AAX SDK  2.1.1
AAX_IACFEffectDescriptor Class Referenceabstract
#include <AAX_IACFEffectDescriptor.h>
Inheritance diagram for AAX_IACFEffectDescriptor:
Inheritance graph
[legend]
Collaboration diagram for AAX_IACFEffectDescriptor:
Collaboration graph
[legend]
Description
Versioned interface for an AAX_IEffectDescriptor.
Public Member Functions
virtual AAX_Result AddComponent (IACFUnknown *iComponentDescriptor)=0
 Add a component to an instance of a component descriptor. More...
virtual AAX_Result AddName (const char *iPlugInName)=0
 Add a name to the Effect. More...
virtual AAX_Result AddCategory (uint32_t iCategory)=0
 Add a category to your plug-in. See AAX_EPlugInCategory. More...
virtual AAX_Result AddCategoryBypassParameter (uint32_t iCategory, AAX_CParamID iParamID)=0
virtual AAX_Result AddProcPtr (void *iProcPtr, AAX_CProcPtrID iProcID)=0
 Add a process pointer. More...
virtual AAX_Result SetProperties (IACFUnknown *iProperties)=0
 Set the properties of a new property map. More...
virtual AAX_Result AddResourceInfo (AAX_EResourceType iResourceType, const char *iInfo)=0
 Set resource file info. More...
virtual AAX_Result AddMeterDescription (AAX_CTypeID iMeterID, const char *iMeterName, IACFUnknown *iProperties)=0
 Add name and property map to meter with given ID. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
virtual AAX_Result AAX_IACFEffectDescriptor::AddComponent ( IACFUnknown *  iComponentDescriptor)
pure virtual
Unlike with AAX_ICollection::AddEffect(), the AAX_IEffectDescriptor does not take ownership of the AAX_IComponentDescriptor that is passed to it in this method. The host copies out the contents of this descriptor, and thus the plug-in may re-use the same descriptor object when creating additional similar components.
Parameters
[in]iComponentDescriptor
virtual AAX_Result AAX_IACFEffectDescriptor::AddName ( const char *  iPlugInName)
pure virtual
May be called multiple times to add abbreviated Effect names.
Note
Every Effect must include at least one name variant with 31 or fewer characters, plus a null terminating character
Parameters
[in]iPlugInNameThe name assigned to the plug-in.
virtual AAX_Result AAX_IACFEffectDescriptor::AddCategory ( uint32_t  iCategory)
pure virtual
Parameters
[in]iCategoryOne of the categories for the plug-in.
virtual AAX_Result AAX_IACFEffectDescriptor::AddCategoryBypassParameter ( uint32_t  iCategory,
pure virtual
Parameters
[in]iParamIDThe parameter ID of the parameter used to bypass the category seciont of the plug-in.
virtual AAX_Result AAX_IACFEffectDescriptor::AddProcPtr ( void *  iProcPtr,
pure virtual
Parameters
[in]iProcPtrA process pointer.
[in]iProcIDA process ID.
virtual AAX_Result AAX_IACFEffectDescriptor::SetProperties ( IACFUnknown *  iProperties)
pure virtual
Parameters
[in]iPropertiesDescription
virtual AAX_Result AAX_IACFEffectDescriptor::AddResourceInfo ( AAX_EResourceType  iResourceType,
const char *  iInfo
pure virtual
Parameters
[in]iResourceTypeSee AAX_EResourceType.
[in]iInfoDefinition varies on the resource type.
virtual AAX_Result AAX_IACFEffectDescriptor::AddMeterDescription ( AAX_CTypeID  iMeterID,
const char *  iMeterName,
pure virtual
Parameters
[in]iMeterIDThe ID of the meter being described.
[in]iMeterNameThe name of the meter.
[in]iPropertiesThe property map containing meter related data such as meter type, orientation, etc.
