AAX SDK
2.1.1
#include <AAX_IHostProcessorDelegate.h>
Delegate for retrieving offline processing information from the host.
The host provides a host processor delegate to a plug-in's host processor object at initialization. The host processor object may make calls to this object to get information about the current render pass or to affect the plug-in's offline processing behavior.
Public Member Functions | |
| virtual | ~AAX_IHostProcessorDelegate () |
| virtual AAX_Result | GetAudio (const float *const iAudioIns[], int32_t iAudioInCount, int64_t iLocation, int32_t *ioNumSamples)=0 |
| CALL: Randomly access audio from the timeline. More... | |
| virtual int32_t | GetSideChainInputNum ()=0 |
| CALL: Returns the index of the side chain input buffer. More... | |
| virtual AAX_Result | ForceAnalyze ()=0 |
| CALL: Trigger an analysis pass. More... | |
inlinevirtual |
pure virtual |
Called from within AAX_IHostProcessor::RenderAudio(), this method fills a buffer of samples with randomly-accessed data from the current input processing region on the timeline, including any extra samples such as processing "handles".
true | [in] | iAudioIns | Timeline audio buffer(s). This must be set to iAudioIns from AAX_IHostProcessor::RenderAudio() |
| [in] | iAudioInCount | Number of buffers in iAudioIns. This must be set to iAudioInCount from AAX_IHostProcessor::RenderAudio() |
| [in] | iLocation | A sample location relative to the beginning of the currently processed region, e.g. a value of 0 corresponds to the timeline location returned by AAX_CHostProcessor::GetSrcStart() |
| [in,out] | ioNumSamples |
Implemented in AAX_VHostProcessorDelegate.
pure virtual |
Called from within AAX_IHostProcessor::RenderAudio(), this method returns the index of the side chain input sample buffer within iAudioIns.
pure virtual |
Call this method to trigger an analysis pass from within the plug-in. Most plug-ins should rely on the host to trigger analysis passes when appropriate. However, plug-ins that require an analysis pass a) outside of the context of host-driven render or analysis, or b) when internal plug-in data changes may need to call ForceAnalyze().
1.8.5
