AAX SDK  2.1.1
AAX_IACFTransport Class Referenceabstract
#include <AAX_IACFTransport.h>
Inheritance diagram for AAX_IACFTransport:
Inheritance graph
[legend]
Collaboration diagram for AAX_IACFTransport:
Collaboration graph
[legend]
Description
Versioned interface to information about the host's transport state.
Public Member Functions
virtual AAX_Result GetCurrentTempo (double *TempoBPM) const =0
 CALL: Gets the current tempo. More...
virtual AAX_Result GetCurrentMeter (int32_t *MeterNumerator, int32_t *MeterDenominator) const =0
 CALL: Gets the current meter. More...
virtual AAX_Result IsTransportPlaying (bool *isPlaying) const =0
 CALL: Indicates whether or not the transport is playing back. More...
virtual AAX_Result GetCurrentTickPosition (int64_t *TickPosition) const =0
 CALL: Gets the current tick position. More...
virtual AAX_Result GetCurrentLoopPosition (bool *bLooping, int64_t *LoopStartTick, int64_t *LoopEndTick) const =0
 CALL: Gets current information on loop playback. More...
virtual AAX_Result GetCurrentNativeSampleLocation (int64_t *SampleLocation) const =0
 CALL: Gets the current playback location of the native audio engine. More...
virtual AAX_Result GetCustomTickPosition (int64_t *oTickPosition, int64_t iSampleLocation) const =0
 CALL: Given an absolute sample position, gets the corresponding tick position. More...
virtual AAX_Result GetBarBeatPosition (int32_t *Bars, int32_t *Beats, int64_t *DisplayTicks, int64_t SampleLocation) const =0
 CALL: Given an absolute sample position, gets the corresponding bar and beat position. More...
virtual AAX_Result GetTicksPerQuarter (uint32_t *ticks) const =0
 CALL: Retrieves the number of ticks per quarter note. More...
virtual AAX_Result GetCurrentTicksPerBeat (uint32_t *ticks) const =0
 CALL: Retrieves the number of ticks per beat. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
virtual AAX_Result AAX_IACFTransport::GetCurrentTempo ( double *  TempoBPM) const
pure virtual
Returns the tempo corresponding to the current position of the transport counter
Note
The resolution of the tempo returned here is based on the host's tempo resolution, so it will match the tempo displayed in the host. Use GetCurrentTicksPerBeat() to calculate the tempo resolution note.
Parameters
[out]TempoBPMThe current tempo in beats per minute
virtual AAX_Result AAX_IACFTransport::GetCurrentMeter ( int32_t *  MeterNumerator,
int32_t *  MeterDenominator
) const
pure virtual
Returns the meter corresponding to the current position of the transport counter
Parameters
[out]MeterNumeratorThe numerator portion of the meter
[out]MeterDenominatorThe denominator portion of the meter
virtual AAX_Result AAX_IACFTransport::IsTransportPlaying ( bool *  isPlaying) const
pure virtual
Parameters
[out]isPlayingtrue if the transport is currently in playback
virtual AAX_Result AAX_IACFTransport::GetCurrentTickPosition ( int64_t *  TickPosition) const
pure virtual
Returns the current tick position corresponding to the current transport position. One "Tick" is represented here as 1/960000 of a quarter note. That is, there are 960,000 of these ticks in a quarter note.
Host Compatibility Notes:
The tick resolution here is different than that of the tick displayed in Pro Tools. "Display ticks" (as they are called) are 1/960 of a quarter note.
Parameters
[out]TickPositionThe tick position value
virtual AAX_Result AAX_IACFTransport::GetCurrentLoopPosition ( bool *  bLooping,
int64_t *  LoopStartTick,
int64_t *  LoopEndTick
) const
pure virtual
This does not indicate anything about the status of the "Loop Record" option. Even when the host is configured to loop playback, looping may not occur if certain conditions are not met (i.e. the length of the selection is too short)
Parameters
[out]bLoopingtrue if the host is configured to loop playback
[out]LoopStartTickThe starting tick position of the selection being looped (see GetCurrentTickPosition())
[out]LoopEndTickThe ending tick position of the selection being looped (see GetCurrentTickPosition())
virtual AAX_Result AAX_IACFTransport::GetCurrentNativeSampleLocation ( int64_t *  SampleLocation) const
pure virtual
Note
This method only returns a value during playback. It cannot be used to determine, e.g., the location of the timeline selector while the host is not in playback.
Parameters
[out]SampleLocationAbsolute sample location of the first sample in the current native processing buffer
virtual AAX_Result AAX_IACFTransport::GetCustomTickPosition ( int64_t *  oTickPosition,
) const
pure virtual
There is a minor performance cost associated with using this API in Pro Tools. It should not be used excessively without need.
Parameters
[out]oTickPositionthe timeline tick position corresponding to iSampleLocation
[in]iSampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_IACFTransport::GetBarBeatPosition ( int32_t *  Bars,
int32_t *  Beats,
int64_t *  DisplayTicks,
) const
pure virtual
Parameters
[out]BarsThe bar corresponding to SampleLocation
[out]BeatsThe beat corresponding to SampleLocation
[out]DisplayTicksThe ticks corresponding to SampleLocation
[in]SampleLocationAn absolute sample location (see GetCurrentNativeSampleLocation())
virtual AAX_Result AAX_IACFTransport::GetTicksPerQuarter ( uint32_t *  ticks) const
pure virtual
Parameters
[out]ticks
virtual AAX_Result AAX_IACFTransport::GetCurrentTicksPerBeat ( uint32_t *  ticks) const
pure virtual
Parameters
[out]ticks
