AAX SDK  2.1.1
AAX_IACFController_V2 Class Referenceabstract
#include <AAX_IACFController.h>
Inheritance diagram for AAX_IACFController_V2:
Inheritance graph
[legend]
Collaboration diagram for AAX_IACFController_V2:
Collaboration graph
[legend]
Public Member Functions
virtual AAX_Result SendNotification (AAX_CTypeID iNotificationType, const void *iNotificationData, uint32_t iNotificationDataSize)=0
 CALL: Sends an event to the GUI. More...
virtual AAX_Result GetHybridSignalLatency (int32_t *oSamples) const =0
 CALL: Returns the latency between the algorithm normal input samples and the inputs returning from the hyrbid component. More...
virtual AAX_Result GetCurrentAutomationTimestamp (AAX_CTransportCounter *oTimestamp) const =0
 CALL: Returns the current automation timestamp if called during the GenerateCoefficients() call AND the generation of coefficients is being triggered by an automation point instead of immediate changes. More...
virtual AAX_Result GetHostName (AAX_IString *oHostNameString) const =0
 CALL: Returns name of the host application this plug-in instance is being loaded by. This string also typically includes version information. More...
- Public Member Functions inherited from AAX_IACFController
virtual AAX_Result GetEffectID (AAX_IString *oEffectID) const =0
virtual AAX_Result GetSampleRate (AAX_CSampleRate *oSampleRate) const =0
 CALL: Returns the current literal sample rate. More...
virtual AAX_Result GetInputStemFormat (AAX_EStemFormat *oStemFormat) const =0
 CALL: Returns the plug-in's input stem format. More...
virtual AAX_Result GetOutputStemFormat (AAX_EStemFormat *oStemFormat) const =0
 CALL: Returns the plug-in's output stem format. More...
virtual AAX_Result GetSignalLatency (int32_t *oSamples) const =0
 CALL: Returns the most recent signal (algorithmic) latency that has been published by the plug-in. More...
virtual AAX_Result GetCycleCount (AAX_EProperty iWhichCycleCount, AAX_CPropertyValue *oValue) const =0
 CALL: returns the plug-in's current real-time DSP cycle count. More...
virtual AAX_Result GetTODLocation (AAX_CTimeOfDay *oTODLocation) const =0
 CALL: Returns the current Time Of Day (TOD) of the system. More...
virtual AAX_Result SetSignalLatency (int32_t iNumSamples)=0
 CALL: Submits a request to change the delay compensation value that the host uses to account for the plug-in's signal (algorithmic) latency. More...
virtual AAX_Result SetCycleCount (AAX_EProperty *iWhichCycleCounts, AAX_CPropertyValue *iValues, int32_t oNumValues)=0
 CALL: Indicates a change in the plug-in's real-time DSP cycle count. More...
virtual AAX_Result PostPacket (AAX_CFieldIndex iFieldIndex, const void *iPayloadP, uint32_t iPayloadSize)=0
 CALL: Posts a data packet to the host for routing between plug-in components. More...
virtual AAX_Result GetCurrentMeterValue (AAX_CTypeID iMeterID, float *oMeterValue) const =0
 CALL: Retrieves the current value of a host-managed plug-in meter. More...
virtual AAX_Result GetMeterPeakValue (AAX_CTypeID iMeterID, float *oPeakValue) const =0
 CALL: Retrieves the currently held peak value of a host-managed plug-in meter. More...
virtual AAX_Result ClearMeterPeakValue (AAX_CTypeID iMeterID) const =0
 CALL: Clears the peak value from a host-managed plug-in meter. More...
virtual AAX_Result GetMeterClipped (AAX_CTypeID iMeterID, AAX_CBoolean *oClipped) const =0
 CALL: Retrieves the clipped flag from a host-managed plug-in meter. More...
virtual AAX_Result ClearMeterClipped (AAX_CTypeID iMeterID) const =0
 CALL: Clears the clipped flag from a host-managed plug-in meter. More...
virtual AAX_Result GetMeterCount (uint32_t *oMeterCount) const =0
 CALL: Retrieves the number of host-managed meters registered by a plug-in. More...
virtual AAX_Result GetNextMIDIPacket (AAX_CFieldIndex *oPort, AAX_CMidiPacket *oPacket)=0
 CALL: Retrieves MIDI packets for described MIDI nodes. More...
- Public Member Functions inherited from IACFUnknown
virtual BEGIN_ACFINTERFACE
ACFRESULT ACFMETHODCALLTYPE
QueryInterface (const acfIID &iid, void **ppOut)=0
 Returns pointers to supported interfaces. More...
virtual acfUInt32 ACFMETHODCALLTYPE AddRef (void)=0
 Increments reference count. More...
virtual acfUInt32 ACFMETHODCALLTYPE Release (void)=0
 Decrements reference count. More...
Member Function Documentation
virtual AAX_Result AAX_IACFController_V2::SendNotification ( AAX_CTypeID  iNotificationType,
const void *  iNotificationData,
pure virtual
This is supported by AAX V2 Hosts only. Check the return code on the return of this function. If the error is AAX_ERROR_UNIMPLEMENTED, your plug-in is being loaded into a host that doesn't support this feature.
Parameters
[in]iNotificationTypeType of notification to send
[in]iNotificationDataBlock of notification data
[in]iNotificationDataSizeSize of iNotificationData, in bytes
virtual AAX_Result AAX_IACFController_V2::GetHybridSignalLatency ( int32_t *  oSamples) const
pure virtual
This method provides the number of samples that the AAX host expects the plug-in to delay a signal. The host will use this value when accounting for latency across the system.
Note
This value will generally scale up with sample rate, although it's not a simple multiple due to some fixed overhead. This value will be fixed for any given sample rate regardless of other buffer size settings in the host app.
Parameters
[out]oSamplesThe number of samples of hybrid signal delay
virtual AAX_Result AAX_IACFController_V2::GetCurrentAutomationTimestamp ( AAX_CTransportCounter *  oTimestamp) const
pure virtual
Note
This function will return 0 if called from outside of GenerateCoefficients() or if the GenerateCoefficients() call was initiated due to a non-automated change. In those cases, you can get your sample offset from the transport start using getTODLocation().
Parameters
[out]oTimestampThe current coefficient timestamp. Sample count from transport start.
virtual AAX_Result AAX_IACFController_V2::GetHostName ( AAX_IString *  oHostNameString) const
pure virtual
Parameters
[out]oHostNameStringThe name of the current host application.
