AAX SDK  2.1.1
List of all members | Public Member Functions | Protected Member Functions
AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision > Class Template Reference
#include <AAX_CPieceWiseLinearTaperDelegate.h>
Inheritance diagram for AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >:
Collaboration graph
[legend]
Description
template<typename T, int32_t RealPrecision = 100>
class AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >
A piece-wise linear taper conforming to AAX_ITaperDelegate.
This taper spaces a parameter's real values in a piecewise linear fashion.
RealPrecision
In addition to its type templatization, this taper includes a precision template parameter. RealPrecision is a multiplier that works in conjunction with the round() function to limit the precision of the real values provided by this taper. For example, if RealPrecision is 1000, it will round to the closest 0.001 when doing any sort of value conversion. If RealPrecision is 1, it will round to the nearest integer. If RealPrecision is 1000000, it will round to the nearest 0.000001. This is particularly useful for preventing things like 1.9999999 truncating down to 1 instead of rounding up to 2.
To accomplish this behavior, the taper multiplies its unrounded parameter values by RealPrecision, rounds the result to the nearest valid value, then divides RealPrecision back out.
Rounding will be disabled if RealPrecision is set to a value less than 1
 AAX_CPieceWiseLinearTaperDelegate (const double *normalizedValues, const T *realValues, int32_t numValues)
 Constructs a Piece-wise Linear Taper with paired normalized and real values. More...
 AAX_CPieceWiseLinearTaperDelegate (const AAX_CPieceWiseLinearTaperDelegate &other)
 ~AAX_CPieceWiseLinearTaperDelegate ()
< T, RealPrecision > *
Clone () const
 Constructs and returns a copy of the taper delegate. More...
T GetMinimumValue () const
 Returns the taper's minimum real value. More...
T GetMaximumValue () const
 Returns the taper's maximum real value. More...
T ConstrainRealValue (T value) const
 Applies a contraint to the value and returns the constrained value. More...
T NormalizedToReal (double normalizedValue) const
 Converts a normalized value to a real value. More...
double RealToNormalized (T realValue) const
 Normalizes a real parameter value. More...
- Public Member Functions inherited from AAX_ITaperDelegateBase
virtual ~AAX_ITaperDelegateBase ()
 Virtual destructor. More...
T Round (double iValue) const
Constructor & Destructor Documentation
template<typename T , int32_t RealPrecision>
AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::AAX_CPieceWiseLinearTaperDelegate ( const double *  normalizedValues,
const T *  realValues,
int32_t  numValues
Note
The parameter's default value should lie within the min to max range.
Parameters
[in]normalizedValuesis an array of the normalized values in sorted order. (make sure to include the full normalized range, 0.0-1.0 inclusive)
[in]realValuesis an array of the corresponding real values to the normalized values passed in.
[in]numValuesis the number of values that have been passed in (i.e. the element length of the other input arrays)
AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::AAX_CPieceWiseLinearTaperDelegate ( const AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision > &  other)
AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::~AAX_CPieceWiseLinearTaperDelegate ( )
Member Function Documentation
AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision > * AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassTaperDelegate<T>* AAX_CSubclassTaperDelegate<T>::Clone() const
return new AAX_CSubclassTaperDelegate(*this);
Implements AAX_ITaperDelegate< T >.
T AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::GetMinimumValue ( ) const
inlinevirtual
T AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::GetMaximumValue ( ) const
inlinevirtual
T AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::ConstrainRealValue ( T  value) const
virtual
This method is useful if the taper requires a contraint beyond simple minimum and maximum real value limits.
Note
This is the function that should actually enforces the constraints in NormalizeToReal() and RealToNormalized().
Parameters
[in]valueThe unconstrained value
T AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::NormalizedToReal ( double  normalizedValue) const
virtual
This is where the actual taper algorithm is implemented.
This function should perform the exact inverse of RealToNormalized(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]normalizedValueThe normalized value that will be converted
double AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::RealToNormalized ( T  realValue) const
virtual
This function should perform the exact inverse of NormalizedToReal(), to within the roundoff precision of the individual taper implementation.
Parameters
[in]realValueThe real parameter value that will be normalized
T AAX_CPieceWiseLinearTaperDelegate< T, RealPrecision >::Round ( double  iValue) const
protected
