AAX SDK  2.1.1
Background processing callback
Background processing support for AAX DSP and Native plug-in algorithms.
On this page
Background thread description
Each algorithm render callback may optionally be associated with a background processing callback. This background callback will be triggered continuously in an idle context, and can be used to perform any background task required by the algorithm.
Restrictions and limitations of background threads
Background thread performance characteristics on DSP systems
The background processing callback is called from a true idle thread context. On DSP accelerated platforms, this means that the callback will be triggered continuously whenever the chip is not executing an interrupt, i.e. the algorithm render callback. Since the render callback's resource requirements are well-defined (or at least strictly bounded,) the background thread's available cycles are also deterministically bounded.
However, the background thread itself has a lower priority than the DSP shell. While the background callback's execution will not be interrupted by shell operations, it will be blocked in the event of a contention for memory resources with the shell. As a result, the number of memory operations that may be performed in this callback will be less well-defined when the host is consuming memory resources,e.g. when delivering a very large coefficient block to the DSP.
If your TDM plug-in does not perform any resource-intensive memory operations then you can assume a guaranteed performance level for its DSP background thread. Development tools are available that will test a plug-in by refreshing its entire context memory at every interrupt, and the background thread performance characteristics measured by these tools, plus an additional buffer to account for any pathological cases that may be missed by the performance check, should provide a guaranteed performance baseline for the background thread that will be completely safe for any Pro Tools operation scenario.
Background thread memory management
The background processing callback is not provided with any data pointers and does not have access to any facilities for managed communication with the rest of the plug-in. Therefore, the background process must use shared global data structures to interact with the render callback. Your plug-in will need to manually synchronize access to this data.
Usually the background callback will want to interact with the render callback via the algorithm's private data blocks. Therefore, private data blocks that are provided to an algorithm's context will not be relocated by the host between calls to the render callback, and background processes can reliably access this data once provided with a pointer. The same is not true for audio buffers, meters, coefficient ports, etc. - this data can all be relocated by the host when the render callback is not executing.
Collaboration diagram for Background processing callback:
