AAX SDK  2.1.1
AAX_VViewContainer Class Reference
#include <AAX_VViewContainer.h>
Inheritance diagram for AAX_VViewContainer:
Inheritance graph
[legend]
Collaboration diagram for AAX_VViewContainer:
Collaboration graph
[legend]
Description
Version-managed concrete AAX_IViewContainer class.
Public Member Functions
 AAX_VViewContainer (IACFUnknown *pUnknown)
virtual ~AAX_VViewContainer ()
virtual int32_t GetType ()
 Returns the raw view type as one of AAX_EViewContainer_Type. More...
virtual void * GetPtr ()
 Returns a pointer to the raw view. More...
virtual AAX_Result GetModifiers (uint32_t *outModifiers)
 Queries the host for the current modifier keys. More...
virtual AAX_Result SetViewSize (AAX_Point &inSize)
 Request a change to the main view size. More...
virtual AAX_Result HandleParameterMouseDown (AAX_CParamID inParamID, uint32_t inModifiers)
 Alert the host to a mouse down event. More...
virtual AAX_Result HandleParameterMouseDrag (AAX_CParamID inParamID, uint32_t inModifiers)
 Alert the host to a mouse drag event. More...
virtual AAX_Result HandleParameterMouseUp (AAX_CParamID inParamID, uint32_t inModifiers)
 Alert the host to a mouse up event. More...
- Public Member Functions inherited from AAX_IViewContainer
virtual ~AAX_IViewContainer (void)
Constructor & Destructor Documentation
AAX_VViewContainer::AAX_VViewContainer ( IACFUnknown *  pUnknown)
virtual AAX_VViewContainer::~AAX_VViewContainer ( )
virtual
Member Function Documentation
virtual int32_t AAX_VViewContainer::GetType ( )
virtual
Implements AAX_IViewContainer.
virtual void* AAX_VViewContainer::GetPtr ( )
virtual
virtual AAX_Result AAX_VViewContainer::GetModifiers ( uint32_t *  oModifiers)
virtual
This method returns a bit mask with bits set for each of the currently active modifier keys. This method does not return the state of the AAX_eModifiers_SecondaryButton.
Host Compatibility Notes:
Although this method allows plug-ins to acquire the current state of the Windows key (normally blocked by Pro Tools), plug-ins should not use key combinations that require this key.
virtual AAX_Result AAX_VViewContainer::SetViewSize ( AAX_Point &  iSize)
virtual
Note
  • For compatibility with the smallest supported displays, plug-in GUI dimensions should not exceed 749x617 pixels, or 749x565 pixels for plug-ins with sidechain support.
Parameters
[in]iSizeThe new size to which the plug-in view should be set
virtual AAX_Result AAX_VViewContainer::HandleParameterMouseDown ( AAX_CParamID  iParamID,
uint32_t  iModifiers
virtual
Parameters
[in]iParamIDID of the parameter whose control is being edited
[in]iModifiersA bitmask of AAX_EModifiers values
virtual AAX_Result AAX_VViewContainer::HandleParameterMouseDrag ( AAX_CParamID  iParamID,
uint32_t  iModifiers
virtual
Parameters
virtual AAX_Result AAX_VViewContainer::HandleParameterMouseUp ( AAX_CParamID  iParamID,
uint32_t  iModifiers
virtual
Parameters
