AAX SDK  2.1.1
AAX_CUnitPrefixDisplayDelegateDecorator< T > Class Template Reference
#include <AAX_CUnitPrefixDisplayDelegateDecorator.h>
Inheritance diagram for AAX_CUnitPrefixDisplayDelegateDecorator< T >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CUnitPrefixDisplayDelegateDecorator< T >:
Collaboration graph
[legend]
Description
template<typename T>
class AAX_CUnitPrefixDisplayDelegateDecorator< T >
A unit prefix decorator conforming to AAX_IDisplayDelegateDecorator.
This class is an AAX_IDisplayDelegateDecorator, meaning that it acts as a wrapper for other display delegates or concrete display types. For more information about display delegate decorators in AAX, see Display delegate decorators
The behavior of this class it to provide unit prefixes such as the k in kHz or the m in mm. It takes the value passed in and determines if the value is large or small enough to benefit from a unit modifier. If so, it adds that unit prefix character to the display string after scaling the number and calling deeper into the decorator pattern to get the concrete ValueToString() result.
The inverse is also supported, so if you type 1.5k in a text box and this decorator is in place, it should find the k and multiply the value by 1000 before converting it to a real value.
This decorator supports the following unit prefixes:
Note
This class is not implemented for integer values as the conversions result in fractional numbers. Those would get truncated through the system and be pretty much useless.
Public Member Functions
 AAX_CUnitPrefixDisplayDelegateDecorator (const AAX_IDisplayDelegate< T > &displayDelegate)
< T > *
Clone () const
 Constructs and returns a copy of the display delegate. More...
bool ValueToString (T value, AAX_CString *valueString) const
 Converts a real parameter value to a string representation. More...
bool ValueToString (T value, int32_t maxNumChars, AAX_CString *valueString) const
 Converts a real parameter value to a string representation using a size hint, useful for control surfaces and other character limited displays. More...
bool StringToValue (const AAX_CString &valueString, T *value) const
 Converts a string to a real parameter value. More...
- Public Member Functions inherited from AAX_IDisplayDelegateDecorator< T >
 AAX_IDisplayDelegateDecorator (const AAX_IDisplayDelegate< T > &displayDelegate)
 Constructor. More...
 AAX_IDisplayDelegateDecorator (const AAX_IDisplayDelegateDecorator &other)
 Copy constructor. More...
virtual ~AAX_IDisplayDelegateDecorator ()
 Virtual destructor. More...
< T > *
Clone () const
 Constructs and returns a copy of the display delegate decorator. More...
 Converts a string to a real parameter value with a size constraint. More...
- Public Member Functions inherited from AAX_IDisplayDelegateBase
virtual ~AAX_IDisplayDelegateBase ()
Constructor & Destructor Documentation
template<typename T >
AAX_CUnitPrefixDisplayDelegateDecorator< T >::AAX_CUnitPrefixDisplayDelegateDecorator ( const AAX_IDisplayDelegate< T > &  displayDelegate)
Member Function Documentation
AAX_CUnitPrefixDisplayDelegateDecorator< T > * AAX_CUnitPrefixDisplayDelegateDecorator< T >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassDisplayDelegate<T>* AAX_CSubclassDisplayDelegate<T>::Clone() const
return new AAX_CSubclassDisplayDelegate(*this);
Implements AAX_IDisplayDelegate< T >.
bool AAX_CUnitPrefixDisplayDelegateDecorator< T >::ValueToString ( T  value,
AAX_CString *  valueString
) const
virtual
Parameters
[in]valueThe real parameter value that will be converted
[out]valueStringA string corresponding to value
Return values
trueThe string conversion was successful
falseThe string conversion was unsuccessful
References AAX_IDisplayDelegateDecorator< T >::ValueToString().
Here is the call graph for this function:
) const
virtual
Parameters
[in]maxNumCharsSize hint for the desired maximum number of characters in the string (not including null termination)
Return values
bool AAX_CUnitPrefixDisplayDelegateDecorator< T >::StringToValue ( const AAX_CString &  valueString,
T *  value
) const
virtual
Parameters
[in]valueStringThe string that will be converted
[out]valueThe real parameter value corresponding to valueString
Return values
References AAX_CString::Erase(), AAX_CString::Length(), and AAX_IDisplayDelegateDecorator< T >::StringToValue().
