AAX SDK  2.1.1
List of all members | Public Member Functions | Public Attributes
AAX_SInstrumentSetupInfo Struct Reference
#include <AAX_CInstrumentParameters.h>
Description
Information used to describe the instrument.
See Also
AAX_CInstrumentParameters::StaticDescribe()
 AAX_SInstrumentSetupInfo ()
 Default constructor. More...
Public Attributes
bool mNeedsGlobalMIDI
 Does the instrument use a global MIDI input node? More...
const char * mGlobalMIDINodeName
 Name of the global MIDI node, if used. More...
uint32_t mGlobalMIDIEventMask
 Global MIDI node event mask, if used. More...
bool mNeedsInputMIDI
 Does the instrument use a local MIDI input node? More...
const char * mInputMIDINodeName
 Name of the MIDI input node, if used. More...
uint32_t mInputMIDIChannelMask
 MIDI input node channel mask, if used. More...
int32_t mNumAdditionalInputMIDINodes
 Number of additional input MIDI Nodes. These will all share the same channelMask and base MIDINodeName, but the names will be appended with numbers 2,3,4,... More...
bool mNeedsTransport
 Does the instrument use the transport interface? More...
const char * mTransportMIDINodeName
 Name of the MIDI transport node, if used. More...
int32_t mNumMeters
 Number of meter taps used by the instrument. Must match the size of mMeterIDs. More...
const AAX_CTypeID * mMeterIDs
 Array of meter IDs. More...
int32_t mNumAuxOutputStems
 Number of aux output stems for the plug-in. More...
const char * mAuxOutputStemNames [kMaxAuxOutputStems]
 Names of the aux output stems. More...
AAX_EStemFormat mAuxOutputStemFormats [kMaxAuxOutputStems]
 Stem formats for the output stems. More...
AAX_EStemFormat mInputStemFormat
 Input stem format. More...
AAX_EStemFormat mOutputStemFormat
 Output stem format. More...
bool mUseHostGeneratedGUI
 Pro Tools or other host to generate a generic GUI for your plug-in? (useful for early development) More...
bool mCanBypass
 Can this instrument be bypassed? More...
AAX_CTypeID mManufacturerID
 Manufacturer ID. More...
AAX_CTypeID mProductID
 Product ID. More...
AAX_CTypeID mPluginID
 Plug-In (Type) ID. More...
Constructor & Destructor Documentation
AAX_SInstrumentSetupInfo::AAX_SInstrumentSetupInfo ( )
inline
Member Data Documentation
bool AAX_SInstrumentSetupInfo::mNeedsGlobalMIDI
Referenced by AAX_SInstrumentSetupInfo().
const char* AAX_SInstrumentSetupInfo::mGlobalMIDINodeName
uint32_t AAX_SInstrumentSetupInfo::mGlobalMIDIEventMask
bool AAX_SInstrumentSetupInfo::mNeedsInputMIDI
const char* AAX_SInstrumentSetupInfo::mInputMIDINodeName
uint32_t AAX_SInstrumentSetupInfo::mInputMIDIChannelMask
int32_t AAX_SInstrumentSetupInfo::mNumAdditionalInputMIDINodes
bool AAX_SInstrumentSetupInfo::mNeedsTransport
const char* AAX_SInstrumentSetupInfo::mTransportMIDINodeName
int32_t AAX_SInstrumentSetupInfo::mNumMeters
const AAX_CTypeID* AAX_SInstrumentSetupInfo::mMeterIDs
Array of meter IDs.
int32_t AAX_SInstrumentSetupInfo::mNumAuxOutputStems
const char* AAX_SInstrumentSetupInfo::mAuxOutputStemNames[kMaxAuxOutputStems]
AAX_EStemFormat AAX_SInstrumentSetupInfo::mAuxOutputStemFormats[kMaxAuxOutputStems]
AAX_EStemFormat AAX_SInstrumentSetupInfo::mInputStemFormat
Input stem format.
AAX_EStemFormat AAX_SInstrumentSetupInfo::mOutputStemFormat
Output stem format.
bool AAX_SInstrumentSetupInfo::mUseHostGeneratedGUI
bool AAX_SInstrumentSetupInfo::mCanBypass
AAX_CTypeID AAX_SInstrumentSetupInfo::mManufacturerID
Manufacturer ID.
AAX_CTypeID AAX_SInstrumentSetupInfo::mProductID
Product ID.
AAX_CTypeID AAX_SInstrumentSetupInfo::mPluginID
Plug-In (Type) ID.
The documentation for this struct was generated from the following file:
