAX_Result AAX_IACFViewContainer::HandleParameterMouseUp ( AAX_CParamID  iParamID,
uint32_t  iModifiers
pure virtual
Parameters
