AAX SDK  2.1.1
List of all members | Public Member Functions | Protected Member Functions
AAX_CLinearTaperDelegate< T, RealPrecision > Class Template Reference
#include <AAX_CLinearTaperDelegate.h>
Inheritance diagram for AAX_CLinearTaperDelegate< T, RealPrecision >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CLinearTaperDelegate< T, RealPrecision >:
Collaboration graph
[legend]
Description
template<typename T, int32_t RealPrecision = 0>
class AAX_CLinearTaperDelegate< T, RealPrecision >
A linear taper conforming to AAX_ITaperDelegate.
This taper spaces a parameter's real values evenly between its minimum and maximum, with a linear mapping between the parameter's real and normalized values.
RealPrecision
In addition to its type templatization, this taper includes a precision template parameter. RealPrecision is a multiplier that works in conjunction with the round() function to limit the precision of the real values provided by this taper. For example, if RealPrecision is 1000, it will round to the closest 0.001 when doing any sort of value conversion. If RealPrecision is 1, it will round to the nearest integer. If RealPrecision is 1000000, it will round to the nearest 0.000001. This is particularly useful for preventing things like 1.9999999 truncating down to 1 instead of rounding up to 2.
To accomplish this behavior, the taper multiplies its unrounded parameter values by RealPrecision, rounds the result to the nearest valid value, then divides RealPrecision back out.
Rounding will be disabled if RealPrecision is set to a value less than 1. This is the default.
 AAX_CLinearTaperDelegate (T minValue=0, T maxValue=1)
 Constructs a Linear Taper with specified minimum and maximum values. More...
RealPrecision > *
Clone () const
 Constructs and returns a copy of the taper delegate. More...
T GetMinimumValue () const
 Returns the taper's minimum real value. More...
T GetMaximumValue () const
 Returns the taper's maximum real value. More...
T ConstrainRealValue (T value) const
 Applies a contraint to the value and returns the constrained value. More...
virtual T NormalizedToReal (double normalizedValue) const
 Converts a normalized value to a real value. More...
virtual double RealToNormalized (T realValue) const
 Normalizes a real parameter value. More...
- Public Member Functions inherited from AAX_ITaperDelegateBase
virtual ~AAX_ITaperDelegateBase ()
 Virtual destructor. More...
T Round (double iValue) const
Constructor & Destructor Documentation
template<typename T , int32_t RealPrecision>
AAX_CLinearTaperDelegate< T, RealPrecision >::AAX_CLinearTaperDelegate ( T  minValue = 0,
T  maxValue = 1
Note
The parameter's default value should lie within the min to max range.
Parameters
[in]minValue
[in]maxValue
Member Function Documentation
AAX_CLinearTaperDelegate< T, RealPrecision > * AAX_CLinearTaperDelegate< T, RealPrecision >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassTaperDelegate<T>* AAX_CSubclassTaperDelegate<T>::Clone() const
return new AAX_CSubclassTaperDelegate(*this);
Implements AAX_ITaperDelegate< T >.
T AAX_CLinearTaperDelegate< T, RealPrecision >::GetMinimumValue ( ) const
inlinevirtual
T AAX_CLinearTaperDelegate< T, RealPrecision >::GetMaximumValue ( ) const
inlinevirtual
T AAX_CLinearTaperDelegate< T, RealPrecision >::ConstrainRealValue ( T  value) const
virtual
This method is useful if the taper requires a contraint beyond simple minimum and maximum real value limits.
Note
This is the function that should actually enforces the constraints in NormalizeToReal() and RealToNormalized().
Parameters
[in]valueThe unconstrained value
T AAX_CLinearTaperDelegate< T, RealPrecision >::NormalizedToReal ( double  normalizedValue) const
virtual
This is where the actual taper algorithm is implemented.
This function should perform the exact inverse of RealToNormalized(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]normalizedValueThe normalized value that will be converted
double AAX_CLinearTaperDelegate< T, RealPrecision >::RealToNormalized ( T  realValue) const
virtual
This function should perform the exact inverse of NormalizedToReal(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]realValueThe real parameter value that will be normalized
T AAX_CLinearTaperDelegate< T, RealPrecision >::Round ( double  iValue) const
protected
