AAX SDK  2.1.1
Functions
AAX_Init.h File Reference
#include "AAX.h"
#include "acfbasetypes.h"
Go to the source code of this file.
Description
AAX library implementations of required plug-in initialization, registration, and tear-down methods.
Functions
AAX_Result AAXRegisterPlugin (IACFUnknown *pUnkHost, IACFPluginDefinition **ppPluginDefinition)
 The main plug-in registration method. More...
AAX_Result AAXRegisterComponent (IACFUnknown *pUnkHost, acfUInt32 index, IACFComponentDefinition **ppComponentDefinition)
 Registers a specific component in the DLL. More...
AAX_Result AAXGetClassFactory (IACFUnknown *pUnkHost, const acfCLSID &clsid, const acfIID &iid, void **ppOut)
 Gets the factory for a given class ID. More...
AAX_Result AAXCanUnloadNow (IACFUnknown *pUnkHost)
 Determines whether or not the host may unload the DLL. More...
AAX_Result AAXStartup (IACFUnknown *pUnkHost)
 DLL initialization routine. More...
AAX_Result AAXShutdown (IACFUnknown *pUnkHost)
 DLL shutdown routine. More...
AAX_Result AAXGetSDKVersion (acfUInt64 *oSDKVersion)
 Returns the DLL's SDK version. More...
Function Documentation
AAX_Result AAXRegisterComponent ( IACFUnknown *  pUnkHost,
acfUInt32  index,
IACFComponentDefinition **  ppComponentDefinition
The implementation of this method in the AAX library simply sets *ppComponentDefinition to NULL and returns AAX_SUCCESS.
Wrapped by ACFRegisterComponent()
Referenced by ACFRegisterComponent().
Here is the caller graph for this function:
AAX_Result AAXGetClassFactory ( IACFUnknown *  pUnkHost,
const acfCLSID &  clsid,
const acfIID &  iid,
void **  ppOut
This method is required by ACF but is not supported by AAX. Therefore the implementation of this method in the AAX library simply sets *ppOut to NULL and returns AAX_ERROR_UNIMPLEMENTED.
Wrapped by ACFGetClassFactory()
Referenced by ACFGetClassFactory().
AAX_Result AAXCanUnloadNow ( IACFUnknown *  pUnkHost)
The implementation of this method in the AAX library returns the result of GetActiveObjectCount() as an AAX_Result, with zero active objects interpreted as AAX_SUCCESS (see CACFUnknown.h)
Wrapped by ACFCanUnloadNow()
Referenced by ACFCanUnloadNow().
AAX_Result AAXStartup ( IACFUnknown *  pUnkHost)
Called once at init time. The implementation of this method in the AAX library uses pUnkHost as an IACFComponentFactory to initialize global services (see acfbaseapi.h)
Wrapped by ACFStartup()
Referenced by ACFStartup().
AAX_Result AAXShutdown ( IACFUnknown *  pUnkHost)
Called once before unloading the DLL. The implementation of this method in the AAX library tears down any globally initialized state and releases any globally retained resources.
Wrapped by ACFShutdown()
Referenced by ACFShutdown().
AAX_Result AAXGetSDKVersion ( acfUInt64 *  oSDKVersion)
The implementation of this method in the AAX library provides a 64-bit value in which the upper 32 bits represent the SDK version and the lower 32 bits represent the revision number of the SDK. See AAX_Version.h
Wrapped by ACFGetSDKVersion()
Referenced by ACFGetSDKVersion().
