AAX SDK
2.1.1
Constants used by ChunkDataParser class.
Variables | |
| const int32_t | FLOAT_TYPE = 1 |
| const char | FLOAT_STRING_IDENTIFIER [] = "f_" |
| const int32_t | LONG_TYPE = 2 |
| const char | LONG_STRING_IDENTIFIER [] = "l_" |
| const int32_t | DOUBLE_TYPE = 3 |
| const char | DOUBLE_STRING_IDENTIFIER [] = "d_" |
| const size_t | DOUBLE_TYPE_SIZE = 8 |
| const size_t | DOUBLE_TYPE_INCR = 8 |
| const int32_t | SHORT_TYPE = 4 |
| const char | SHORT_STRING_IDENTIFIER [] = "s_" |
| const size_t | SHORT_TYPE_SIZE = 2 |
| const size_t | SHORT_TYPE_INCR = 4 |
| const int32_t | STRING_TYPE = 5 |
| const char | STRING_STRING_IDENTIFIER [] = "r_" |
| const size_t | MAX_STRINGDATA_LENGTH = 255 |
| const size_t | DEFAULT32BIT_TYPE_SIZE = 4 |
| const size_t | DEFAULT32BIT_TYPE_INCR = 4 |
| const size_t | STRING_IDENTIFIER_SIZE = 2 |
| const int32_t | NAME_NOT_FOUND = -1 |
| const size_t | MAX_NAME_LENGTH = 255 |
| const int32_t | BUILD_DATA_FAILED = -333 |
| const int32_t | HEADER_SIZE = 4 |
| const int32_t | VERSION_ID_1 = 0x01010101 |
| const int32_t AAX_ChunkDataParserDefs::FLOAT_TYPE = 1 |
| const char AAX_ChunkDataParserDefs::FLOAT_STRING_IDENTIFIER[] = "f_" |
| const int32_t AAX_ChunkDataParserDefs::LONG_TYPE = 2 |
| const char AAX_ChunkDataParserDefs::LONG_STRING_IDENTIFIER[] = "l_" |
| const int32_t AAX_ChunkDataParserDefs::DOUBLE_TYPE = 3 |
| const char AAX_ChunkDataParserDefs::DOUBLE_STRING_IDENTIFIER[] = "d_" |
| const size_t AAX_ChunkDataParserDefs::DOUBLE_TYPE_SIZE = 8 |
| const size_t AAX_ChunkDataParserDefs::DOUBLE_TYPE_INCR = 8 |
| const int32_t AAX_ChunkDataParserDefs::SHORT_TYPE = 4 |
| const char AAX_ChunkDataParserDefs::SHORT_STRING_IDENTIFIER[] = "s_" |
| const size_t AAX_ChunkDataParserDefs::SHORT_TYPE_SIZE = 2 |
| const size_t AAX_ChunkDataParserDefs::SHORT_TYPE_INCR = 4 |
| const int32_t AAX_ChunkDataParserDefs::STRING_TYPE = 5 |
| const char AAX_ChunkDataParserDefs::STRING_STRING_IDENTIFIER[] = "r_" |
| const size_t AAX_ChunkDataParserDefs::MAX_STRINGDATA_LENGTH = 255 |
| const size_t AAX_ChunkDataParserDefs::DEFAULT32BIT_TYPE_SIZE = 4 |
| const size_t AAX_ChunkDataParserDefs::DEFAULT32BIT_TYPE_INCR = 4 |
| const size_t AAX_ChunkDataParserDefs::STRING_IDENTIFIER_SIZE = 2 |
| const int32_t AAX_ChunkDataParserDefs::NAME_NOT_FOUND = -1 |
| const size_t AAX_ChunkDataParserDefs::MAX_NAME_LENGTH = 255 |
| const int32_t AAX_ChunkDataParserDefs::BUILD_DATA_FAILED = -333 |
| const int32_t AAX_ChunkDataParserDefs::HEADER_SIZE = 4 |
| const int32_t AAX_ChunkDataParserDefs::VERSION_ID_1 = 0x01010101 |
1.8.5
