AAX SDK  2.1.1
AAX_IACFComponentDescriptor Class Referenceabstract
#include <AAX_IACFComponentDescriptor.h>
Inheritance diagram for AAX_IACFComponentDescriptor:
Inheritance graph
[legend]
Collaboration diagram for AAX_IACFComponentDescriptor:
Collaboration graph
[legend]
Description
Versioned description interface for an AAX plug-in algorithm callback.
Public Member Functions
virtual AAX_Result Clear ()=0
 Clears the descriptor. More...
virtual AAX_Result AddReservedField (AAX_CFieldIndex iFieldIndex, uint32_t iFieldType)=0
 Subscribes a context field to host-provided services or information. More...
virtual AAX_Result AddAudioIn (AAX_CFieldIndex iFieldIndex)=0
 Subscribes an audio input context field. More...
virtual AAX_Result AddAudioOut (AAX_CFieldIndex iFieldIndex)=0
 Subscribes an audio output context field. More...
virtual AAX_Result AddAudioBufferLength (AAX_CFieldIndex iFieldIndex)=0
 Subscribes a buffer length context field. More...
virtual AAX_Result AddSampleRate (AAX_CFieldIndex iFieldIndex)=0
 Subscribes a sample rate context field. More...
virtual AAX_Result AddClock (AAX_CFieldIndex iFieldIndex)=0
 Subscribes a clock context field. More...
virtual AAX_Result AddSideChainIn (AAX_CFieldIndex iFieldIndex)=0
 Subscribes a side-chain input context field. More...
virtual AAX_Result AddDataInPort (AAX_CFieldIndex iFieldIndex, uint32_t iPacketSize, AAX_EDataInPortType iPortType)=0
 Adds a custom data port to the algorithm context. More...
virtual AAX_Result AddAuxOutputStem (AAX_CFieldIndex iFieldIndex, int32_t iStemFormat, const char iNameUTF8[])=0
 Adds an auxiliary output stem for a plug-in. More...
virtual AAX_Result AddPrivateData (AAX_CFieldIndex iFieldIndex, int32_t iDataSize, uint32_t iOptions=AAX_ePrivateDataOptions_DefaultOptions)=0
 Adds a private data port to the algorithm context. More...
virtual AAX_Result AddDmaInstance (AAX_CFieldIndex iFieldIndex, AAX_IDma::EMode iDmaMode)=0
 Adds a DMA field to the plug-in's context. More...
virtual AAX_Result AddMIDINode (AAX_CFieldIndex iFieldIndex, AAX_EMIDINodeType iNodeType, const char iNodeName[], uint32_t channelMask)=0
 Add your MIDI node objects as context fields. More...
virtual AAX_Result AddProcessProc_Native (AAX_CProcessProc iProcessProc, IACFUnknown *iProperties=NULL, AAX_CInstanceInitProc iInstanceInitProc=NULL, AAX_CBackgroundProc iBackgroundProc=NULL, AAX_CSelector *oProcID=NULL)=0
 Registers an algorithm processing entrypoint (process procedure) for the native architecture. More...
virtual AAX_Result AddProcessProc_TI (const char inDLLFileNameUTF8[], const char iProcessProcSymbol[], IACFUnknown *iProperties=NULL, const char iInstanceInitProcSymbol[]=NULL, const char iBackgroundProcSymbol[]=NULL, AAX_CSelector *oProcID=NULL)=0
virtual AAX_Result AddMeters (AAX_CFieldIndex iFieldIndex, const AAX_CTypeID *iMeterIDs, const uint32_t iMeterCount)=0
 Add a meter field to the plug-in's context. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
virtual AAX_Result AAX_IACFComponentDescriptor::Clear ( )
pure virtual
Clears the descriptor and readies it for the next algorithm description
virtual AAX_Result AAX_IACFComponentDescriptor::AddReservedField ( AAX_CFieldIndex  iFieldIndex,
uint32_t  iFieldType
pure virtual
Note
Currently for internal use only.
Parameters
[in]iFieldIndexUnique identifier for the field, generated using AAX_FIELD_INDEX
[in]iFieldTypeType of field that is being added
virtual AAX_Result AAX_IACFComponentDescriptor::AddAudioIn ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines an audio in port for host-provided information in the algorithm's context structure.
  • Data type: float**
  • Data kind: An array of float arrays, one for each input channel
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddAudioOut ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines an audio out port for host-provided information in the algorithm's context structure.
  • Data kind: An array of float arrays, one for each output channel
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddAudioBufferLength ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines a buffer length port for host-provided information in the algorithm's context structure.
  • Data type: int32_t*
  • Data kind: The number of samples in the current audio buffer
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddSampleRate ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines a sample rate port for host-provided information in the algorithm's context structure.
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddClock ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines a clock port for host-provided information in the algorithm's context structure.
  • Data type: AAX_CTimestamp *
  • Data kind: A running time counter which increments even when the transport is not playing.
Host Compatibility Notes:
As of Pro Tools 11.1, this field may be used in both Native and DSP plug-ins. The DSP clock data is a 16-bit cycling counter. This field was only available for Native plug-ins in previous Pro Tools versions.
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddSideChainIn ( AAX_CFieldIndex  iFieldIndex)
pure virtual
Defines a side-chain input port for host-provided information in the algorithm's context structure.
  • Data kind: The index of the plug-in's first side-chain input channel within the array of input audio buffers
Parameters
virtual AAX_Result AAX_IACFComponentDescriptor::AddDataInPort ( AAX_CFieldIndex  iFieldIndex,
pure virtual
Defines a read-only data port for plug-in information in the algorithm's context structure. The plug-in can send information to this port using AAX_IController::PostPacket().
The host guarantees that all packets will be delivered to this port in the order in which they were posted, up to the point of a packet buffer overflow.
Parameters
[in]iFieldIndexUnique identifier for the port, generated using AAX_FIELD_INDEX
[in]iPacketSizeSize of the data packets that will be sent to this port
[in]iPortTypeWhether or not the host should buffer this port
virtual AAX_Result AAX_IACFComponentDescriptor::AddAuxOutputStem ( AAX_CFieldIndex  iFieldIndex,
pure virtual
Use this method to add additional output channels to the algorithm context.
The aux output stem audio buffers will be added to the end of the audio outputs array in the order in which they are described. When writing audio data to a specific aux output, find the proper starting channel by accumulating all of the channels of the main output stem format and any previously-described aux output stems.
The plug-in is responsible for providing a meaningful name for each aux outputs. At the very least, individual outputs should be labeled "Output xx", where "xx" is the aux output number as it is defined in the plug-in. The output name should also include the words "mono" and "stereo" to support when users are looking for an output with a specific stem format.
There is a hard limit to the number of outputs that Pro Tools supports for a single plug-in instance. This limit is currently set at 256 channels, which includes all of the plug-in's output channels in addition to the sum total of all of its aux output stem channels.
Pro Tools supports only mono and stereo auxiliary output stem formats
Parameters
[in]iFieldIndexDEPRECATED: This parameter is no longer needed by the host, but is included in the interface for binary compatibility
[in]iStemFormatThe stem format of the new aux output
[in]iNameUTF8The name of the aux output. This name is static and cannot be changed after the descriptor is submitted to the host
virtual AAX_Result AAX_IACFComponentDescriptor::AddPrivateData ( AAX_CFieldIndex  iFieldIndex,
int32_t  iDataSize,
uint32_t  iOptions = AAX_ePrivateDataOptions_DefaultOptions
pure virtual
Defines a read/write data port for private state data. Data written to this port will be maintained by the host between calls to the algorithm context.
See Also
alg_pd_registration
Parameters
[in]iDataSizeSize of the data packets that will be sent to this port
[in]iOptionsOptions that define the private data port's behavior
virtual AAX_Result AAX_IACFComponentDescriptor::AddDmaInstance ( AAX_CFieldIndex  iFieldIndex,
pure virtual
DMA (direct memory access) provides efficient reads from and writes to external memory on the DSP. DMA behavior is emulated in host-based plug-ins for cross-platform portability.
Note
The order in which DMA instances are added defines their priority and therefore order of execution of DMA operations. In most plug-ins, Scatter fields should be placed first in order to achieve the lowest possible access latency.
Todo:
Update the DMA system management such that operation priority can be set arbitrarily
Parameters
[in]iDmaModeAAX_IDma::EMode that will apply to this field
virtual AAX_Result AAX_IACFComponentDescriptor::AddMIDINode ( AAX_CFieldIndex  iFieldIndex,
pure virtual
Due to current restrictions MIDI data won't be delivered to DSP algorithms, only to AAX Native.
Parameters
[in]iFieldIndexThe ID of the port. MIDI node ports should formatted as a pointer to an AAX_IMIDINode.
[in]iNodeTypeThe type of MIDI node, as AAX_EMIDINodeType
[in]iNodeNameThe name of the MIDI node as it should appear in the host's UI
[in]channelMaskThe channel mask for the MIDI node. This parameter specifies used MIDI channels. For Global MIDI nodes, use a mask of AAX_EMidiGlobalNodeSelectors
virtual AAX_Result AAX_IACFComponentDescriptor::AddProcessProc_Native ( AAX_CProcessProc  iProcessProc,
IACFUnknown *  iProperties = NULL,
AAX_CInstanceInitProc  iInstanceInitProc = NULL,
AAX_CBackgroundProc  iBackgroundProc = NULL,
AAX_CSelector *  oProcID = NULL
pure virtual
Parameters
[in]iProcessProcSymbol for this processing callback
[in]iPropertiesA property map for this processing callback. The property map's values are copied by the host and associated with the new ProcessProc. The property map contents are unchanged and the map may be re-used when registering additional ProcessProcs.
[in]iInstanceInitProcInitialization routine that will be called when a new instance of the Effect is created. See Algorithm initialization.
[in]iBackgroundProcBackground routine that will be called in an idle context within the same address space as the associated process procedure. See Background processing callback
[in]oProcID
Todo:
document this parameter
virtual AAX_Result AAX_IACFComponentDescriptor::AddProcessProc_TI ( const char  inDLLFileNameUTF8[],
const char  iInstanceInitProcSymbol[] = NULL,
const char  iBackgroundProcSymbol[] = NULL,
pure virtual
Parameters
[in]inDLLFileNameUTF8UTF-8 encoded filename for the ELF DLL containing the algorithm code fragment
[in]iProcessProcSymbolSymbol for this processing callback
[in]iInstanceInitProcSymbolInitialization routine that will be called when a new instance of the Effect is created. Must be included in the same DLL as the main algorithm entrypoint. See Algorithm initialization.
[in]iBackgroundProcSymbolBackground routine that will be called in an idle context within the same address space as the associated process procedure. Must be included in the same DLL as the main algorithm entrypoint. See Background processing callback
[in]oProcID
Todo:
virtual AAX_Result AAX_IACFComponentDescriptor::AddMeters ( AAX_CFieldIndex  iFieldIndex,
const AAX_CTypeID *  iMeterIDs,
pure virtual
Meter fields include an array of meter tap values, with one tap per meter per context. Only one meter field should be added per Component. Individual meter behaviors can be described at the Effect level.
For more information, see Plug-in meters .
Parameters
[in]iMeterIDsArray of 32-bit IDs, one for each meter. Meter IDs must be unique within the Effect.
[in]iMeterCountThe number of meters included in this field
