AAX SDK  2.1.1
AAX_CPercentDisplayDelegateDecorator< T > Class Template Reference
#include <AAX_CPercentDisplayDelegateDecorator.h>
Inheritance diagram for AAX_CPercentDisplayDelegateDecorator< T >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CPercentDisplayDelegateDecorator< T >:
Collaboration graph
[legend]
Description
template<typename T>
class AAX_CPercentDisplayDelegateDecorator< T >
A percent decorator conforming to AAX_IDisplayDelegateDecorator.
This class is an AAX_IDisplayDelegateDecorator, meaning that it acts as a wrapper for other display delegates or concrete display types. For more information about display delegate decorators in AAX, see Display delegate decorators
The behavior of this class it to provide string conversion to and from percentage (%) values. When converting a parameter value to a string, it takes the real value and performs a % conversion before passing the value on to a concrete implementation to get a value string. It then adds on the "%" string at the end to signify that the value was converted. This allows something like a gain value to remain internally linear at all times even though its display is converted to a percentage.
The inverse operation is also supported; this class can convert a percentage-formatted string into its associated real value. The string will first be converted to a number, then that number will have the inverse % calculation applied to it to retrieve the parameter's actual value.
Public Member Functions
 AAX_CPercentDisplayDelegateDecorator (const AAX_IDisplayDelegate< T > &displayDelegate)
< T > *
Clone () const
 Constructs and returns a copy of the display delegate. More...
bool ValueToString (T value, AAX_CString *valueString) const
 Converts a real parameter value to a string representation. More...
bool ValueToString (T value, int32_t maxNumChars, AAX_CString *valueString) const
 Converts a real parameter value to a string representation using a size hint, useful for control surfaces and other character limited displays. More...
bool StringToValue (const AAX_CString &valueString, T *value) const
 Converts a string to a real parameter value. More...
- Public Member Functions inherited from AAX_IDisplayDelegateDecorator< T >
 AAX_IDisplayDelegateDecorator (const AAX_IDisplayDelegate< T > &displayDelegate)
 Constructor. More...
 AAX_IDisplayDelegateDecorator (const AAX_IDisplayDelegateDecorator &other)
 Copy constructor. More...
virtual ~AAX_IDisplayDelegateDecorator ()
 Virtual destructor. More...
< T > *
Clone () const
 Constructs and returns a copy of the display delegate decorator. More...
 Converts a string to a real parameter value with a size constraint. More...
- Public Member Functions inherited from AAX_IDisplayDelegateBase
virtual ~AAX_IDisplayDelegateBase ()
Constructor & Destructor Documentation
template<typename T >
AAX_CPercentDisplayDelegateDecorator< T >::AAX_CPercentDisplayDelegateDecorator ( const AAX_IDisplayDelegate< T > &  displayDelegate)
Member Function Documentation
AAX_CPercentDisplayDelegateDecorator< T > * AAX_CPercentDisplayDelegateDecorator< T >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassDisplayDelegate<T>* AAX_CSubclassDisplayDelegate<T>::Clone() const
return new AAX_CSubclassDisplayDelegate(*this);
Implements AAX_IDisplayDelegate< T >.
bool AAX_CPercentDisplayDelegateDecorator< T >::ValueToString ( T  value,
AAX_CString *  valueString
) const
virtual
Parameters
[in]valueThe real parameter value that will be converted
[out]valueStringA string corresponding to value
Return values
trueThe string conversion was successful
falseThe string conversion was unsuccessful
References AAX_IDisplayDelegateDecorator< T >::ValueToString().
Here is the call graph for this function:
) const
virtual
Parameters
[in]maxNumCharsSize hint for the desired maximum number of characters in the string (not including null termination)
Return values
bool AAX_CPercentDisplayDelegateDecorator< T >::StringToValue ( const AAX_CString &  valueString,
T *  value
) const
virtual
Parameters
[in]valueStringThe string that will be converted
[out]valueThe real parameter value corresponding to valueString
Return values
References AAX_CString::Length(), AAX_IDisplayDelegateDecorator< T >::StringToValue(), and AAX_CString::SubString().
