AAX SDK
2.1.1
How to add tracing to your plug-ins and view logging from the plug-in host.
DigiTrace is a logging tool used by many Avid audio applications. DigiTrace provides high-performance, real-time tracing capabilities and can help you debug hard-to-isolate problems in real-time code. Pro Tools and other Avid audio products are instrumented with DigiTrace, and it is easy to add DigiTrace logging to your AAX plug-ins.
This document outlines how to use DigiTrace, both as a developer to add trace instrumentation to your code and as an end user to view or record trace instrumentation for an instrumented application.
DigiTrace generates encrypted logs on users' systems. These log files can be decrypted via the DigiTraceDecryptor application that is included in the DigiTrace Tools package.
By default, DigiTrace logs basic information including details about the system, software, component versions, and any errors that are encountered. By using a simple configuration text file, DigiTrace can be easily configured to provide additional logging information such as plug-in loading details. Here are some examples of how you can use DigiTrace:
This section provides quick steps for the following common tasks:
DigiTrace log files are placed into a common logs directory. The specific directory that is used depends on the version of DigiTrace - see Where are DigiTrace log files stored?.
By default, the version of DigiTrace that is installed with Avid audio products generates logs in an encrypted format with the extension ".dlog". Developer builds of Pro Tools and other applications are configured to generate plain-text logs.
You can convert .dlog files to plain-text using the DigiTraceDecryptor tool that is included in the DigiTrace Tools package available for download from the Avid developer portal. To decrypt a log using this tool, simply drag-and-drop the .dlog file onto the tool. You can also set this tool as the default application for opening .dlog files in your OS, which will allow you to decrypt and open .dlog files directly.
In order to be able to view streaming log output in real time, DigiTrace must be configured for plain-text output. This is the default configuration for developer builds of Pro Tools and other Avid audio applications.
To configure shipping applications for plain-text log output, you must replace the application's installed DigiTrace library with a development version of the DigiTrace library. Development builds of DigiTrace are included in the DigiTrace Tools package. Search for "Digitrace.framework" on OS X or "DigiTrace.dll" on Windows and replace the installed shipping version of the library with the developer version from the DigiTrace Tools package to configure the application for plain-text output.
Note that the developer version of DigiTrace may output logs to a different directory than the shipping version. In general, developer builds of DigiTrace will place log files in a directory next to the instrumented application. For example, developer builds of Pro Tools will output logs to a logs directory placed adjacent to the Pro Tools application bundle rather than in the user's Library/Logs/Avid folder.
To easily add tracing to an AAX plug-in, use the AAX_TRACE or AAX_TRACE_RELEASE macros. Logging from the "release" macro will be enabled for all builds of the plug-in, whereas logging from the "standard" macro will only be enabled in Debug builds of the plug-in.
To configure DigiTrace to print logs from AAX_TRACE or AAX_TRACE_RELEASE macros in AAX plug-ins, add the following line to the config.digitrace file for the application:
The config.digitrace file is a plain-text file that should be placed either directly next to the application executable or in the OS X application bundle's Resources directory. If a config.digitrace file does not already exist for the application then you can create it to enable DigiTrace.
The default logging in Avid audio applications includes data that can be useful in many different troubleshooting situations. For example:
In addition, you can add DigiTrace logging code to your plug-ins, helping you examine potential issues in the way your plug-in is running on a user's computer even when you cannot reproduce the issue locally.
DigiTrace logs are stored in a log files directory on the user's system. The default location of this directory depends on the operating system and on which version of DigiTrace is being used:
This default log directory can be overridden in the DigiTrace config file. See Advanced DigiTrace configuration for more information.
By default the log file will be given a time-stamped name in the format <AppName>_YYYY_MM_DD_HH_MM_SS.dlog. This timestamp represents the system time when the log was created. Like the log directory, this log file name can be changed using the DigiTrace configuration. See Advanced DigiTrace configuration for more information.
You can of course view a log file by opening it periodically. In addition, assuming that DigiTrace is configured for plain text output, you can also constantly monitor a log file in a "streaming" manner. This is possible using standard Unix tools included with OS X or with Cygwin on Windows. In fact, this approach usually works better than telling DigiTrace to use console output due to buffering of the console output.
tail: tail -f /path/to/digitrace/logs/the_logfile.txt tail and ls: tail -f `ls -d -1 -rt /path/to/digitrace/logs/*.txt | tail -1` Console behavior is quite different between OS X and Windows
Windows
OS X
tail command, e.g. tail -f "~/Library/Logs/Avid/Pro Tools.0.log" Here is the beginning of an example DigiTrace log:
The columns consist of the following:
You can configure DigiTrace to include or exclude specific traces using the config.digitrace configuration file. This file is plain text and includes a single configuration command on each line.
This is the basic format for a command used to enable tracing for a single facility:
Here are some examples:
DTF_APP_VERSION=file@DTP_LOW DTF_PLUGINS_3P=file@DTP_LOW,console@DTP_URGENT DTF_ASSERTHANDLER=console@DTP_URGENT DTF_DAE_MEM=console@DTP_URGENT,file@DTP_LOWEST For more information about special configuration commands, see Advanced DigiTrace configuration.
Trace facilities are used by DigiTrace to determine whether or not the given trace statement should be displayed. Trace facilities allow the user to filter trace statements at the component level.
Trace priorities are used by DigiTrace to determine whether or not the given trace statement should be displayed. DigiTrace specifies five trace priorities:
DTP_LOWEST DTP_LOW DTP_NORMAL DTP_HIGH DTP_URGENT The DigiTrace configuration file specifies minimum trace priorities. For example, if a trace statement uses DTP_LOW and DigiTrace is configured to use DTP_NORMAL as the minimum trace priority, then the trace statement will not be sent to the output target. In general, the DTP_LOWEST priority setting will populate the trace output with the most verbose information while the DTP_URGENT setting will output only the most high level details.
This section includes descriptions of several facilities that are used in Pro Tools and other Avid audio products. The logging provided by these facilities may be helpful when diagnosing plug-in issues.
DTF_AAXPLUGINS
DTF_AAXPLUGINS facility will slightly reduce the overhead of trace statements and chip communication on HDX systems. DTF_AAXHOST at DTP_NORMAL DTF_PLUGINS at DTP_LOW DTF_TIPLUGINS at DTP_NORMAL DTP_LOW for deeper tracing.DTF_TISHELLMGR at DTP_HIGH DTF_DAE_HOSTDEVICE at DTP_URGENT DTF_DAE_ERRORS at DTP_NORMAL or DTP_LOW DTP_LOW to enable stack traces. DTF_ASSERTHANDLER at DTP_NORMAL or DTP_LOW DTF_DAE_ERRORS: Information about any asserts that fail. Use DTP_LOW to enable stack traces. DTF_THREAD_NAMES_AND_PRIORITIES at DTP_NORMAL or DTP_LOW DTP_NORMAL for just names and IDs, and DTP_LOW to include priorities. DTF_PACESUPPORT at DTP_NORMAL DTF_ADC at DTP_NORMAL DTF_AUTOMATION at DTP_LOW DTF_AUDIOSUITE at Pro Tools 11 and higher includes logging for audio render callback performance. To enable this logging, enabled the DTF_DAE_HOSTDEVICE facility at DTP_URGENT. This facility will enable logging of real-time audio render thread metrics around any render errors that occur.
Here is an example of a performance log:
Int(LL): hstEr=0, ioEr=0, dif=2665(2891,23129), tot=2517(1648,2317), in=51(58,83), clbk=2158(1508,2158), out=108(99,164), offset=[12], mxW=1101(com.avid.aax.eleven.free) The different values included in this log are:
hstEr ioEr dif tot in clbk out offset A log of 'x=a (b,c)' means that the (x) value (e.g. tot) for the interrupt was (a) us, the running average was (b) us, and the maximum value encountered was (c) us. Therefore, in the example above:
In practice, it is difficult to precisely log this information during an error. This is due to changes in the interrupt pattern and scheduling when the audio engine is halted. In order to account for this, the performance logging will print out logs for several interrupts around when any error occurs. The actual audio engine error (hstEr) may be reported for a "junk" interrupt cycle that is spuriously logged during this halt process.
Standard printf-style logging from AAX plug-ins is very easy. This feature is built into the AAX specification and is exposed to plug-ins via the AAX_TRACE and AAX_TRACE_RELEASE macros. For more information about basic logging, see the documentation for those macros.
DTF_AAXPLUGINS trace facility must be enabled.As a developer, you can use several advanced macros to extend the functionality of DigiTrace logging in your plug-in beyond the simple printf-style features provided by AAX_TRACE. The full DigiTrace macro suite includes macros for stack traces, very long traces, or even the ability to dump a block of memory to the log.
Note that these advanced features are only available on the host system. They are not currently available from algorithms running on embedded hardware.
To add advanced DigiTrace instrumentation to your source code you must:
If you have problems including the DigiTrace header file, try moving it to the top of the file that you're including it into. DigiTrace has no other dependencies and should be safe to include into any component.
Should you run into linker errors or other problems after adding the DigiTrace header file, please go through the following items and verify that each is included in your project:
DigiTrace provides five core macros for trace output, which are:
TRACE_R - for general printf style tracing. Subject to a total line limit of 256 chars.TRACE_PUTS_R - prints an arbitrary length buffer, splitting it up into clean lines based on line breaks. No formatting.STACKTRACE_R - for stack trace printing. See below.MEMTRACE_R - for memory buffer hex tracingFXTRACE_R - for automatic function entry and exit tracingAll of the macros listed above are general-use macros, which generate output in both Debug and Release builds. They each have a debug-only variant which excludes the trailing "<TT>_R</TT>". Like AAX_TRACE, these debug-only versions compile to a noop in release builds.
The use of debug-only macros is not usually necessary due to the fact that release traces are encrypted and hidden from end users (but not from other developers.) As a best practice, we recommend using the "_R" version of a macro whenever possible. The debug versions of the macros should only be necessary in special circumstances where you specifically do not want to compile the code into release builds.
For more information about tracing in release builds see Security concerns
Adding a DigiTrace statement to your code is as easy as making a single function call thanks to DigiTrace's predefined macros. The basic macro syntax is:
Here is a code sample:
The STACKTRACE_R macro is very useful for getting stack traces of important events in the code like throwing errors (which can be thrown from many locations). One particularly useful feature of this macro is that it allows you to specify a facility and priority for the printf part of the stacktrace, e.g. DTP_NORMAL, and another one for the stacktrace step, e.g. DTP_LOW. See DigiTrace.h for a full list of macros and their documentation.
You can explicitly disable tracing in an instrumented file in the build by defining the MTurnDbgTraceOff symbol at the top of the file.
Unless you provide your own logging encryption, DigiTrace logs are not secure and should not be used to store any sensitive information.
Logs generated by Pro Tools release builds on users' systems are encrypted. This is primarily for the sake of avoiding confusion in our user community, since DigiTrace logs can be cryptic and potentially misleading for users who are not familiar with our code.
Avid and other third-party developers will see your plug-ins' release trace statements if they load your plug-ins with the appropriate trace facilities enabled. We highly recommend that you keep this in mind when developing your trace statements, both in order to prevent confusion (see the formatting guidelines in the AAX_TRACE_RELEASE documentation) and in order to maintain the security of your code.
The basic configuration command to enable tracing for a facility is described above in Configuring DigiTrace.
There are also additional commands that can be added to the DigiTrace configuration file for more advanced configurations.
#' character is ignored FileTracingDir = { DIRPATH } USE_RELATIVE_PATH Append = { true | false } false true, the output of this trace will be appended to any existing log file with the same name. Otherwise, this trace will overwrite an existing log file with the same name. LogFileLimit = { LIMIT } TraceQueueSize = { small | medium | large } small BeQuiet = { true | false } false true, this configuration option makes all trace output occur without any decoration (i.e. no timestamps, no thread id, no process id, etc.). FileId = { FILEID } Name = { NAME } DigiTrace config files can be loaded dynamically, which means that you can add new configs while the instrumented application is running. Below are the details surrounding dynamic loading:
DigiTrace is an internal testing and troubleshooting tool. Although we will try to provide up-to-date documentation so that third-party developers can use this tool, we may need to change the way that DigiTrace works at some point and so we cannot make any promises regarding forwards-compatibility.
At the time of this writing:
If you notice significant bugs or other problems with DigiTrace in any Pro Tools release then we encourage you to report the issues to us on the developer forum. We may not be able to address issues immediately, but your feedback is appreciated.
As with all information provided in the AAX SDK, the information provided in this documentation is confidential and is bound by the terms of your NDA with Avid. You may provide customized DigiTrace configuration files to end users in order to generate useful debugging information on their systems. However, you may not provide users with decrypted DigiTrace logs or with other details provided in this DigiTrace documentation.
1.8.5
