AAX SDK  2.1.1
AAX_CStateTaperDelegate< T > Class Template Reference
#include <AAX_CStateTaperDelegate.h>
Inheritance diagram for AAX_CStateTaperDelegate< T >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CStateTaperDelegate< T >:
Collaboration graph
[legend]
Description
template<typename T>
class AAX_CStateTaperDelegate< T >
A linear taper conforming to AAX_ITaperDelegate.
This taper spaces a parameter's real values evenly between its minimum and maximum, with a linear mapping between the parameter's real and normalized values. It is essentially a version of AAX_CLinearTaperDelegate without that class' additional RealPrecision templatization.
Public Member Functions
 AAX_CStateTaperDelegate (T minValue=0, T maxValue=1)
 Constructs a State Taper with specified minimum and maximum values. More...
AAX_CStateTaperDelegate< T > * Clone () const
 Constructs and returns a copy of the taper delegate. More...
T GetMinimumValue () const
 Returns the taper's minimum real value. More...
T GetMaximumValue () const
 Returns the taper's maximum real value. More...
T ConstrainRealValue (T value) const
 Applies a contraint to the value and returns the constrained value. More...
T NormalizedToReal (double normalizedValue) const
 Converts a normalized value to a real value. More...
double RealToNormalized (T realValue) const
 Normalizes a real parameter value. More...
- Public Member Functions inherited from AAX_ITaperDelegateBase
virtual ~AAX_ITaperDelegateBase ()
 Virtual destructor. More...
Constructor & Destructor Documentation
template<typename T >
AAX_CStateTaperDelegate< T >::AAX_CStateTaperDelegate ( T  minValue = 0,
T  maxValue = 1
Note
The parameter's default value should lie within the min to max range.
Parameters
[in]minValue
[in]maxValue
Member Function Documentation
AAX_CStateTaperDelegate< T > * AAX_CStateTaperDelegate< T >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassTaperDelegate<T>* AAX_CSubclassTaperDelegate<T>::Clone() const
return new AAX_CSubclassTaperDelegate(*this);
Implements AAX_ITaperDelegate< T >.
T AAX_CStateTaperDelegate< T >::GetMinimumValue ( ) const
inlinevirtual
T AAX_CStateTaperDelegate< T >::GetMaximumValue ( ) const
inlinevirtual
T AAX_CStateTaperDelegate< T >::ConstrainRealValue ( T  value) const
virtual
This method is useful if the taper requires a contraint beyond simple minimum and maximum real value limits.
Note
This is the function that should actually enforces the constraints in NormalizeToReal() and RealToNormalized().
Parameters
[in]valueThe unconstrained value
T AAX_CStateTaperDelegate< T >::NormalizedToReal ( double  normalizedValue) const
virtual
This is where the actual taper algorithm is implemented.
This function should perform the exact inverse of RealToNormalized(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]normalizedValueThe normalized value that will be converted
double AAX_CStateTaperDelegate< T >::RealToNormalized ( T  realValue) const
virtual
This function should perform the exact inverse of NormalizedToReal(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]realValueThe real parameter value that will be normalized
