AAX SDK  2.1.1
List of all members | Classes | Public Member Functions
AAX_CBinaryDisplayDelegate< T > Class Template Reference
#include <AAX_CBinaryDisplayDelegate.h>
Inheritance diagram for AAX_CBinaryDisplayDelegate< T >:
Inheritance graph
[legend]
Collaboration diagram for AAX_CBinaryDisplayDelegate< T >:
Collaboration graph
[legend]
Description
template<typename T>
class AAX_CBinaryDisplayDelegate< T >
A binary display format conforming to AAX_IDisplayDelegate.
This display delegate converts a parameter value to one of two provided strings (e.g. "True" and "False".)
 AAX_CBinaryDisplayDelegate (const char *falseString, const char *trueString)
 Constructor. More...
 AAX_CBinaryDisplayDelegate (const AAX_CBinaryDisplayDelegate &other)
AAX_IDisplayDelegate< T > * Clone () const
 Constructs and returns a copy of the display delegate. More...
bool ValueToString (T value, AAX_CString *valueString) const
 Converts a real parameter value to a string representation. More...
bool ValueToString (T value, int32_t maxNumChars, AAX_CString *valueString) const
 Converts a real parameter value to a string representation using a size hint, useful for control surfaces and other character limited displays. More...
bool StringToValue (const AAX_CString &valueString, T *value) const
 Converts a string to a real parameter value. More...
void AddShortenedStrings (const char *falseString, const char *trueString, int iStrLength)
- Public Member Functions inherited from AAX_IDisplayDelegateBase
virtual ~AAX_IDisplayDelegateBase ()
 Virtual destructor. More...
Constructor & Destructor Documentation
template<typename T >
AAX_CBinaryDisplayDelegate< T >::AAX_CBinaryDisplayDelegate ( const char *  falseString,
const char *  trueString
Constructor.
Parameters
[in]falseStringThe string that will be associated with false parameter values
[in]trueStringThe string that will be associated with true parameter values
References AAX_CString::Length().
Here is the call graph for this function:
AAX_CBinaryDisplayDelegate< T >::AAX_CBinaryDisplayDelegate ( const AAX_CBinaryDisplayDelegate< T > &  other)
Member Function Documentation
AAX_IDisplayDelegate< T > * AAX_CBinaryDisplayDelegate< T >::Clone ( ) const
virtual
In general, this method's implementation can use a simple copy constructor:
template <typename T>
AAX_CSubclassDisplayDelegate<T>* AAX_CSubclassDisplayDelegate<T>::Clone() const
return new AAX_CSubclassDisplayDelegate(*this);
Implements AAX_IDisplayDelegate< T >.
bool AAX_CBinaryDisplayDelegate< T >::ValueToString ( T  value,
AAX_CString *  valueString
) const
virtual
Parameters
[in]valueThe real parameter value that will be converted
[out]valueStringA string corresponding to value
Return values
trueThe string conversion was successful
falseThe string conversion was unsuccessful
) const
virtual
Parameters
[in]maxNumCharsSize hint for the desired maximum number of characters in the string (not including null termination)
Return values
bool AAX_CBinaryDisplayDelegate< T >::StringToValue ( const AAX_CString &  valueString,
T *  value
) const
virtual
Parameters
[in]valueStringThe string that will be converted
[out]valueThe real parameter value corresponding to valueString
Return values
void AAX_CBinaryDisplayDelegate< T >::AddShortenedStrings ( const char *  falseString,
const char *  trueString,
int  iStrLength
