AAX SDK  2.1.1
Macros | Functions
AAX_SliderConversions.h File Reference
#include "AAX.h"
#include <algorithm>
#include <stdint.h>
Go to the source code of this file.
Description
Legacy utilities for converting parameter values to and from the normalized full-scale 32-bit fixed domain that was used for RTAS/TDM plug-ins.
Legacy Porting Notes:
These utilities may be required in order to maintain settings chunk compatibility with plug-ins that were ported from the legacy RTAS/TDM format.
Note
AAX does not provide facilities for converting to and from extended80 data types. If you use these types in your plug-in settings then you must provide your own chunk data parsing routines.
Macros
#define AAX_SLIDERCONVERSIONS_H
#define AAX_LIMIT(v1, firstVal, secondVal)   ( (secondVal > firstVal) ? (std::max)((std::min)(v1,secondVal),firstVal) : (std::min)((std::max)(v1,secondVal),firstVal) )
Functions
int32_t LongControlToNewRange (int32_t aValue, int32_t rangeMin, int32_t rangeMax)
int32_t LongToLongControl (int32_t aValue, int32_t rangeMin, int32_t rangeMax)
 Convert from int32_t control value 0x80000000...0x7FFFFFFF to a int32_t ranging from rangeMin to rangeMax (linear) More...
double LongControlToDouble (int32_t aValue, double firstVal, double secondVal)
 Convert from int32_t control value 0x80000000...0x7FFFFFFF to an double ranging from firstVal to secondVal (linear) More...
int32_t DoubleToLongControl (double aValue, double firstVal, double secondVal)
 Convert from an double ranging from firstVal to secondVal (linear) to int32_t control value 0x80000000...0x7FFFFFFF. More...
int32_t DoubleToLongControlNonlinear (double aValue, double *minVal, double *rangePercent, int32_t numRanges)
double LongControlToDoubleNonlinear (int32_t aValue, double *minVal, double *rangePercent, int32_t numRanges)
double LongControlToLogDouble (int32_t aValue, double minVal, double maxVal)
 Convert from int32_t control value 0x80000000...0x7FFFFFFF to an double ranging from minVal to maxVal (logarithmic) More...
int32_t LogDoubleToLongControl (double aValue, double minVal, double maxVal)
 Convert from an double ranging from minVal to maxVal (logarithmic) to int32_t control value 0x80000000...0x7FFFFFFF. More...
Macro Definition Documentation
#define AAX_LIMIT (   v1,
  firstVal,
  secondVal
Function Documentation
int32_t LongControlToNewRange ( int32_t  aValue,
int32_t  rangeMin,
int32_t  rangeMax
int32_t LongToLongControl ( int32_t  aValue,
int32_t  rangeMin,
int32_t  rangeMax
double LongControlToDouble ( int32_t  aValue,
double  firstVal,
double  secondVal
int32_t DoubleToLongControl ( double  aValue,
double  firstVal,
double  secondVal
int32_t DoubleToLongControlNonlinear ( double  aValue,
double *  minVal,
double *  rangePercent,
int32_t  numRanges
double LongControlToDoubleNonlinear ( int32_t  aValue,
double *  minVal,
int32_t  numRanges
double LongControlToLogDouble ( int32_t  aValue,
double  minVal,
double  maxVal
Note
This is LOGARITHMIC, so minVal & maxVal have to be > zero!
int32_t LogDoubleToLongControl ( double  aValue,
double  minVal,
double  maxVal
Note
