AAX SDK  2.1.1
AAX_VHostProcessorDelegate Class Reference
#include <AAX_VHostProcessorDelegate.h>
Inheritance diagram for AAX_VHostProcessorDelegate:
Inheritance graph
[legend]
Collaboration diagram for AAX_VHostProcessorDelegate:
Collaboration graph
[legend]
Description
Version-managed concrete Host Processor delegate class.
Public Member Functions
 AAX_VHostProcessorDelegate (IACFUnknown *pUnknown)
AAX_Result GetAudio (const float *const inAudioIns[], int32_t inAudioInCount, int64_t iLocation, int32_t *ioNumSamples)
 CALL: Randomly access audio from the timeline. More...
int32_t GetSideChainInputNum ()
 CALL: Returns the index of the side chain input buffer. More...
AAX_Result ForceAnalyze ()
 CALL: Trigger an analysis pass. More...
- Public Member Functions inherited from AAX_IHostProcessorDelegate
virtual ~AAX_IHostProcessorDelegate ()
Constructor & Destructor Documentation
AAX_VHostProcessorDelegate::AAX_VHostProcessorDelegate ( IACFUnknown *  pUnknown)
Member Function Documentation
AAX_Result AAX_VHostProcessorDelegate::GetAudio ( const float *const  iAudioIns[],
int32_t  iAudioInCount,
int64_t  iLocation,
int32_t *  ioNumSamples
virtual
Called from within AAX_IHostProcessor::RenderAudio(), this method fills a buffer of samples with randomly-accessed data from the current input processing region on the timeline, including any extra samples such as processing "handles".
Note
Plug-ins that use this feature must set AAX_eProperty_UsesRandomAccess to true
It is not possible to retrieve samples from outside of the current input processing region
Always check the return value of this method before using the randomly-accessed samples
Parameters
[in]iAudioInsTimeline audio buffer(s). This must be set to iAudioIns from AAX_IHostProcessor::RenderAudio()
Parameters
[in]iAudioInCountNumber of buffers in iAudioIns. This must be set to iAudioInCount from AAX_IHostProcessor::RenderAudio()
Parameters
[in]iLocationA sample location relative to the beginning of the currently processed region, e.g. a value of 0 corresponds to the timeline location returned by AAX_CHostProcessor::GetSrcStart()
[in,out]ioNumSamples
  • Input: The maximum number of samples to read.
  • Output: The actual number of samples that were read from the timeline
Implements AAX_IHostProcessorDelegate.
int32_t AAX_VHostProcessorDelegate::GetSideChainInputNum ( )
virtual
Called from within AAX_IHostProcessor::RenderAudio(), this method returns the index of the side chain input sample buffer within iAudioIns.
AAX_Result AAX_VHostProcessorDelegate::ForceAnalyze ( )
virtual
Call this method to trigger an analysis pass from within the plug-in. Most plug-ins should rely on the host to trigger analysis passes when appropriate. However, plug-ins that require an analysis pass a) outside of the context of host-driven render or analysis, or b) when internal plug-in data changes may need to call ForceAnalyze().
